0 2016 48 Hesitating
Last Post: Screw Loose Dan
0 Ei
0 24633-77 Breather assembly
0 Newbie CV rebuild
Last Post: Matt Black
0 ‘68 XLCH...transmission
Last Post: Larry May
Last Post: Yochstein
Last Post: Jheitt
0 Salutations y'all
0 New member in MD
0 New from Utah
0 New England 2018
Old 28th February 2005
Question Nitrogen in Your Tires ?
I picked this post at another forum. Have not heard this one before. What do ya think?
Read a article about 6 weeks ago on the benefits of nitrogen in your tires verus oxygen written by a man with a PHD. Unlike oxygen nitrogen has no moisture and it leaks out thru rubber much slower.
But the number one reason is it runs cooler and disperses heat better than oxygen thus extending tire life. 300 Costco stores across the usa now fill your new tires that you buy from them with nitrogen. Nascar uses nitrogen and all major airlines fill their tires in their airplanes with nitrogen. So I only took a short ride and did not notice any differences but I think I will see better tire life.
Moved On Moved On is offline
Ummm....
It would be kinda odd for anyone to put oxygen in their tires. I usually put air in my tires, air is 78% nitrogen, 21% oxygen, the last 1% is other gases. Clicky Here
Nitrogen molecules are bigger than oxygen, so sure it will leak slower through the rubber. Both gases will leak pretty good through a nail hole.
Helium would be pretty bad. It will leak through almost anything. I used to work for a company that made helium leak detectors. If you held the probe on your wrist and took a deep breadth of helium, about 5 seconds later the sensor would go off, because the helium was leaking out of your body right through your skin
Gazza
gilx's Avatar
gilx gilx is offline
gilx is an unknown quantity at this point
Originally Posted by Gary
...Nitrogen molecules are bigger than oxygen, so sure it will leak slower through the rubber. Both gases will leak pretty good through a nail hole...
Here in Utah along the Wasatch front we get "inversion layers" in the winter time. A big high pressure area gets stuck over top of us preventing the smog from blowng away. After a couple weeks I swear the smog buildup makes the air half hydrocarbon. This is when I fill my tires...enough complex molecule in there not only does it not leak out, it becomes self-sealing .
--gilx
2004, 1200 Custom, taxes paid
"'Tis better to be silent and be thought a fool, than to speak and
remove all doubt." -- Mark Twain
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the rough
n
A full Nitrogen fill has some benefits but I doubt many people would be able to pick any difference on the street....
who actually bothers to check tire pressures at LEAST once a week????????????
Correct pressure will make the tires last longer too....
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant future
300 Costco stores across the usa now fill your new tires that you buy from them with nitrogen. .
So how do they suck out the air that's already in the tire before they put the nitrogen in??? Otherwise you'll still have oxygen in there.........
Ed
Ed
The Only Y2K dual-set 883C
So Cal
ted's Avatar
ted ted is offline
Senior Master Bike Builder
Sportster/Buell Model: 883-1380cc hot rod
Sportster/Buell Year: 87
Sportster/Buell Model #2: wife's 883-1200
Sportster/Buell Year #2: 87
ted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to behold
I used nitrogen when I was racing, tires and air shifter. Mostly for the air shifter. No moisture means the air shift parts stay clean way longer. For the tires it was the convenience of having the nitrogen bottle handy on the bike trailer. Nascar, Indy car, airplane use is for other reasons. Fast race cars heat tires up pretty good and air expands. Pressure is critical in race cars. When using nitrogen the pressure stays pretty constant regardless of tire heat. For street use, air is cheaper and just as effective.
Ted
Still crazy after all these years.
Late 87-883 Hugger/1380cc (84") conversion. Too many cool parts to list. Built engine on a fresh set of cases, so conversion might not really describe it. Estimated near 115 hp.
Early 87-883/1200 conversion. Wife's bike. SE heads, 1200 flat pistons, 40" Drag Pipes, everything else stock.
"Wise men speak because they have something to say; Fools because they have to say something."
Plato
bubbahog's Avatar
bubbahog bubbahog is offline
bubbahog is an unknown quantity at this point
Nitrogen would also be good if you were planning on riding in very low temperatures - like -20F.
I'll stick with the free stuff from the gas station for now.
flathead45's Avatar
Sportster/Buell Year: 86
Other Motorcycle Year: 1945
how about hydrogen?
that would make for a killer burnout
"lord of the Night Lite"
thank god for darwin ;)
stevo's Avatar
that'd be the "Big bang" theory......
flathead45's Avatar
I doub thee "the hindenberg"
Similar Threads
Need new tires this year, Metzler or HD? klamen Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 29 22nd February 2005 01:30
Whitewall tires? CuL8R Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 8 6th February 2005 02:54
Tires and winter... XLFREAK Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 8 22nd December 2004 14:14
low profile tires seajay Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 1 8th December 2004 14:47
which tires? engine Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 21 23rd November 2004 23:08
