Last Post: Hank21113
0 Won't rev past 1200
Last Post: Aocasio
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
Last Post: jordan1200
0 too bad
0 Head gaskets.
Last Post: ezmerf
Last Post: robistro
Last Post: felis
0 newby from Australia
Last Post: Veeflys
Last Post: Crosshairs
0 seeking advices
0 Dynatek DC6-5 coil
0 Cream
Last Post: jakewalter
Last Post: seajay
Last Post: seajay
Last Post: JKKO
0 H4 bulb
Last Post: andy_t
Last Post: cazz1000
0 Speedo cable lube
Last Post: JacksBrother
0 Oil use/smoking
Last Post: gpydeski
Old 7th March 2005
Geek's Avatar
Geek Geek is offline
Geek is an unknown quantity at this point
Default Removing reflectors from fender
I am wanting to remove the reflectors from my forks and rear fender. Not to worried about the forks but any considerations I need to take before removing from the fender? I don't want the paint to come with it.
Thanks!
Old 7th March 2005
Turbota's Avatar
Turbota Turbota is offline
The paint won't come off. Credit card will work. So will nylon fishing line. Some people heat them a little with a hair blower (but not nessesary) before trying to remove.
Any glue that remains can be removed with WD-40. It will melt the glue right off after a little rubbing.
Have fun!
04 XL 1222R
Old 7th March 2005
Hi.
Well, the way I would do it is to get a plastic bondo spatula and some WD-40.
Soak the adhesive down with WD-40, and then using shrt strokes, work the spatula between the reflector and the fender.
Once off, use a terry cloth soaked in WD-40 to remove the rest of the glue.
Old 7th March 2005
Steve-B Steve-B is offline
Steve-B has disabled reputation
Would it be fair to assume the same rules apply in removing the tank badges, and the centre trim on the 2004 1200c?
Old 7th March 2005
Geek's Avatar
Default Thanks
Thanks fellas.
I now have my Saturday project.
Old 7th March 2005
LuxBlue's Avatar
LuxBlue LuxBlue is offline
According to the shop manual, use string or fishing line in a sawing motion to break adhesive bond for tank trim removal. The manual says use isopropyl alchohol to clean glue residue. I guess WD-40 wouldn't hurt the clear coat??
Old 7th March 2005
Thanks for that, LuxBlue.
Old 8th March 2005
SamIam's Avatar
SamIam SamIam is offline
Other Motorcycle Model: FXDX
SamIam is an unknown quantity at this point
Worked like a charm (using the WD40 and the CC) great tip! I'm sure the plastic bondo spatula or fish line would work well too...just did not have any around.
Thanks!
Old 9th March 2005
LuxBlue's Avatar
Actually it wasn't the shop manual that I saw the tank trim removal, it was Service Bulletin M-1152. Here's the description without drawings or check this site Bert found and look at Bulletin M-1152.
http://www.harleyhog.co.uk/M_bulletins.htm
M-1152 1 of 3
SERVICE BULLETIN
2004 SPORTSTER FUEL TANK CONSOLE
Purpose
As a running change, the XL Custom fuel tank console
assembly has been redesigned to minimize the potential for
console fitment complaints and seat damage. This bulletin
describes how to identify these problems and replace consoles
on affected vehicles.
Motorcycles Affected
All 2004 XL 1200 Custom models produced before 2/17/04.
Required Dealer Action
If any of the following conditions exist, follow the instructions
under
Procedure
below to replace the console assembly:
If the seat has been damaged by the pin and clip assembly
attached to the rear end of the console.
If the metal console is loose from the plastic liner.
If the metal console rattles.
If there are exposed sharp edges on the metal console.
When the condition(s) exist which require console replacement,
order the redesigned console, Part No. 71276-04A,
through normal parts order process. You will be billed accordingly
and reimbursed when you file a claim. See Credit Procedure.
Replace seat if it has been cut or torn. If the integrity of the
seat has not been compromised and damage is in a nonvisible
area, seat is deemed acceptable and is not to be
replaced.
Procedure
Special Tools Needed
Console Alignment Ring HD-47114.
Temporary use of a smaller diameter fuel filler cap (H-D
Part Number 61272-92B). This is the original equipment
cap found on 2004 or later XL883 and XL1200R Sportsters,
as well as many other Harley-Davidson models.
Approximately 18 in. (0.46 M) fishing line (or string) to
aid in removing the existing console.
Removal
1. Refer to the Sportster Models Service Manual and follow
the instructions given to remove the seat. Retain all seat
mounting hardware.
11WARNING 1WARNING
Stop the engine when refueling or servicing the fuel system.
Do not smoke or allow open flame or sparks near
gasoline. Gasoline is extremely flammable and highly
explosive, which could result in death or serious injury.
(00002a)
2. See Figure 1. Remove the original fuel filler cap (2) from
the fuel tank (1) and set it aside. Obtain a small diameter
Harley-Davidson fuel filler cap (5) and screw it into the
fuel filler opening.
Figure 1. Console Installation
1. Fuel tank
2. Original equipment fuel filler cap
3. Fuel tank console
4. Console alignment ring (Part No. HD-47114)
5. Small diameter fuel filler cap
M-1152 April 23, 2004
IMPORTANT NOTE
In the interest of preserving customer safety and satisfaction, always check for outstanding recalls whenever any motorcycle is brought into your
dealership for either maintenance or service.
©2004 HARLEY-DAVIDSON MOTOR COMPANY
M-1152 2 of 3
3. See Figure 2. Insert the fishing line (2) between the rear
of the fuel tank and the plastic liner (1) on the underside
of the original console.
NOTE
Raise the ends of the fishing line away from the fuel tank to
avoid scuffing the tank finish.
4. Using a side-to-side “sawing” motion, work the fishing
line toward the front of the fuel tank to break the adhesive
bond between the console and the tank.
5. Carefully remove the console and liner from the fuel tank
and discard it.
CAUTION
Be careful not to scratch the paint on the fuel tank when
removing the adhesive.
NOTE
To avoid damaging the fuel tank finish, do not use tools or
abrasive cleaners to remove the adhesive residue that
remains on the fuel tank surface. Try to stay within the area
that will be covered by the new console.
6. See Figure 3. To remove any adhesive residue remaining
on the fuel tank surface:
a. Carefully peel off as much adhesive as possible,
using your thumb and fingers only.
11WARNING 1WARNING
Observe warnings on labels of cleaning compounds.
Failure to follow warnings could result in death or serious
injury. (00076a)
CAUTION
Use of cleaning compounds other than isopropyl alcohol
may damage fuel tank finish. Test in inconspicuous area.
b. Clean the top of the fuel tank with a mixture of 50%
to 70% isopropyl alcohol and 30% to 50% distilled
water or, if necessary, straight isopropyl alcohol.
c. Allow the fuel tank surface to dry thoroughly
Installation
1. See Figure 4. Measure and mark the centerline of the
fuel tank at the rear of the tank.
2. Obtain the
new
fuel tank console. Measure and mark the
centerline of the console at the rear of the panel.
3. See Figure 5. Place Console Alignment Ring (Part No.
HD-47114) over the fuel filler cap.
Figure 2. Removing Existing Console
Figure 3. Removing Adhesive Residue
Figure 4. Marking Fuel Tank Centerline
Figure 5. Placing Console Alignment Ring Tool
(Part No. HD-47114)
i02569
1. Original fuel tank console liner
2. Fishing line or string
M-1152 3 of 3
4. Peel the liner from the adhesive backing of the console.
5. Position the console over the fuel tank without touching
the adhesive to the tank surface. Center the large hole
over the console alignment ring tool, and align the mark
on the rear of the console with the mark made on the
rear of the fuel tank.
6. Slide the front of the console down over the console
alignment ring tool onto the fuel tank. Bring the rear of
the console down, keeping the marks aligned.
7. Press the console firmly against the top of the fuel tank
and hold pressure for 30 seconds. After releasing pressure,
avoid direct contact with the console for about 20
minutes, then remove the console alignment ring tool.
8. Remove the small-diameter fuel filler cap and install the
original fuel filler cap.
9. Refer to the Sportster Models Service Manual and follow
the instructions given to install the seat.
11WARNING 1WARNING
After installing seat, pull upward on front of seat to be
sure it is in locked position. While riding, a loose seat can
shift causing loss of control, which could result in death
or serious injury. (00070a)
10. Allow AT LEAST 24 hours after applying the console
before exposing the area to vigorous washing, strong
water spray or extreme weather. The adhesive bond will
increase to maximum strength after about 72 hours at
normal room temperatures.
Credit Procedure
For each vehicle requiring console replacement, complete a
regular warranty claim referencing Service Bulletin M-1152 in
the ‘Comments’ or ‘Note’ field of the claim. Fill in the rest of
the claim as follows:
Upon receipt and processing of the properly completed claim,
you will be credited the appropriate amount for parts and
labor. Be sure to destroy and properly dispose of all replaced
fuel tank consoles 60 days after receiving credit on the
claims.
NOTE
This condition will be warranted while the vehicle is still under
factory warranty only.
Similar Threads
Changing out a rear fender, how difficult? E00i3 Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 12 5th March 2006 22:09
Rear fender scratches invaliduser Sportster Motorcycle General Discussion and Problems 5 25th April 2005 18:10
Heh...FXR fender struts almost fit... Joker88Sporty Chopper & Bobber Talk 2 3rd April 2005 03:18
Removing 04 rear fender > Lots of work? Turbota Sportster Motorcycle General Discussion and Problems 8 16th March 2005 01:54
HELP REMOVING REFLECTORS OFF MY 04 vetthed Rubber Mount Sportster Motorcycle Talk (2004-2006) 17 27th January 2005 15:55
