Last Post: BluBeaSSt
Last Post: jcro61
0 90 in. Build
Last Post: mac93
Last Post: 883openpipes
0 New England 2018
0 Forty-Eight Special and Iron 1200 Sportsters announced today
0 Sportster or Street Bob
Last Post: seagullplayer
Last Post: conv90
Last Post: hscic
Old 12th July 2006
Moved On Moved On is offline
Talking My Bike Runs Great Again !!!
My bike has been running like crap since last November, but I finally nailed that sucker
Summary: It would cough and sputter after driving about 10 miles for about a mile. It would run great cold and great hot, just that 10 mile point it would run like crap for a little bit. Here's a few threads where I talked about the problem with folks...
Static Timing Check - Confusion
2.5 Vacuum Questions
Engine - Stutter Stutter KaBANG
I finally broke down and bought a new ignition module for $150. It runs great again, no sputtering at ten miles or any oter point and it seems to be running smoother than I can remember it havin run in a long time overall.
Funny story with the ignition module... I was riding to work last Friday and the bike was running worse than ever. So I decided I need to get that ignition module and try that because I'm running out of ideas. Stopped at the dealer after work. I stood in line for a while, the first parts counter guy asked what I needed and I asked for the parts catalog because I wanted some deutsch connector pins too. A few minutes later the second guy asks if I've been helped, I was still looking for the connector pins but I asked how much the module was and rattled off the part number. He told me he had one in stock, and he went out back and got it for me. I looked at it and kept looking at the catalog then the parts manager came over and helped me get the pins. I mentioned the ignition module to him, he didn't realize I was holding one so he said "I have SE modules and they cost less $119", so I ask him to get it. He comes out with one and it's for a 1200. Neither him or I knew the difference so I said I'll take the 883 OEM stock module............ he says he doesn't have any they've all been on back order and he's been calling dealers all around the state to find one for a guy in the shop. So I said "I have one right here", he looked and said "where the heck did you get that?" I just pointed to the stock room. He said "well you do more buisness here than the guy out back so you can have it", and I said "damn right I have my hands on it and there's no way you're getting it back now"
Well I hope if the guy waiting for the 883 ignition module is reading this I'm not in too much rouble, but your new ignition module works great
Thanks for all of the suggestions I got from everybody especialy Chris.
Gazza
Old 12th July 2006
chrishajer's Avatar
Sportster/Buell Year: 1988
Hey, rock on. Glad you fixed it. I have all these unresolved threads in the back of my gourd and I can check yours off now. Thanks for posting to resolution.
--Chris
Old 12th July 2006
renpia's Avatar
renpia renpia is offline
Sportster/Buell Model: 883 Sportster
renpia has disabled reputation
Gazza, I had a similar problem. Replaced the ingition with an SE and solved all my hesitation, sputtering problems. Why didn't you go with the SE though? It has a higher rev limiter.
1995 883/1200 Sportster nickname JOYRIDE - mods: cylinders bored and honed, 1200 pistons, Andrews N2 cam, S&S E carb with Yost power tube, Hypercharger with K&N, Screamin Eagle coil, SE ignition, SE wires, Pingle petcock, straight drag pipes, Progressive rear shocks, lowered Progressive springs front, GMA dual piston calipers, Sturgis billet wheels, Headwinds bullet headlight, AME 9 deg kit.
Old 12th July 2006
None in stock for 883 and I hate waiting.
Gazza
Old 12th July 2006
renpia's Avatar
I wonder if the SE for the 1200 would work on an 883.
Old 12th July 2006
It might, but I didn't know the difference nor did the parts manager. He said the folks out back in service (it's a different building because their remodelling big time) would know but I wasn't about to leave my only 883 module in the state behind on the counter to go ask them
Gazza
Old 16th May 2007
Jojo_Dogboy Jojo_Dogboy is offline
Sportster/Buell Model: 883 XLC
Jojo_Dogboy has disabled reputation
I read someware can't remember now where that the 1200 sport ignition module has a better advance curve. The is no difference on crane or daytona as to 1200 or 883 so I don't see why it wouldn't work. I ordered the Crane but the wiring harness dosent match up and need to make a deutch gender bender.
Old 16th May 2007
Hanoverfiste's Avatar
Hanoverfiste Hanoverfiste is offline
Other Motorcycle Model: Electraglide
Other Motorcycle Year: 1993
Hanoverfiste will become famous soon enoughHanoverfiste will become famous soon enoughHanoverfiste will become famous soon enoughHanoverfiste will become famous soon enoughHanoverfiste will become famous soon enoughHanoverfiste will become famous soon enough
Glad you nailed it!!, Im envious, I havent heard my bike run for over a year now!!
Walk your Path, let others walk theirs
Old 16th May 2007
NoBoZoS's Avatar
NoBoZoS NoBoZoS is offline
Sportster/Buell Model: XL 883 Custom
NoBoZoS will become famous soon enoughNoBoZoS will become famous soon enoughNoBoZoS will become famous soon enoughNoBoZoS will become famous soon enoughNoBoZoS will become famous soon enoughNoBoZoS will become famous soon enough
Hey
I have an 03 883 OEM ignition module take off if they're looking for one!
