Last Post: hhugger
0 Slip on muffler
Last Post: Tucsonmax1
0 1972 tank fitment
0 bike went for a slide
0 New England 2018
Last Post: The Crusher
0 90 in. Build
Last Post: Jheitt
0 Help me with gas cap...
0 Sportster or Street Bob
0 2016 48 Hesitating
Last Post: Screw Loose Dan
Last Post: dnaj11
Old 2nd October 2008
S. Weaver's Avatar
S. Weaver S. Weaver is offline
Location: Smithville, Pennsylvania - Milepost 21 on the Low Grade
Sportster/Buell Model: XL 883
S. Weaver is an unknown quantity at this point
Default PSI 3 Slide Carb for EVO applications
Has anybody seen one of these or heard how they work? Could this new carb work on a Sportster? The external adjustment and three slide technology sounds like something from general aviation - imagine a fuel mixture lever on your ride ...
Sorry, I'm too new to be allowed to post a link. Google PSI carbs ...
XLXR's Avatar
XLXR XLXR is online now
Very interesting. Buy two, send one to me, and I'll give you my opinion about it for free.
It may run better than the stock carb, but you still have to know how to tune a carb. You will still have the problem of the short Y intake manifold and fuel/air charge bouncing back and forth in the intake.
My other question is will it compensate for altitude changes as well as the CV carb does? I frequently ride from sea level to over 6,000 feet on the same day.
I just saw you had an 883. My guess would be to spend your money on a 1250 kit first, if they have the overheating and oil burning problem fixed.
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
1250.00 for a carb and you get 6 ponies. sign me up!
wandrur's Avatar
wandrur wandrur is online now
Thx for the help, jackass
Sportster/Buell Model: XL 883 > SE 1200
Sportster/Buell Model #2: 1200 XLH
Sportster/Buell Year #2: 1999
wandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond repute
For what, the Kool-Aid line??
Ireeman's Avatar
Asgardian
ah reverend you are enlightend also.
Lenster's Avatar
Lenster Lenster is offline
Lenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond repute
Here's my PSI on an '06 XL1200C.
I'd give more info right now, but I gotta get ready for work.
Lenster's 1250 2006 XL1250C, Hammer Crush Heads, 15 Degree Pistons, 10.5:1 CR, S&S Roller Rockers, Fixed Length Pushrods, Jim's Powerglide II Hydraulic Lifters, RedShift 585 Cams, Energy 1 Clutch w/ 15% Stronger Spring, Hammer Performance Billet Intake Manifold, Mikuni HSR 45 (25 Pilot, 157.5 Main, 96 Needle 2nd Clip from top, Y6 Needle Jet), Offset Crush AC, Cobra Power Pro HP 2:1 Exhaust and a Daytona Twin Tec TC88A with a Kickass Map by Rico 05R.
Old 3rd October 2008
S. Weaver's Avatar
Nice terms ...
I'm quite content with the 883 as it is. This carb appealed to me more as a gadget. Aviation and motorcycle technology have been cross-breeding for 100 years. It's interesting to see this latest spin-off ...
Lenster, when you have more time, tell us a tale about your PSI.
Lenster's Avatar
For Starters, see This Thread, This Thread, , This Thread and This Thread
nemosengineer@yahoo.com's Avatar
nemosengineer@yahoo.com nemosengineer@yahoo.com is offline
Sportster/Buell Model #2: Dyna Superglide Custom
Other Motorcycle Model: KTM LC4 600
Other Motorcycle Year: 1990
nemosengineer@yahoo.com is a jewel in the roughnemosengineer@yahoo.com is a jewel in the roughnemosengineer@yahoo.com is a jewel in the roughnemosengineer@yahoo.com is a jewel in the roughnemosengineer@yahoo.com is a jewel in the roughnemosengineer@yahoo.com is a jewel in the roughnemosengineer@yahoo.com is a jewel in the roughnemosengineer@yahoo.com is a jewel in the roughnemosengineer@yahoo.com is a jewel in the roughnemosengineer@yahoo.com is a jewel in the roughnemosengineer@yahoo.com is a jewel in the rough
Interesting... Can you give us an example of of this unholy cross-breeding of aviation and motorcycle technology that happened later than the introduction of the radial aircraft engine???
: Mike
"It is always better to be shot out of a cannon than to be squeezed out of a tube"
Lenster's Avatar
: Mike
Like this?
Or this?
