first xlch
17th August 2010
Posts: 515 Sportster/Buell Model: 883N Sportster/Buell Year: 2009
Originally Posted by ParrotHead
Also, They changed the axle size in 2005. Says here they went from .75 to 1 inch in 05.
Correct!
Front axle size was 3/4 until 2009 when front and rear both changed to 25mm.
17th August 2010
Posts: 1,165 Sportster/Buell Model: XLH Sportster Sportster/Buell Year: 1991 Other Motorcycle Model: 650 Triumph Bonneville Other Motorcycle Year: 1970
what about the improved cams ('W" cams) and the better flowing heads with bigger valves
7mm valve stems etc.
883 / 1200 conversion, shrink ported high velocity heads, milled .020 off the compression side. stainless steel tulip conversion valves. 10:1 wiseco forged pistons. "W" cams, Crane HI-4E ignition module, forcewinder AC. mustang seat, Progressive springs, RK-shocks, fork brace. metzeler me880 tires, headlight modulator. PIAA intense white H4 bulb
17th August 2010
Bike Builder
Posts: 1,830 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2010 Sportster/Buell Model #2: XL883 SOLD Sportster/Buell Year #2: 2007 Other Motorcycle Model: Suzuki Inazuma GW250 Other Motorcycle Year: 2013
in 08 they change the solid axles for hollowed ones to reduce unsprung weight (tubes).
Also from '08 and up none of the tank decals said "SPORTSTER" until the 48 in 2010.
17th August 2010
Posts: 427 Sportster/Buell Model: XLCH Sportster/Buell Year: 1974
If I'm correct wasn't the 50th also the intro of the nightster if not disregard after all I have a i mean own an ironhead
17th August 2010
Posts: 7,427 Sportster/Buell Model: Sportster 1200C Sportster/Buell Year: 06
2011 The Sportster Line goes to hell in a handbasket !!
17th August 2010
Hmmm, did they switch to 25mm at the same time?
17th August 2010
Posts: 4,031 Sportster/Buell Model: XL 1200 Custom Sportster/Buell Year: 2004
Which year started the "Low Fuel" light?
17th August 2010
2011 1200 C dropped.
17th August 2010
Shifter shaft diameter and thus the primary cover different due to bushing opening being larger in 2005 from 2004. Ask me how I know!!
17th August 2010
2004..... Sportster officially declared NOT a girl's bike by me!
