Last Post: jammantoo
0 What is this?? 07 efi 1200 weird box
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Diagnostic help
0 Tool Roll Help
Last Post: hexnut
Last Post: hexnut
Last Post: Matt397
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
Last Post: jordan1200
0 05 and 73
0 Brake light stays on
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
Old 6th August 2006
wadel's Avatar
wadel wadel is offline
Sportster/Buell Model #2: XB12XT
Sportster/Buell Year #2: 2008
Other Motorcycle Model: 1970 Honda CB350
wadel is on a distinguished roadwadel is on a distinguished roadwadel is on a distinguished road
Default Rear Fender is dented from seat
I just got back from a 3000 mile ride and my bike looked like crap with 3000 miles of road grime, dirt and rain. I rode with my Mustang Vintage Solo along with the passenger pillon. While I didn't have a passenger, I put a bag (probably about 25 lbs) on the back seat to act as a back rest (worked great). When I took the pillon and seat off to clean the bike, I noticed the middle mounting hole is slanted back towards the taillight with the fender bending along with it. This is the hole where the screw for the front seat goes, along with the spacer for the front of the pillon to mount. Has anyone else had this mounting hole bend backwards? Am I doing something wrong and will it continue to get worse?
I normally ride with the solo seat only. I only weigh 180 so it's not an unusual amount of weight on the seat.
When it rains, I pour it on.
Old 6th August 2006
Jimbo999's Avatar
Jimbo999 Jimbo999 is offline
Riding with Angels
Sportster/Buell Model: Sportster XLH 883
Sportster/Buell Year: 1988
Jimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the rough
I'm going to be watching this thread.........Interesting problem.
Try n' catch the wind
Stage 1
Taxes Paid
Blue Loctite is your Friend
Old 6th August 2006
merc merc is offline
Sportster/Buell Model: Custom
Other Motorcycle Model: Suzuki GN400
Other Motorcycle Year: 1980
merc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant future
wow-that does not sound like it should happen.
I amreally liking that Mustang solo but am interested in what others say.
I also like the Leprera seats with the optional stitching like flames.
I hope your fender issues can be ironed out.
Old 6th August 2006
skratch's Avatar
skratch skratch is offline
skratch has disabled reputation
i've not heard of this happening before either. how about a couple of pics so we can see how bad it is.
If he runs, he's a terrorist. If he doesn't, he's a well disciplined terrorist.
Old 6th August 2006
Krayven Sumhead Krayven Sumhead is offline
Sportster/Buell Model: XL1200C (Heywood)
Sportster/Buell Year: '05
Other Motorcycle Model: Ultra (T-Bagger)
Other Motorcycle Year: '03
Krayven Sumhead has disabled reputation
I've got the same seat with at least 10,000 miles on it........ When you attach the passenger pillion, are you sure you captured the 't' nut with the pillion bracket or maybe it was sitting on top of the 't' nut, pushing it down and back???????
The only thing my Mustang seat has done to my bike is the rubber bumpers on the passenger pillion left mars on my rear fender. I usually leave the pillion at home.
Old 7th August 2006
wadel's Avatar
Krayven: Good thought but I'm fairly certain the pillon bracket was in the spacer as it should be. There is one thing I forgot: My solo seat was sitting on the yoke of my throw-over saddlebags which changes the angle of the solo seat mounting point a bit.
Here is a picture that shows how it is dented down toward the rear and pulled up toward the front (my photo skills leave a lot to be desired):
Old 7th August 2006
skratch's Avatar
hmm, it almost looks like your screw was too loose (in the seat mount ) so it was acting as a lever to push the retaining nut down. maybe the thickness of the leather on the yoke of the saddlebags? thinking about it, that could be it, there was a gap between the mounting tab and the top of the retaining nut when you installed it, but your body weight caused the seat pan to flex, thereby putting a lot more stress on the retaining nut.
just a guess on my part, i've never seen that before.
if it were me, i would take my back tire off, tap the dent back flush, and then not use the throwover bags like that again.
Old 7th August 2006
flynhi4u flynhi4u is offline
Sportster/Buell Year: 1986
flynhi4u will become famous soon enoughflynhi4u will become famous soon enoughflynhi4u will become famous soon enoughflynhi4u will become famous soon enoughflynhi4u will become famous soon enoughflynhi4u will become famous soon enoughflynhi4u will become famous soon enoughflynhi4u will become famous soon enough
Just finished painting my '86 and it was bent when I took it apart, never noticed it prior to working on the fender. I fixed it and had it all nice and straight. Painted and reassembled. within a week it was bent again, just a little, using the factory solo seat. I went back to my Corbin Gunfighter, for different reasons so now I don't care but I understand your problem.
Sam in IN
'86 883/1240
Old 7th August 2006
Moved On Moved On is offline
Why doe it look like the top of that tee nut is no longer smooth?
Gazza
Old 7th August 2006
wadel's Avatar
Nope, no loose screws (on the bike at least ). I've used the saddlebags on a couple trips before, even with a lot more weight on the pillon (don't tell the wife I said that). But, I think the saddlebags might be the cause. Without them, it is very easy to get the solo seat on but with the saddlebags it takes a bit of muscle to get everything to line up.
I think I'll just keep an eye on it and hope it doesn't get worse. My attempts at bodywork have never turned out right so I won't try to correct this.
