0 rethreadable?
Last Post: senseigreen
Last Post: mct496
Last Post: conv90
Last Post: Jowniofownio
0 Intro from New England
0 Diagnostic help
8 Crankshaft Failure
Last Post: spitfirechopper
0 Head gaskets.
Last Post: Fridge
Last Post: MatHormell
Last Post: Ben221
Last Post: blindfredy
0 first harley- help!!
Last Post: cantolina
0 oil cooler or not?
0 Engine dies when choke off
Last Post: shovithead
0 90 in. Build
Last Post: mac93
0 newby from Australia
Last Post: GeoK
Old 19th June 2006
SuaveRider SuaveRider is offline
SuaveRider has disabled reputation
Default Clicking noise from drive pulley!
Hello,
I'm getting a clicking sound from my secondary belt. Sounds and looks like the teeth on my belt are clicking into / out of the rear pulley. The tighter the belt is, the louder it gets. You can see the belt ride slightly on top of the teeth until they finally click into position. I've messed with the axle adjusters but can't seem to get the noise to stop. This is a brand new BDL belt.
Anyone have suggestions for me? Should the belt make noises? Will it wear in? Also, I just noticed a slight play in my front pulley. I can just barely get it to move in and out by maybe 1/64". Is this normal or should it be so tight as to not get any movement at all? If so, could this have something to do with my noise? I was going to try to make sure the front pulley nut was as tight as possible but really don't have the tools to budge it.
All help appreciated
Thanks
Old 21st June 2006
Nothing? Bueller, Bueller?
Old 21st June 2006
FSZEKE302's Avatar
FSZEKE302 FSZEKE302 is offline
US NAVY Vet, ADR2
Other Motorcycle Model: FXD SuperGlide
FSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the rough
Is this the original belt? Has anything been changed. I've never heard of this problem, but it doesn't sound normal.
ZEKE] Old and Proud 1994 XLH [Black of Course] " A fear of weapons is a sign of retarded sexual and emotional maturity " -Sigmund Freud http://xlforum.net/photopost/showgal...r=3484&cat=500
US NAVY Vet, ADR2
Old 26th June 2006
canroc's Avatar
canroc canroc is offline
Sportster/Buell Model: 2004 XL 1200 Custom
canroc is an unknown quantity at this point
Originally Posted by SuaveRider
Hello,
Thanks
Did you get this resolved? I'm hearing the same thing now when I push the bike while it is in neutral and not running.
"There is no cure for birth and death save to enjoy the interval"... George Santayana
Old 26th June 2006
chrishajer's Avatar
Sportster/Buell Year: 1988
Could be lots of things. I don't know what year your bike is, but I see you have a BDL belt. Why did you install the BDL belt? What happened to the old belt? Miles on vehicle? Visual condition of the pulleys? Are you sure you have the correct pitch belt from BDL (part number)?
Also, on the front pulley - it will move in and out a LITTLE bit. If the nut is tight (not sure what year again) then the pulley is not likely to be loose. Need more information to be able to help you more.
--Chris
