0 Feeling in trouble.
Last Post: sdsbassist
0 Value of a Boattail?
Last Post: Moon Wolf
0 spoke nipple tool?
0 Spring Seat Brackets?
0 Cylinder Piston kits
Last Post: SoonerSport
Last Post: valvebeater
Last Post: jcasella
0 Leaks
7 Long Road Trip advice
Last Post: gravydog
Last Post: seanq2208
0 Diagnostic help
Last Post: BradX13
Last Post: jordan1200
0 Stock 883 cold blooded
Last Post: Diogenes415
0 z bars
Last Post: 201648Rider
2 Humble pie
Last Post: Sprtstr1200s
Last Post: gravydog
0 New to Harley
0 79 ironhead
0 Back in Sporty Land
0 1967 XLCH stroker project
Old 26th February 2005
RoseLady RoseLady is offline
Sportster/Buell Model #2: 1000 CC
Sportster/Buell Year #2: 1977
Other Motorcycle Model: 1000 Sportster Hardtail
Other Motorcycle Year: 1968
RoseLady has disabled reputation
Unhappy Ironhead Coil Test???!!!??
Someone please tell me how to tell if my coil has gone bad on my 77 (piece of X?@#) sportster! I am about ready to send it to the landfil!
Thanks!
Info from Clymer manual:
disconnect coil secondary and primary wires before testing.
1. set ohmmeter to RX1. Measure coil primary resistance between both coil primary terminals. should be 4.7 to 5.7 ohms
2. set meter to RX100. measure coil secondary resistance between both high voltage terminals. should be 16,000 to 20,000 ohms
An alternative is to temporarily install a known good ig coil.
Strange...Coil on bike, with ignition on, volts are there on positive end of coil (top). Volts are also measureable from bottom terminal of coil when bike is attempting to fire (hitting starter button).
But, No fire from end of plug wires (with screwdriver installed and ground to plugs)....So could this still be a coil issue??
PS... Dyna-S ignition installed. Not running points.
74FeHeadXLH 74FeHeadXLH is offline
Sportster/Buell Model: 1974 XLH
Sportster/Buell Year: 74
74FeHeadXLH has disabled reputation
yea but to actually test the coil...take off the wires from the screws on the side and unplug the two plug wires...then measure the resistance of the coil which is useing the battery power of the ohmeter/multimeter you are using. The primary measurement is the two screws on the side of the coil (Mick listed the range it should read if good), the socondary is your two plug wires. Bike ignition needs to be off and wires unhooked to take these readings
1974 XLH 1000, DRAG PIPES, S & S "E", AND
Thanks...I was wandering how to tell what the primary from the secondary. I have a service manual somewhere?>?
I'm not sure if this is a sign/symptom of the coil going/gone out but...
I was riding and the bike was running really bad. Then it just died! Won't start. No fire to the plugs. I'm glad I have an 04 1200C as a primary ride.
This 1977 is pretty (corvett yellow, fat bob tank, fat bob fender, ect) but, it is truly a piece of #@*?
I go through those phases of calling my 74xlh a POS too, then I get it fixed and all's well again, mines also converted from points to electronic, and the first part I had to replace after I had it about a month was the coil, but at the same time I also noticed most of the wiring connectios were corroded and rusty and needed to be cleaned up as well, and the plug wires were old and tired, so it could be a combination of smaller probs causing it for ya
Did your coil go out?
I think my Dyna-S needs 5 ohm coil. Which is what I THINK is on the bike. My thought is if the Dyna-S needs a 5 and I have a 4.5 or a 3 on the bike this may be my trouble. Maybe the coil did what it could and now it has had all it can take. I put the Dyna on about 750-1000 miles ago.
Do you think this problem could have anything to do with the Dyna?!? I hope not!$!
I want to do a complete "tune-up" on the sporty but the 1972 Shovelhead (basket case) I just bought is screaming for parts! Just have to decide which bike to pay the "tax" on first.
I will take my "notes" on testing the coil out to the shop in the morning and see what I can see!
yea a wrong ohm coil will work....for a little while then fry...doubtful it hurt your ingnition
Will the "primary resistance test" that Mick described and you explained tell me what ohm coil is on the bike?
yea the primary resistance is the one that'll tell ya
Similar Threads
1973 Ironhead Sportster runnin' early mag? t-bonewilliams Sportster Motorcycle General Discussion and Problems 12 20th February 2011 01:17
single fire coil Gone Sportster Motorcycle Motor - Top End 10 30th April 2005 02:30
Generator Output Test IronMick Ironhead Sportster Motorcycle Talk (1957-1985) 9 3rd April 2005 14:54
Help...Coil Relocation and Wiring divisi Sportster Motorcycle Motor - Top End 2 19th February 2005 20:47
ironhead benny04hd Sportster Motorcycle Motor - Top End 1 12th February 2005 13:52
