Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
0 Sportster or Street Bob
Last Post: RKN
0 Drive Chain Adjustment
0 Newbie CV rebuild
0 1977 xlch starter issues
Last Post: datimm09
0 no rear brake light
5 Transmission HELP!
Last Post: Twistedrench
0 Reflectors...Yeah, or Neh
Last Post: kap
0 Primary Chain Adjustment
Last Post: sltm1
0 Tachometer drive
Last Post: sleighcrane
Old 5th July 2006
Narley's Avatar
Narley Narley is offline
Narley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura about
Originally Posted by stevo
OK... just had a look..
the part numbers on the wheels are casting part numbers....
the casting part number for both 5 speed wheels is the same as the right side of 4 speeds
BUT it's an A number which means an update of the origional number.... which in this case is a different machining of the same casting/forging...
4 speed and 5 speed aren't interchangeable...... different length outputs on the primary side...
Kerry ... not sure on the key/slot thing ... all the 5 speed sporties I can recall have been keyed and I just put a set of S&S Supreme rods on a set of 94 wheels and put 'em in a 2000 model with a post 2000 pinion gear and E grind cams.
Just figuring this out now. the s&s flywheel set up is designed after the old pinion shaft I was told. I have broken the pinion shaft key and chewed up my redshift 643 cams in the process. Remeber that break i was tlking about that could be a problem this season. well it happened. So i have ordered the new wheels and shafts and rods from s&s and decided to get new cases from them to lessen the chance of future problems. I was shown a set of older wheels and the pinion and shaft were keyed to fit together ..not the single little iron key that my 02 was using but several meshing notches...looked way stronger.
2002 157 hp sportster nearly in the nines...
1995 Blacked out Cafe style 1200 with xb conversion.
The cannons don't thunder ,there is nothing to plunder.
My Caribbean yearnings 200 years late. I am a forty year old victim of fate. Arriving on the scene 2 centuries late. Alas I am glad still, for having found me best mate. With the wind in my sails...n the rubber side down, I cruise dangerous land ,they all know me in town. No parrot, no sword..with regular life I be bored. So I does what I can, We don't set ships a sail,we aint walked no planks, but we live best we can and for that we give thanks.
Old 5th July 2006
ted's Avatar
ted ted is offline
Senior Master Bike Builder
Sportster/Buell Model: 883-1380cc hot rod
Sportster/Buell Year: 87
Sportster/Buell Model #2: wife's 883-1200
Sportster/Buell Year #2: 87
ted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to behold
Cool
Pics of pinion shafts. Splined is a 87, keyed is a 89. I have seen keys fail when used with agressive cams. That is why S&S uses the older splined shaft. On the lightweight S&S bottom in my motor I was able to use stock 87 pinion and oil pump gears. The motor co, in their infinate wisdom decided to make it weaker to save some $$$.
Ted
Still crazy after all these years.
Late 87-883 Hugger/1380cc (84") conversion. Too many cool parts to list. Built engine on a fresh set of cases, so conversion might not really describe it. Estimated near 115 hp.
Early 87-883/1200 conversion. Wife's bike. SE heads, 1200 flat pistons, 40" Drag Pipes, everything else stock.
"Wise men speak because they have something to say; Fools because they have to say something."
Plato
Old 5th July 2006
I am sorry you did not like my response but looking up part numbers is not a simple 1 or 2 minute deal.
You would not believe how many people expect me to give them free advice and recommendations only for them to turn around and buy the parts off of the internet.
I cannot compete on price with internet warehouses. The only thing I have is our knowledge and expertise to set us apart from them. If I give that away for free how do you expect us to stay in business?
If you had been an established customer I would have been more than happy to assist you.
Old 5th July 2006
Narley's Avatar
Beauty pics...they say a thousand words. the meat of the keyed system had me shaking my head. That splined shaft looks good .
Old 5th July 2006
ted's Avatar
ted ted is offline
Dan,
I figured that with the expertice at NRHS the answer would be right at the tip of the tounge. 4 speed cranks dont work in 5 speeds due to the alternator change. I have raced and wrenched on 4 speed Sportys. I put the present motor together myself. I know 4 speeds, but not 5 speeds. I was looking at helping a guy out that need a flywheel assy. I was not going to sell the guy something that would not work. So, I went to the experts. Maybe we all learned something here. I can't imagine that you didn't know the answer though.
Ted
Old 6th July 2006
ted's Avatar
ted ted is offline
Cool
The guy is looking at S&S for a new crank now. Can't go wrong there. I suggested he look into the lightweight race wheels. I sure like mine. ;-)
Thanks again for all the help guys.
Ted
