Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
Last Post: hscic
0 1972 tank fitment
0 primary chain temp.
Last Post: x1_guy
Last Post: Crash7557
Last Post: nakina
5 Transmission HELP!
Last Post: MatHormell
0 strange small wires attached to coil
0 90 in. Build
0 24633-77 Breather assembly
Old 22nd July 2006
Gone Gone is offline
Question Another Cam Question
I have an '06 XL-883 that will be getting the NRHS 1212 conversion and their new special headwork that allows use of flattop pistons this winter. What is the difference between the stock 883 cams and the stock 1200 "W" cams? Would there be any advantage to replacing the 883 cams with the "W" cams? Thanks.
Old 22nd July 2006
Calbo,
That kit is designed to use SE 536 cams as they have a very long duration that helps bleed off compression. You do not want to use flat tops with 883 heads and either of those stock cam. We have a special reverse dome piston designed for that. So unless you are getting the 536 cams do not use the flat tops.
Old 22nd July 2006
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Less than a dime's worth. You don't want either of those grinds with that flat top conversion package.
One of the things that makes that flat top conversion work so well is that the chamber relief work didn't touch the squish band. We still have the full squish band around the perimeter of the chamber.
But this necessarily leaves the CR a bit higher, because you're not touching the area that gives the greatest opportunity for adding chamber volume. We decided to put the 536's in rather than reduce the squish area, because the later intake close event of the 536's bleeds off some of the compression, and therefore makes the higher CR manageable and pump gas friendly.
Do that combo with "D" or "W" cams and you may create a pinger.
Click Here to Contact Me
Old 22nd July 2006
aswracing's Avatar
We cross posted, but we said the same thing
Old 22nd July 2006
Originally Posted by NRHS Sales
Calbo,
Thanks Dan, I tried to call yesterday but I guess I was either too late or y'all were too busy. Would there be any advantage to using the "W" cams with the reverse dome piston kit?
Old 22nd July 2006
aswracing's Avatar
You're talking about an awfully mild build, "W" cams with 10:1 under 883 heads with those small valves. The "W" cams are very narrow and close the intake early. More squeeze + more cam = more power. 10.5:1 with .536's works very well and is no harder to do.
Old 22nd July 2006
Question
Thanks, I appreciate the info - I was just trying to figure the best way to get the most bang-for-the-buck as I could get the "W" cams really cheap! Oh well, damn the bad luck LOL!
I'm curious what the difference in hp/trq was in the dyno test for the rvs dome 1212 kit vs the 1212 flattops with new special grind (Mile Campbell grind)?
Old 22nd July 2006
We never did a test between the 2. Sorry.
Old 22nd July 2006
Bummer! LOL!!! There's abt a doubling of price between the two so for me to justify the additional expense the performance difference would have to be pretty substantial! Care to "ballpark" it?
Old 23rd July 2006
sporty58's Avatar
sporty58 sporty58 is offline
Sportster/Buell Model #2: XLH QC99
Sportster/Buell Year #2: 1998
Other Motorcycle Model: Dyna
Other Motorcycle Year: 2009
sporty58 has disabled reputation
I am not going to stick a number to it but going from a 10:1 is setup with stock cams to a 10.5:1 setup with .536 cams is going to be some of the cheapest horsepower you can ever buy.
2005 - 1212 conversion, Stage III NRHS Heads, S$S .600 cams, Krome Werks slip ons, Twin Tec ignition, HSR45, Hurricane on DevonatorII
1998 - 99" homegrown conversion, Stage II NRHS Thunderstorm heads, Redshift .643 cams, Axtell castiron cylinders, S$S 4 5/16 crank, S&S G with thunderjet
** Gone** 2004 R1150R.... Just had to try one and the ride sucked so bad I sold it after one season... pretty bad when it is a worse ride than a solid mount sporty
