0 Stage 1 results
0 Screw Loose's Repairs
0 C.O.B.B run west
0 Lowboy frame conversion
Last Post: Sportster-92
0 Spokes or Mags
0 Project of the day
Last Post: Baby883
Last Post: kaveebee
Old 20th February 2005
XLFREAK XLFREAK is offline
Default slipping clutch
my clutch is slipping so badly that i cant get any acceleration at any rpm over 2500, but i have adjusted the clutch both ways to no avail. Is there anything left i can try besides changing the plates?
62 XLCH
flathead45's Avatar
Sportster/Buell Year: 86
Other Motorcycle Year: 1945
pull the plates and rough them up with some fine grit sandpaper (the fiber ones) then clean the steel ones up and replace and readjust
old sporty plates glaze up kinda quick and you need to brake the glaze off them
I have two sets of plates , one spare that I deglaze and store and the one in the bike (speeds up changes, cause I can clean the old plates at will)
or try some kevlar plates (I know you don't want to replace them but kevlar lasts)
"lord of the Night Lite"
thank god for darwin ;)
Old 15th July 2005
Chris B.'s Avatar
Chris B. Chris B. is offline
Sportster/Buell Model: Ironhead 1000
Sportster/Buell Year: 1973
Chris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura about
yeah, having the same problem... starts to slip about 2500rpm. Thx flathead, may have to try that!
Chris B. -'73 Ironhead
Similar Threads
Clutch slipping?? HHahn001 Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 7 15th July 2005 19:27
To clutch or not to clutch ? Predator Sportster Motorcycle General Discussion and Problems 36 10th April 2005 05:48
Clutch drag jag1 Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 1 14th February 2005 19:11
Clutch advice needed. BonRu Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 10 11th February 2005 14:39
Clutch Busted? jaws Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 7 6th January 2005 21:55
