0 1977 Bright Blue
Last Post: Airarbiter
0 THE Trainspotting Thread
0 Brake Squeek
0 Won't rev past 1200
Last Post: Aocasio
0 Mikuni HSR42
Last Post: jammantoo
Last Post: Keep it running
0 Paulie420 needs your help.
Last Post: The Crusher
Last Post: RandyMac
0 Not charging issue!
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Last Post: felis
0 Where did it go?
Last Post: mwXL 2006
0 z bars
Last Post: Bryan83taco
0 2001 883 'customizing' log
Last Post: Jheitt
Old 24th February 2005
BonRu's Avatar
BonRu BonRu is offline
BonRu is an unknown quantity at this point
Default Help! Need adviced on bleeding brakes!
Anyone on line right now, we are changing out the front brake line, and are having trouble bleeding the brakes. It is being very stubborn. Any tricks? Anyone know why this is happening. We're doing it right now, so if you could respond now, that would be great!!! Laptop is standing by . . .
Thanks in advance!
xena's Avatar
xena xena is offline
Assistant Administrator
Do it just like in a car....pump the lever a bunch of times, hold it, crack the bleeder screw, repeat. It takes a LOT of pumping. You'll eventually get resistance in the lever but be patient. Make sure you keep fluid in the master cyl.
during the process.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams
Python 3 Slip ons
TC88A running Xena's Black Panther Map
My 1212 Conversion Thread
XL Forum Members Map
BonRu's Avatar
Thanks Xena. We were pumping and pumping, and nada, and so we thought we were doing something wrong. I guess we just gotta keep at it. Thanks so much for your quick response!
Gyahmers's Avatar
Gyahmers Gyahmers is offline
Other Motorcycle Model: 2007 Dyna Street Bob
Gyahmers is an unknown quantity at this point
Like xena said, pump and pump and pump and pump and pump and pump and pump and.................................. It takes what seems like forever, so pump and pump and pump, come on now keep pumping that hand lever.
Gyahmers's Avatar
I forgot this, and don't ask me why cuz I don't know, but it seems to help if you turn the ignition on to start while pumping.
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the rough
tickle it.....
look down thru the threads as this came up last week..
here's the link
http://www.xlforum.net/forums/showth...light=bleeding
BonRu's Avatar
Originally Posted by stevo
tickle it.....
Thanks Stevo; am looking through old threads now.
radar's Avatar
radar radar is offline
Other Motorcycle Model: Road King Classic
Other Motorcycle Year: 2007
radar is on a distinguished roadradar is on a distinguished roadradar is on a distinguished road
Default Brake Bleed
I just did this today with a new chrome and braided setup, it takes exactly 367,248 strokes on the lever to get pressure.
Just kidding, as said before, fill the res and pump until you have fluid coming out the bleeder on the caliper, close the bleeder and pump the lever, open the bleeder, pump some more, eventually it will build pressure and give you enough to properly bleed the system, then it goes real quick.
My Best
My Best to all,
Walt.
2005 XL1200C
Black, Chrome, and Taxed
2007 RK Classic
Suede Blue/Black, stock 'till I blow it up
BonRu's Avatar
My Best
Thanks Radar, that's helpful. That's exactly what we have done; changed out the old cable for the new chrome braided line. I've pumped it at least 278,546 times, and I thought maybe that was more than enough. I can see now, I need to do more. Thanks to everyone who responded. We are following your advice, and hopefully by morning we'll have some progress.
stevo's Avatar
Tickle the air out....
Turn the bars so that the handle end of the master cylinder is higher....sometimes ya need to loosen the master cyl and rotate it slightly...
pull the lever in slightly..what you are trying to achieve is opening the initial port in the cylinder......tickle the lever around this point and you'll see air comin back into the master cylinder...
Once you've got that bit worked out the tap the hose up the length of it with a small spanner to free the air that's sticking to the sides of the line.....
that's a master class ..... and works well...I do it on ALL systems that are giving me trouble......
ya still need to get the air out of the caliper and you need to bleed it normally for that..
Similar Threads
bleeding front brakes Gho Sportster Motorcycle Tires, Wheels, and Brakes 18 15th March 2006 23:52
Another bleeding nightmare Grizzly Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 11 12th June 2005 02:42
Brake bleeding, stupid question #5... engine Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 8 26th March 2005 02:59
GSXR 1000 brakes blueglide88 Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 1 19th March 2005 04:11
sportster brakes sucks? jiffylube Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 13 9th March 2005 02:25
