Last Post: rickmodee
0 1967 XLCH stroker project
0 79-83 dual disc fork spring length
Last Post: Reverend G
0 New to Harley
0 Check engine light, again
Last Post: lazyb8s
Last Post: T^2
Last Post: Smerch
0 Curious as to what I actually have
Last Post: JakRabbit
0 Not charging issue!
Last Post: r4fthrs
0 Running Rich
0 Head gaskets.
Last Post: Sadsack
0 spoke nipple tool?
Last Post: Bayou.Ogre
Last Post: jammantoo
Last Post: robbie202
0 1977 Bright Blue
Last Post: Larry May
0 Stock 883 cold blooded
Last Post: seagullplayer
Last Post: jordan1200
0 rpm jump pulling in clutch
0 Value of a Boattail?
Last Post: valvebeater
0 '89 Sportster 1200 Chopper
0 Bikes and Bells and Bears
0 Engine dies when choke off
Old 14th November 2008
tat2d2dope's Avatar
tat2d2dope tat2d2dope is offline
Other Motorcycle Model: Shovelhead
Other Motorcycle Year: 1976
tat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura about
Default so who has done a top end
i'm fixing to do a top end job
i'm looking at wiesco or KB pistons
my question is do the wrist pins have the brass bushings like shovelheads
and do they have to be pressed in and then cut to fit the wrist pin.
1973 iron head sportster fully customized the stock frame
SOLD for 76 shovelhead and $5000
Old 15th November 2008
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
Only bushing is in the con rod small end, pistons are sized to fit the wrist pins, which are included in the piston kits. Wrist pins are full floating type that you oil and slip into place, after fitting one keeper so you know how far to go. Install the other keeper and you're ready to run. No cutting of any kind is necessary, at least not on the Wiseco 10:1 forged pistons I have.
Eric
