Last Post: David L.
Last Post: Naplesron
Last Post: Grumpy-Biker
0 Lowboy frame conversion
0 Primary Oil INSANITY!
Last Post: randy3934
0 Left Side Exhaust?
Last Post: maltesefalcon
Last Post: blindfredy
Old 8th August 2006
Sportster Girl's Avatar
Sportster Girl Sportster Girl is offline
Sportster Girl has disabled reputation
Default E-Z Fill Fork Caps
Ok, when I replace my fork springs I want to replace the fork caps with the ones that allow you to re-fill with oil without pulling the entire cap off.
http://www.jpcycles.com/productdetail.aspx?PID=230-343
Can anyone tell me why this 39mm kit only fits XL's from 88-03? Did they change the caps/fork tubes so these won't fit on post '03's?
Or, does someone have info on caps like these that will fit '04 or later XL's?
Old 8th August 2006
pirate50's Avatar
pirate50 pirate50 is offline
Sportster/Buell Model #2: Softail Standard
pirate50 is a jewel in the roughpirate50 is a jewel in the roughpirate50 is a jewel in the roughpirate50 is a jewel in the roughpirate50 is a jewel in the roughpirate50 is a jewel in the roughpirate50 is a jewel in the roughpirate50 is a jewel in the roughpirate50 is a jewel in the roughpirate50 is a jewel in the roughpirate50 is a jewel in the rough
Sporty,
Follow the link that you posted and look under the updated 2006 catalogue. It shows that it fits Sportsters up to 2006.
Pirate
Old 8th August 2006
geekrider geekrider is offline
Sportster/Buell Model: 883C
geekrider will become famous soon enoughgeekrider will become famous soon enoughgeekrider will become famous soon enoughgeekrider will become famous soon enoughgeekrider will become famous soon enoughgeekrider will become famous soon enough
Originally Posted by pirate50
Sporty,
Actually it looks like it specifically mentions only fitting BT's up to 2006.
Its a good question - what changed in forks for the rubber mounts?
Old 9th August 2006
grizz420's Avatar
grizz420 grizz420 is offline
Sportster/Buell Model: 05 1200R
Other Motorcycle Model: V star classic wife's
grizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the rough
Smile nothing changed
if you look in the harley catalog there thr same part #
05 1200R Forcewinder XR air filter, Mikuni HSR 42,Super Trapp 2-1 pipe,TC88a ign., head light visor, chin spoiler, sport front fender, solo seat off 883, 12 and 1/2 inch dual rate Works shocks , dual rate Works fork springs
Old 9th August 2006
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
SG, you shouldn't have any problem fitting those caps to your bike.
39mm is the same on either 03-06, 39 mm is just the width of the trees versus 41mm used on BT's.
RTFS
Ride That F'N Sportster!!
Old 9th August 2006
Thanks! Couldn't figure out why they wouldn't fit.....
