Last Post: Screw Loose Dan
0 Primary Oil INSANITY!
0 Lowboy frame conversion
0 What jets do you use?
Last Post: David L.
0 FNG from OKC
Last Post: David L.
0 Show your tank decals
Last Post: Tonail
0 Solar battery charging
Last Post: Ranchero50
Last Post: Naplesron
Last Post: Grumpy-Biker
Old 30th September 2006
rottenralph's Avatar
Default Question about front tires
I tried to have a 120/70/19 but it would not open out to the rimn and seal. Just too big for my 2.75 inch wide rime. Who know the largest tire I can fit on a standard width 19 inch harley front wheel. I have had a 100/90/19 and want the widest I can get. Will 110/80/19 fit.
its actually 3 inches wide according to the web site.
Ghugly Ghugly is offline
Ghugly has disabled reputation
What device or devices were used to expand the sidewalls? I've seen the nutty lowriders around here using some freakishly narrow tires on wide rims on their cars (I mean tread widths half the rim width). While this is a stupid way to achieve a really stupid looking, poor handling ride in my opinion, it's pretty common. I really don't know what devices are available for mounting bike tires, but it seems to me that what you're trying to do shouldn't be that tough.
'04 XL883 With '04 1200 Heads, Cylinders, and pistons, Sifton Evader Cams, Arlen Ness Big Sucker A/C, SE2 Slip ons, SE Ignition, Road King Air Shocks.
obinella's Avatar
obinella obinella is offline
Sportster/Buell Model: xl 883 R
Sportster/Buell Year: 1989
Other Motorcycle Model: 83 xs 650 yam
Other Motorcycle Year: 83
obinella will become famous soon enoughobinella will become famous soon enoughobinella will become famous soon enoughobinella will become famous soon enoughobinella will become famous soon enoughobinella will become famous soon enough
install the tire, seat the bead on one side, squirt a shot of ether in tire and touch off with a match. standard precautions apply! keep your face, chin whiskers, etc,etc out of harms way, keep your fingers out of the damm thing also.
Can I watch?
obinella's Avatar
Originally Posted by Ghugly
Can I watch?
sure, great fun!
cjburr's Avatar
cjburr cjburr is offline
Sportster/Buell Year #2: 1998
Other Motorcycle Year: 2009
Ralph, here is the thread where I installed what I believe is the biggest tire you can put on a stock front rim. My rim was the stock 19" cast wheel. Hope it helps, there are pics of the installed tire and you can see how close it came to the fender.
Good luck, Chris
http://xlforum.net/forums/s...ad.php?t=26303
My Other Toy Goes Mach 25
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
If you have a 2.75 rim you should be able to mount a 120 on it. I have a 2.75/18 rim that I used to have on my bike and 120s fit it no problem, but really a 120 would like a 3" rim.
I'm running the stock 2.15 rim now and I have a Avon 110/90 19 on it that fits fine. It's really big ass. It's as wide as some 120s, and might not fit the stock fender. It makes a Dunlop GT501 100/90 19 look like a little skinny runt.
I think the problem was the 70 height coupled with the extra width. The tire was 5 inches wide and after putting it on it looked wrong and the one side would not roll out to the edge. It stayed tucked under. I ordered a 110/80/19 and that one has to fit. I used to have a avon venom up front in the same size. I hope the 140/70/16 works on my back. The 70 seems to like a wider rim.
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
R, how many miles did you get out of the Venom on the front? just curious cause i just bought new front/rear set Venom x.
Bad news: had to get a new front wheel bearing rightside was bad, and it won't be here till tuesday. Running the spoke wheel in the meantime.
RTFS
Ride That F'N Sportster!!
