Last Post: Crosshairs
0 Need advice
Last Post: Krjrcustom1
Last Post: 60weight
0 New From CA
Last Post: 60weight
0 FNG from OKC
Last Post: GeoK
0 Oil Hose replacement help.
Last Post: McQueen
0 Shotgun Porn
Last Post: GeoK
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
0 New in NM
Last Post: GeoK
Last Post: bfarrell
rigid evo ironhead
Old 2nd December 2008
spooledup50 spooledup50 is offline
spooledup50 is an unknown quantity at this point
Default 82 ironhead
i want to build a bobber out of my 82 seems no buddie makes a 82-85 rigid frame just wanting to know if the rear mount is in the right place and i just have to fab the front and top mount or do i need to cut all the mounts and start from scratch ,
and if i had to start from scratch woud it be a good idea to use the evo frame ,
if i was to put the iron in an evo frame is the rear mount in the right place and will the motor fit in the frame just need to make front mounts or is it a waste of sweat thanks sam
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
Here's one example of what's out there...
http://www.steelthundercc.com/sportster_frames.html
jagdprcp's Avatar
jagdprcp jagdprcp is offline
Sportster/Buell Year: 1976
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1979
jagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enough
Kansas Kustom will make you a hardtail section so you can keep the stock frame and not have to worry about Title issues. You can get more info here:
http://www.kansaskustom.com/Hardtail...s_Ironhead.php
Skeeeter
'76 XLH - 4 5/8" Stroker, Andrews V-9 cams, S&S Super 'E' and Barnett Billet Scorpion Clutch plus some cosmetic stuff
'79 XLH - Mostly stock except for cosmetics (for now!)
Old 3rd December 2008
Default 82
Kansas has some nice stuff thanks but I really want to loose some rake and slam the front end -4 under like an old cafe racer or bobber there's slot of off the shelfs out there I just need to customeize it to fit just want to know if any one has tryed it and have any sugestions
tat2d2dope's Avatar
tat2d2dope tat2d2dope is offline
Other Motorcycle Model: Shovelhead
Other Motorcycle Year: 1976
tat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura about
check out this thread
http://xlforum.net/forums/s...d.php?t=360619
it's my build thread and i am modding my frame
you could get some tips and stuff there.
1973 iron head sportster fully customized the stock frame
SOLD for 76 shovelhead and $5000
Old 4th December 2008
82xlsa's Avatar
82xlsa 82xlsa is offline
Sportster/Buell Model: XLS
Sportster/Buell Year: 1982
82xlsa is an unknown quantity at this point
Default Weld on Hard tails / Frames
Check these guys out they have several weld on options for 82 models. Bitter End Old School Choppers.
http://cgi.ebay.com/ebaymotors/82-03...QQcmdZViewItem
http://www.tejasthumpcycles.com/Part...r%20frames.htm
