Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Lubrication and Lubricants
Lubrication and Lubricants You guessed. Here is where everyone can argue over oil.
0 FNG from OKC
Last Post: Lukidj
0 New in NM
0 Tried to buy a new helmet
Last Post: kap
Last Post: _Outlaw
0 Screw Loose's Repairs
Last Post: Screw Loose Dan
0 Tank swap
Last Post: Grymy
0 Lowboy frame conversion
Last Post: spacecoast
0 Primary Oil INSANITY!
0 What jets do you use?
Last Post: David L.
Last Post: David L.
Old 21st August 2006
guamXL
Guest
Posts: n/a
Default foamy oil help
I have a 2006 XL1200R and after riding for about 1 hour I checked the oil and all I got on the stick was foam.
jms969's Avatar
jms969 jms969 is offline
jms969 has disabled reputation
1. What oil are you using?
2. Are you using an additive?
3. How many miles since your last oil change?
4. How much oil did you put in on your last oil change?
5. Does oil register on the dipstick when the engine is cool?
Might want to park the bike until you are certain that you are properly lubricating the engine...
JMS
thatbikerguy's Avatar
thatbikerguy thatbikerguy is offline
Other Motorcycle Model: Suzuki GS 750 L
Other Motorcycle Year: 81
thatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud of
I agree!!!
expect the unexpected
2003 1200 XLC Sterling Silver/ Vivid Black
Moved On Moved On is offline
How much foam did you get? Some foam on the top is normal, if you don't have any foam then it's time to really start to worry.
Gazza
Sportster1200's Avatar
Sportster1200 Sportster1200 is offline
Sportster/Buell Model: 883/1200 Real School Chop
Other Motorcycle Model: Honda CBR600
Other Motorcycle Year: 89
Sportster1200 is a jewel in the roughSportster1200 is a jewel in the roughSportster1200 is a jewel in the roughSportster1200 is a jewel in the roughSportster1200 is a jewel in the roughSportster1200 is a jewel in the roughSportster1200 is a jewel in the roughSportster1200 is a jewel in the roughSportster1200 is a jewel in the roughSportster1200 is a jewel in the roughSportster1200 is a jewel in the rough
If you just changed the oil you may have some air trapped in your lines.
Kong
Sportster - Kicking Big Twin Ass Since 1957
jms969's Avatar
Kong
See my questions 4 and 5 above...
Old 22nd August 2006
jms969's Avatar
So GuamXL... What did you find?
