0 Engine dies when choke off
Last Post: 60weight
0 Help please...77 xlch oil line routing diagram image?
Last Post: 69sscamaro
0 Won't rev past 1200
Last Post: Aocasio
0 Oil use/smoking
0 Speedo cable lube
Last Post: a150bdriver
Last Post: Hank21113
Last Post: halfmt1
Last Post: Edster
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 Head gaskets.
Last Post: sltm1
0 newby from Australia
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
0 too bad
Last Post: robistro
Last Post: Crosshairs
0 seeking advices
0 Cream
Last Post: jakewalter
Old 4th October 2008
jcsportster's Avatar
jcsportster jcsportster is offline
Sportster/Buell Year: 1979
jcsportster is an unknown quantity at this point
Default tach drive
Got home the other day and found brown stuff run down and back on my cam cover. Its coming out of the tach drive. Looks and feels like rusty water. Doesnt really have an oily feel. I've ridden in the rain numerous times, but have had the cable disconnected and reconnected since then and there was no sign of water in cable. Tach works great. Is there a seal in the tach drive that could have gone and forced old rust up and out of the unit? Does this mean the unit needs replacing? Is there a way to clean it and relubricate it?
I do not know what is actually happening there. However the tach drive is quite simple. It can be removed, cleaned, inspected, re-installed without disturbing other parts. There should be a paper gasket between it and the case. I have recently seen a post here where a copper washer was used. I would think a white "plastic" [or whatever] washer would also do. Anything that will seal.
OK. Its got a gasket between it and the case. Couldnt really tell where it was leaking at, at the base or at the top where the cable ties into it. The whole drive was covered with the wet rusty looking stuff and it run down and back on the cover. But it still works, so..
