Last Post: Hank21113
0 Won't rev past 1200
Last Post: Aocasio
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
Last Post: jordan1200
0 too bad
0 Head gaskets.
Last Post: ezmerf
Last Post: robistro
Last Post: felis
0 newby from Australia
Last Post: Veeflys
Last Post: Crosshairs
0 seeking advices
0 Dynatek DC6-5 coil
0 Cream
Last Post: jakewalter
Last Post: seajay
Last Post: seajay
Last Post: JKKO
0 H4 bulb
Last Post: andy_t
Last Post: cazz1000
0 Speedo cable lube
Last Post: JacksBrother
0 Oil use/smoking
Last Post: gpydeski
Old 25th November 2004
sportymark's Avatar
sportymark sportymark is offline
Other Motorcycle Model: Yamaha XJR1300
sportymark is an unknown quantity at this point
Default Power Output
For those of you interested in thse things, I finally had my 04 1200 Roadster dyno'd today. The results were: 80.5 BHP and 73.9 FT torque. This is with the following "bolt in" mods: SE Mufflers (80424-04), SE Air Cleaner (29042-04), SE Mikuni Flat-Slide Carb (27454-01), SE Ignition Module (31785-04) and SE Cam Kit (25197-04). The sad thing is I was pleased with this result, bearing in mind I was looking at around 147 BHP for my Honda Blackbird last year! The interesting thing on the dyno was the way the speedometer (and dyno) read at around 140mph at max power, I don't know if I could get near that on the road as the handling is too scary around 120!
1200RSC - Roadster Sport Custom (Roadster Base, Sport suspension, SE Stage 2 engine and Custom bodywork)
"This man is depriving a village somewhere of an idiot"!
aka_Matt's Avatar
aka_Matt aka_Matt is offline
Sportster/Buell Year: '04
aka_Matt is on a distinguished roadaka_Matt is on a distinguished roadaka_Matt is on a distinguished road
at what RPM's? can u post the graph? how much did u lose down low with those huge cams?
'04 HD XL1200C... Blue/Orange flames, Bobtail rear fender, Custom front fender, 6 spoke front wheel, Chrome everything... Rinehart 2-1, Mid-Controls, Deuce Wheel w/ 160/70x17, Ness BS, 74hp/85tq... FOR SALE
barry1967's Avatar
barry1967 barry1967 is offline
Other Motorcycle Model: 2005 FXD Chopper Blue
barry1967 is an unknown quantity at this point
My 04 with just SE ac kit, D&D slip-ons and a jetted carb made 74.51Hp at 6K and 77.04ftlbs at 4300. I would guess that would be pretty standard for most 1200's give or take 1 or 2 hp/tq either way depending on pipes. It looks like he lost about 3ft lbs with the SE .551's. Just my 2 cents if it's worth anything.
Stage 1
Metz 880s
V&H pipe
95 inch and more very soon.
Old 26th November 2004
gwcrim's Avatar
gwcrim gwcrim is offline
Sportster/Buell Model: 1200 Sport
Sportster/Buell Model #2: Cafe el Roadkill
Sportster/Buell Year #2: 199?
Other Motorcycle Model: KX520
Other Motorcycle Year: 1989
gwcrim has disabled reputation
Those numbers are surprisingly low. My 1200 Sport with N8 cams made 78 HP. I wonder what a different exhaust might net.
140 on the dyno doesnt' take wind drag into effect. None the less, I've had my 1200 Sport to 141 at an ECTA meet. But that was with some aerodynamic tricks.
~Crim~
My photo gallery: http://xlforum.net/photopost/showgallery.php/cat/500/ppuser/184]
sportymark's Avatar
Cant't comment on the precise gain because I didn't dyno it from standard. The parts fitted are all from the SE catalogue. I have a reluctance to fit other makes because the dealer that has done the work will get it back in part exchange next year. Max power was at 6500 rpm although it did rev out to 7000rpm. I will contact Bert to see if he can post the readouts as I don't have a scanner. All the run proves is what a typical Roadster with these mods puts out. The bike has only done 1200 miles so maybe it's still a bit tight.
Similar Threads
Rain Caused Engine Power Loss dneyer Sportster Motorcycle General Discussion and Problems 23 27th April 2005 21:22
cut the baffles....not good XL-DecentGlide Sportster Motorcycle General Discussion and Problems 8 5th April 2005 00:59
04 05 air cleaners Milazzo Rubber Mount Sportster Motorcycle Talk (2004-2006) 53 30th March 2005 13:51
Power Graph sportymark Rubber Mount Sportster Motorcycle Talk (2004-2006) 2 10th December 2004 09:10
