0 Curious as to what I actually have
0 '89 Sportster 1200 Chopper
0 Bikes and Bells and Bears
0 Engine dies when choke off
0 rpm jump pulling in clutch
0 Value of a Boattail?
0 New to Harley
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
0 79 ironhead
0 Head gaskets.
0 Stock 883 cold blooded
Last Post: oldboy
0 THE Trainspotting Thread
0 Need help with glare.
0 99 1200s clutch drag
Last Post: jordan1200
0 Not charging issue!
0 V&H Shortshot question
Last Post: lucifer_mr2
0 1977 Bright Blue
Last Post: Jowniofownio
0 z bars
Last Post: jharback
Old 6th September 2008
corzy's Avatar
corzy corzy is offline
Sportster/Buell Year: 03
corzy is an unknown quantity at this point
Default Drive belt
Hi there, just busted my drive belt on my 03 sporty, have 32000 miles on her so probably just wear, as i dont drive too hard, just alot (9000+miles this season) ordered from the local yamaha dealer as i cant stand the HD dealer, 175 sounds to be around normal.
before i get started as ive never changed one, is there anything i need to consider before starting????
cant find any threads with advise on changing the belt?
any info is much appreciated
thanks
Corzy
Corzy - 03 sporty 883 borred out to 1212
milmat1's Avatar
milmat1 milmat1 is offline
Sportster/Buell Year: 06
thanks
Corzy
YES! Get the manual !!
Then do a search on here, Theres a ton of info about the belts and breakage. If you don't adjust it right you can expect another break ! There quite Fininky !! Other than the adjustment the replacemnet is straight forward !
Use the search at the bottom of the page !!
66impala's Avatar
66impala 66impala is offline
66impala is a name known to all66impala is a name known to all66impala is a name known to all66impala is a name known to all66impala is a name known to all66impala is a name known to all66impala is a name known to all66impala is a name known to all66impala is a name known to all66impala is a name known to all66impala is a name known to all
Ditto, get a manual. Buy a belt tension gauge, and make up the tool to measure from your axle bolt to the swing arm bolt ( I bought a 2ft length of steel rod at home depot to make the tool). I changed my belt while on vacation in the motels parking lot, I made it home and properly adjusted to specs. Mine broke at 17k and right after having tires changed, my 12yr old son and I were on a road trip and we were loaded up good also.
The HD belt was 205.00 last year from the dealer.
2004 883 custom, softail heritage handlebars, spoked dyna rear wheel, 1200c stock rear pulley, softail deluxe rear lights, dyna 10row oil cooler, shovelhead hard saddlebags with roadking air shocks. A few splashes of bling here and there.
corzy's Avatar
ya i have the manual, where could i get and how much would a belt tension gauge be? thanks for the tips, will get started once the part gets here
Desertfox's Avatar
Desertfox Desertfox is offline
Sportster/Buell Model: 2001 883 Custom
Desertfox has disabled reputation
Mine is an '01 with the original belt still on it. Haven't had any issues with it yet(knock on wood). Although the new belts have a service life rated "indefinate", that does not take into consideration someone deliberately trying to break one . As for changing it? I would definately hand that over to a professional. Although they are tough they will not tolerate misalignment. You can shred one quite easily by getting the alignment out a nothingth of an inch. Unless you have some specialized equipment and know what the hell you are doing you will be spending another $200.00 on a belt very soon. The $75.00 to $100.00 you would pay a professional to do it could seem cheap by comparison.
If you hate me, I've probably given you just cause. There, feel better?
ReddTigger's Avatar
you can use a wire hanger to make the alignment tool,, Very simple, I used a Zip Tie instead of an "O" ring and it's worked for me.
The belt tension gauge should only be about 10-15 bucks at the dealership.
States I've Ridden in
71.3 hp 70.8 tq
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
If you have the manual, just follow that to change the belt. It isn't too difficult.
Folkie
South East England Riders
robzuc97's Avatar
robzuc97 robzuc97 is offline
Other Motorcycle Model: FLSTC
Other Motorcycle Year: 1997
robzuc97 is on a distinguished roadrobzuc97 is on a distinguished road
These aren't step-by-step procedures but a few tidbits: Using service manual check for proper direction of the belt before installation (look it up). The belt can be installed over the swing arm by removing the lower shock blot and swinging up but try not to excessively twist, bend, or abuse it too much. A quick tension check is to twist the belt gently; it should go no further the 1/4 twist and will be at proper tension if you don't want to buy the tool. Check the pulleys for any damage (rock could've got up there). Any distortion of the drive or esp. the rear pulley=replace or you'll keep breaking belts from accelerated wear. Follow vehicle alignment procedure carefully, check & double check esp. the adjuster screws. There is a 1/32th inch tolerance for axle alignment. Use a torque wrench on all fasteners. The belt may be replaced without removing the tire but needs raised to adjust belt and remove lower shock bolt. Follow the manual verbatim! and take your time to do it right. And the biggy: if you screw up, it will have "catastrophic results". And have fun! I lost mine on the side of the road at 12K (rock?) and had to change it there!
Old 7th September 2008
milmat1's Avatar
$22.00 At the stealers !!
Folkie's Avatar
Brass Nut
Here it is:
(clickety click)
