0 Slip on muffler
Last Post: Tucsonmax1
0 1972 tank fitment
0 bike went for a slide
0 New England 2018
Last Post: The Crusher
0 90 in. Build
Last Post: Jheitt
0 Help me with gas cap...
0 Sportster or Street Bob
0 2016 48 Hesitating
Last Post: Screw Loose Dan
Last Post: dnaj11
Old 22nd February 2005
m0trh3d's Avatar
m0trh3d m0trh3d is offline
m0trh3d has disabled reputation
Unhappy HELP!! cam cover
I really need someone's help, bad..
I know that you guys know about sportsters so I am contacting you first.
I have a 90 sporty and here is my issue.
I had a screw break off in my cam cover, this screw is one(the bottom one) of two that attach the timing plate to the cover. While drilling it out I think that I went to far, I don't think that I broke thru( well I am sure I did not break completely though) but I don't know what is directly behind that screw that may have been hit...? My main concern is to find out if there is an oil passage for any of the gears etc.. that may have been effected?
Do you happen to have a cam cover laying around and can take a look for me to tell me what is there?
Thanks for the help
raysheen's Avatar
raysheen raysheen is offline
Sportster/Buell Model: 883XLH - 1200
Sportster/Buell Model #2: NRHS Stg 3 Thunderstorm
Sportster/Buell Year #2: 2000
raysheen is just really niceraysheen is just really niceraysheen is just really niceraysheen is just really niceraysheen is just really niceraysheen is just really niceraysheen is just really niceraysheen is just really niceraysheen is just really niceraysheen is just really niceraysheen is just really nice
Hi m0trh3d,
do you have any idea how far you went? How far can you stick your drill bit into the hole that you drilled? Not sure if you introduced yourself in the forum yet, but if not then welcome!
John
m0trh3d's Avatar
I hit a stop. so I am hitting metal. and when I stick a bit in there and pull it out and lay it on top it is right at the back portion of the rotor open area..So I beleive that I am ok but I am anal and paranoid and would realy love to know for sure what is behind there.. for piece of mind.. Ya know...
Similar Threads
04-05 Cam Install How-To (complete with pics) Turbota Sportster Motorcycle - Bottom End 31 25th April 2013 22:53
Stock cover on Big Sucker!!! shaggybob Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 6 7th May 2005 21:40
Air Cleaner Cover Mounting Opinions? phreak Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 5 18th April 2005 23:33
Am I screwed...Cam case cover? Luckymic Sportster Motorcycle General Discussion and Problems 15 27th March 2005 20:52
points cover engine Sportster Motorcycle Motor - Top End 2 16th November 2004 18:48
