0 New to me 55kh
0 Nup 1009 (Bearing)
Last Post: dave76
0 S&S Super E Carb
Last Post: jp2code
Last Post: mikethebike61
0 so it's officially ended
0 AGM battery for 76' XLH
Last Post: forqueue
Last Post: Clevspeed
Last Post: ReddTigger
Last Post: Nitro57xl
Last Post: Cablejudge
0 Sportster book
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: Nicktater
0 What jets do you use?
Last Post: Thack
5 Red Shift cams similar to Jackhammer 570 ?
0 My 08' Nightster
Last Post: XL1275
Old 1st November 2008
Krypto Krypto is offline
Banned
Sportster/Buell Model: 1200N
Sportster/Buell Year: 08
Sportster/Buell Model #2: XL 1000
Sportster/Buell Year #2: 1979
Krypto is a splendid one to beholdKrypto is a splendid one to beholdKrypto is a splendid one to beholdKrypto is a splendid one to beholdKrypto is a splendid one to beholdKrypto is a splendid one to beholdKrypto is a splendid one to beholdKrypto is a splendid one to beholdKrypto is a splendid one to beholdKrypto is a splendid one to beholdKrypto is a splendid one to behold
Default Springer Project Phase II
She's back on the rack, In for part 2 of Nightster surgery! I picked out a seat and figured out what to do about the ECM & Power Commander units. I also upon some prodding from the ladies, decided to put some passenger pegs on too. Now that I removed the ECM bucket from the fender, there is space to add weight without worrying about grinding the bottom of the bucket off with the tire.
Here's pic's of what has been done so far.....
We made a bracket to get this La Rosa seat to fit to the frame, and fashoned a pan to fit the space below it.
A bracket welded to the battery strap holds the Power Commander where we can get to it easy for adjustments if needed. (it's upside down due to wire routing). I fastened it to the bracket with some pretty strong 2 sided tape.
The PCIII connector is located in front of the rear wheel against the frame in a protective box made to fit and a strap to hold it in place.
The ECM Is fitted in a metal container painted with rhino coating and is bolted under the front of the swingarm. There are through bolts that hold it in through the holes in the corner of the ECM. I am going to seal it in with black fire-stop patch to keep it watertight.
All the plastic was removed from under the rear fender, the hole was welded gone, and I removed just enough so the fender lined up with the support brace.
Footpeg brackets that will lift them above the Cherry Bomb.
Yet to be finished, the rear shocks which are progressive 412 covered black with bullit top covers, and speedo relocation, I found a rocker box bracket that I have on the way. also several more shiny parts that I want Black...
daggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to all
looks realy good man, did you just drill and tap some holes in yr swingarm for those passenger foot peg brackets?
the seat looks killer, what size are the springs? that lip on the back of it looks like you could still pull pritty hard off the line without worrying about flyin off, that is one thing i hate about my seat.
mullemeck's Avatar
mullemeck mullemeck is offline
Sportster/Buell Model: xl1200
Sportster/Buell Year: -93
mullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nicemullemeck is just really nice
the seat looks really good on the bike and fits nice with the springer!
It will be fun to chop this one
nightsterRyder's Avatar
nightsterRyder nightsterRyder is offline
Sportster/Buell Year: 07
nightsterRyder is an unknown quantity at this point
The seat is beautiful. Where did you get that?
'07 HD Nightster
SE Stage 1 Kit
Vance and Hines Slants (Black)
vtdrugs's Avatar
vtdrugs vtdrugs is offline
Sportster/Buell Model #2: ironhead
Sportster/Buell Year #2: 74
Other Motorcycle Model: Suzuki GSXR600
vtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura about
nice set up...but words to the wise....those ecm connectors are not water friendly! I had a similar set up going, until my bike started running like crap. took it to the stealer and they said water just ran outta the plugs going into the ecm. since then i dropped the pcIII and went with a sert w/ dyno tune. a little more pricey, but less hardware and a piece of mind that next time i ride in the rain, my bike won't f up.
2008 XL1200N....work in progress
1974 XLCH....another work in progress
CTFS
I hate deer!
Banned
I considered this dilemma prior to design. all components are in containers that I will be sealing with a 3M waterproofing product that we use for high voltage splicing. It comes in pads about the size of an index card. It's black & stretches around the splices then adheres to itself and conforms to the wiring and seals out moisture. They use a simular product for sealing the A/C tubing as it penetrates the firewall of your car. Also due to fenderless design, I don't anticipate doing much riding in the rain. My bike to me is like a roller coaster, It's a blast to ride, takes my mind off of all that is unworthy! however, I wouldn't consider riding a roller coaster in the rain, kinda sucks the fun right out of it...
gearhead1972's Avatar
gearhead1972 gearhead1972 is offline
Sportster/Buell Model: XLH 883/1250
gearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura about
Very nice work, I would have to say your sportster is one of my favorites on this forum.
03 Vivid Black 883/1250, with 04 1200r/XB heads, Andrews N4 cams, Hurricane push rods.040 shorter than stock. Dyna 2000i ignition, Screaming Eagle ignition coil and wires. V&H Straight Shots, Generic tear drop with 3in wide K&N filter, 48 slow, 175 main, NOKH needle shimmed .043. Progressive front springs, 412 rear shocks. ♠ 79.5 HP, 77.96 TQ ♠ ~Kevin~
Riding with Angels
Thumbs up
looks very nice. i had my ecm in the same place but moved it because of water. i thought like you about sealing it up. but i am afraid with heating and cooling condensation wil get it . all computers heat up and in an airtight space when it cools stnds to reason you will get condensation. but who knows someones got to try it. your bike looks great. i like the brown seat and the footpeg mounts. very nice job keep those pics coming.
LIFE IS SHORT PRAY HARD!!!!
snowman's Avatar
snowman snowman is offline
Nice job!!! Very well thought out...
Always liked the LaRosa seats...
Looking forward to seeing the cherry bomb on the exhaust!
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Old 4th November 2008
Riding with Angels
Default ecm and power commander
heres the pic
