V.o.e.s
14th November 2008
Posts: 28 Sportster/Buell Model: xl 883 Sportster/Buell Year: 2005
Fuel Reserve?
I've got an 05 883 and i have run out of gas twice. there's no fuel light on my bike, it's got the little knob that i turn to reserve. however, when i ran out of gas and turned it to reserve i got nothing. so the next time i rode i turned it to reserve and after a while of driving my bike started sputtering and died like it was out of gas and when i turned it to "ON" it started up again? anybody know why my reserve isn't working?
14th November 2008
Posts: 2,512 Sportster/Buell Model: 883c Sportster/Buell Year: 2004 Sportster/Buell Model #2: Flyrite Rigid completed? Sportster/Buell Year #2: 2003
Sure you turned it the right way?
Is it on res all the time?
If not the petcock has a screen on the end that may have came off. The screen regulates the level at which the the fuel is at reserve.
14th November 2008
Yup - also, when you ran out, how much gas did you put in?
If I remember correctly we'd normally put about 2.5 gallons or so in once it hit reserve (at about 100-120 miles).
If we ran it ALL The way down ON reserve it would take more like 3.1-3.2 gallons (and be closer to 140-150 miles).
14th November 2008
Brass Nut
Posts: 46,958 Sportster/Buell Model: XL1200CB Sportster/Buell Year: 2015 Other Motorcycle Model: CRF250L Other Motorcycle Year: 2017
There was a recall (or a tech bulletin or something) for some bikes (early '05?) which had the petcock marked the wrong way between 'on' and 'reserve'.
Folkie
South East England Riders
14th November 2008
I think I heard something like that too.
14th November 2008
Brass Nut
I'll have a look when I get home; I may have a copy of it.
14th November 2008
Posts: 1,069 Sportster/Buell Model: 1250 Sportster/Buell Year: 1995 Sportster/Buell Model #2: 1350 S+S Sportster/Buell Year #2: 1995 Other Motorcycle Model: Screaming Eagle Ultra Other Motorcycle Year: 2006
Easy thing to check. Pull your fuel line off and see when gas comes out. But, the screen has nuttin to do with reserve. There are different height feed tubes for main and reserve.
Larry
When in doubt, gas it...
Ol' Chief Larry of the Dirty Ducks MC
14th November 2008
Posts: 1,643 Sportster/Buell Model: XL1200R 'Ms Lily' Sportster/Buell Year: 2004
All the below applies to the 04 1200 Roadster.
If I remember correctly (at my age, it's getting questionable) the petcock has three positions: ON, OFF, RES.
Assuming you are using all three positions, then there is something wrong with the petcock. If you are mechanically inclined, the next time you get 80+ miles on the tank, take it off, tilt it on the right side, and carefully remove the petcock. (Listen for noise that indicates parts falling off.) Inspect for damage.
Below are pix of the petcock in various stages of disassembly:
Filter still on
Filter loose
Filter off - showing where tube sits in petcock
It's kind of hard to see in the pix, but there are 2 holes. One (to the right in this pix) gets the tube shown coming out of the bottom of the filter. The other hole is for reserve. I just checked and the filter does not fit backwards.
So, check it (or have the dealer/favorite indy check) for a filter that may have come loose or off. Else you have some other issue. (While I was getting this together, the post about the recall comes in... well, it wasn't something I repeated this time.  )
Carl
Which way to the egret!
Reason: add info/comment
14th November 2008
Brass Nut
Larry
That's only going to work if the fuel's down to the reserve level. And only with a vacuum applied.
14th November 2008
Posts: 7,427 Sportster/Buell Model: Sportster 1200C Sportster/Buell Year: 06
And you do know that the short end of the handle is the pointer right?
Look at the pics above and make sure your going the right directions !
