Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > NRHS - High Performance
0 99 1200s clutch drag
Last Post: NZstu
0 z bars
Last Post: jharback
0 Value of a Boattail?
0 1967 XLCH stroker project
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
0 rpm jump pulling in clutch
0 1977 Bright Blue
Last Post: ericfreeman
Last Post: jammantoo
Last Post: lugster
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
Old 29th September 2008
gm1ll's Avatar
gm1ll gm1ll is offline
gm1ll is just really nicegm1ll is just really nicegm1ll is just really nicegm1ll is just really nicegm1ll is just really nicegm1ll is just really nicegm1ll is just really nicegm1ll is just really nicegm1ll is just really nicegm1ll is just really nicegm1ll is just really nice
Default Setting timing
I have a question about a nose cone ignition module. I have the Twintec 1005. Got it set up and static and dynamic timed. Even with the lowest setting on the switches, I have detonation at the slightest application of the throttle. Retarding the module back to the static timing point helps. My question is how far back can I go? Until it settles down and runs without detonation or can I only retard back as far as the static timing point? Is there any harm being done by retarding back past the static timing point? Is it possible to retard the module far enough back to cause other problems? I've probably asked the same thing 5 different times, but I'm just asking as they come to me.
Started life as a 2000 883 been through many mods but now is a 1212 w/04 XB heads, SE .497 cams, CV carb, Twintec 1005 ignition, Pro-flow oil pump.
Screw Head Quarters!
:marw3:
There is no problem with turning your igntion down by retarding it past the static timing. Static is usually about 28 degrees and often we have to start ours out around 26 degrees or even less if the compression is high. You would be surprised how many bikes we get on the dyno that are way too advanced. When we turn them down we will find 5-10 more hp just with a simple timing adjustment. More advance is not necessarily a good thing even if you don't hear any detonation.
Old 30th September 2008
gm1ll's Avatar
Thanks Dan. Oh I received the carb bracket and got it installed. It is just what I needed to replace that cheap chrome bracket that blocks the idle mixture screw. Thanks again!
Dakin Engineering Dakin Engineering is offline
Sportster/Buell Year: 1987
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1991
Other Motorcycle Year: 1995
Dakin Engineering has disabled reputation
Do you have a VOES? If not, is there a wire for it on the Twin Tec? (Not my brand) My iggy wants the wire grounded if not used...
Sam
Old 1st October 2008
gm1ll's Avatar
Yes Voes is connected and operational. I set the timing back a few degrees retarded from the static point and it's running much better.
Old 5th May 2009
Shamdog's Avatar
Shamdog Shamdog is offline
Sportster/Buell Model #2: Dyna Low Rider
Sportster/Buell Year #2: 2004
Shamdog is on a distinguished roadShamdog is on a distinguished roadShamdog is on a distinguished roadShamdog is on a distinguished road
Did you adjust your VOES? Are you running colder plugs.
Both need to be done.
'00 1200 VC (Very Custom)
Daytona Ignition / SE Round AC / HSR 42 / NRHS Stage 2 XB Heads / Hurricane 10.5:1 pistons / SE .536 Cams / RB LSR 2-1 / Ghost Flames / Bling and...well, you get the picture
Old 5th August 2009
Gojira's Avatar
Gojira Gojira is offline
Bike Builder
Sportster/Buell Model: 883r
Other Motorcycle Model: cb750
Other Motorcycle Year: 1974
Gojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the roughGojira is a jewel in the rough
i have a ? , turnning the ignition wich way to retard,clockwise????
Old 6th August 2009
Gone Gone is offline
Clockwise will advance timing and counter-clockwise will retard timing.
