0 1974 Ironhead
0 24633-77 Breather assembly
0 Ei
Last Post: Serious Blac
0 New from Utah
0 Post season carnage
0 De-lowing a Superlow with Progressive Monotubes?
Last Post: FuriousGeorg
0 Exhaust Clamp Fitting
Last Post: Yochstein
Last Post: norseXL
0 Rubber mount Oil tank Vent line Routing
0 Need help on bolt size - 92 XL1200, mid pegs
Last Post: r4fthrs
0 Reflectors...Yeah, or Neh
Last Post: 60weight
0 1250 Conversion troubles
Old 21st October 2008
Gone Gone is offline
Default rubbermount in a rigid frame
Here the question, can a rubbermount 1200, be used in a rigid EVO 1200 frame? Does anyone know if HD changed the casing and the frame or just the frames for the rubbermounts?
Thanks in advance....
gearhead1972's Avatar
gearhead1972 gearhead1972 is offline
Sportster/Buell Model: XLH 883/1250
gearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura about
The frame is a little bigger to accommodate the rubber mounting points, At least to my eye viewing Elissa's and mine side by side. Cases are different at least with the trap doors and the primary covers, as for the spacing of motor mounts I am not sure.
03 Vivid Black 883/1250, with 04 1200r/XB heads, Andrews N4 cams, Hurricane push rods.040 shorter than stock. Dyna 2000i ignition, Screaming Eagle ignition coil and wires. V&H Straight Shots, Generic tear drop with 3in wide K&N filter, 48 slow, 175 main, NOKH needle shimmed .043. Progressive front springs, 412 rear shocks. ♠ 79.5 HP, 77.96 TQ ♠ ~Kevin~
Both are pretty damn different...
Fe Head Fe Head is offline
Sportster/Buell Year: 1979
Same as "Kev M " except + {10 X10} = 100 % different in both:
a) the frame with all new motor mounts, its dog bone attachments as well as
b) the huge cast-in rings on the front and rear of the crankcases.
It would be easier to fit an Evo engine into a rubbermount frame than "vice versa" but not necessarily by much IMO.
However, I am quite confident that someday, someone, somewhere will do exactly what may seem impracticable just to prove a point.
Cheers;
LOL - I was just walking the line of the fact that they are both the same basic design. 45 degree V twin, 4-camshaft, shared crankpin EVO sportster motor in a dual-cradle frame.
But yeah, what FE said.
The motor casing on the solidmount acts as a stressed member, reinforcing the less bulky frame for a nice rigid chassis. When they rubbermounted the motor they had to increase the frame size/bulk (weight) in order to get back that rigidity (they claim the new frame is stiffer by some large percentage, though it's not clear if that's double-talk for it had to be that much stiffer for the chassis to essentially have the same stability if you know what I mean).
Anyway, they are about as similar in character as two very different bikes can be.
Old 22nd October 2008
Thanks guys, I figured as much........Knew I get the skinny here.
XLXR's Avatar
XLXR XLXR is offline
Not only are the engine mounts different, but the swing arm mounts are very different also.
