Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
0 1974 Ironhead
0 24633-77 Breather assembly
0 Ei
Last Post: Serious Blac
0 New from Utah
0 Post season carnage
0 De-lowing a Superlow with Progressive Monotubes?
Last Post: FuriousGeorg
0 Exhaust Clamp Fitting
Last Post: Yochstein
Last Post: norseXL
0 Rubber mount Oil tank Vent line Routing
0 Need help on bolt size - 92 XL1200, mid pegs
Last Post: r4fthrs
0 Reflectors...Yeah, or Neh
Last Post: 60weight
0 1250 Conversion troubles
  #91
Old 20th August 2010
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
Originally Posted by tara View Post
thanks, on every manual, even in the Clymer, they say to remove pushrods and tappets
They don't say that in the FSM; another example of the FSM being better than one of these third party manuals.
Folkie
South East England Riders
tara's Avatar
tara tara is offline
Sportster/Buell Model: 1200 xl
Sportster/Buell Year: 1987
tara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the rough
what is FSM ? clymer has normally a great reputation, i have used it for years, it is quite good usually.
thanks
1986 frame - 1997 1200 engine stage 1.5 - N2 cams- single fire Accel - Crane hi 4 - big sucker - 23 T sprocket 48 T - Ohlins #3#3 13 1/4 - showa 35 mm Progressive spring - all brake system by Performance Machine second motor 86 4 speed 883conver 10.5 1200 V8 cams 1200 heads - tuned CV cards by killer motorcycle product -
Folkie's Avatar
Brass Nut
Factory service manual. By far the best (as this example proves).
Old 23rd August 2010
tara's Avatar
thanks for the info
Old 1st March 2011
DaytonaSportster's Avatar
DaytonaSportster DaytonaSportster is offline
DaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond repute
Excellent write up!! I used this as a quick reference and did my N4 change out today. Now to put some miles on them!
http://xlforum.net/forums/showthread.php?t=842245
Old 30th March 2011
fukeles fukeles is offline
Sportster/Buell Model: Sportster 883 conv 1200
fukeles is an unknown quantity at this point
Hello,
Turbota wrote one important sentence.
Once all cams are removed, DO NOT rotate the engine. This will make it much easier to install the new cams in there proper position.
Here I made a mistake. My cams was removed and I had move the bike in my garage. Of course, I forgot 5th gear and my engine rotated
Can you please advise me how I can install the cams properly now?
Thanks a lot for every advice
Mark
Old 30th March 2011
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
Originally Posted by fukeles View Post
Hello,
Mark
Just line up the timing mark on the pinion gear, to where it is pointed directly at the center of the #2 bushing.
Sic Semper Evello Mortem Tyrannis
Old 30th March 2011
steelworker's Avatar
Other Motorcycle Year: 2016
Hello,
Mark
It doesn't make it much more difficult. Just rotate the engine until the mark on the pinion gear is pointing to the centre of the bush for the #2 cam (edit: as in Rico's photo above - he beat me to it!), then install the #2 cam to check the mark on it aligns with the mark on the pinion gear (remove the cam and rotate the engine slightly if necessary to align).
Now remove the #2 cam.
Fit the #1 and #3 cams and align the marks on them with the centre of the #2 cam bush. Hold them in place while you reinstall the #2 cam. Check that all marks on cams 1-3 and the pinion gear align. Slide the #2 cam out slightly if necessary to adjust the alignment of cams 1 and 3.
Fit cam #4, aligning the mark with the mark on cam #3.
Old 31st March 2011
While mine did not rotate when installing, just 1/2 my cams came out with the cover. So I just rotated and aligned up no problem.
Old 31st March 2011
evereyken's Avatar
evereyken evereyken is offline
Sportster/Buell Model: 883r convert to 1214 SOLD
Other Motorcycle Model: DL650AL2 VStrom
evereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really niceevereyken is just really nice
My cams came out when I removed the cover and I did as Rico described above and everything lined up just right.
SOLD on 4/3/12 - '06 883R with NRHS 1214 conversion using Wiseco 9.5:1 pistons, w cams, TC88A ICM, RevTech FXDX AC, 45/180 jetting, IMS 2.5 turns, Bub/Rinehart 2 into 1, 1200s bars, Progressive front springs w/10wt BelRay, Superbrace, 1200s rear shocks, tach kit, Flyscreen, Jagg oil cooler
Now riding a 2012 Suzuki DL650AL2 "WeeStrom"
