0 Not measuring any crankshaft endplay
Last Post: nakina
0 Manifold Leaks Gone !!!!
Last Post: cazz1000
Last Post: groovemeisterus
Last Post: rwharris
Last Post: tvon
Last Post: KCinSB
0 Lightning strike
Last Post: Screw Loose Dan
Last Post: x1_guy
Old 10th October 2006
Mattbastard's Avatar
Mattbastard Mattbastard is offline
Bike Builder
Sportster/Buell Model: Sportster 883/1200
Other Motorcycle Model: V-Strom 1000
Other Motorcycle Year: 2014
Mattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of light
Thanks for the reply. You've got the aluminum one I assume. Is there a steel counterpart that I could get from HD? I've heard ppl on here complain about the aluminum ones and quality issues they've had with them wearing too quickly and whatnot.
Old 13th October 2006
chipdog4's Avatar
chipdog4 chipdog4 is offline
chipdog4 is an unknown quantity at this point
I remember someone a while back getting a steel 29 tooth from harley for around $60? That wouldn't be bad at all.
Here's a website with a Pulley listed for ALL SPORTSTERS
http://www.billetusa.com/evoprodt.html#
EV-30TALSP 30 tooth aluminum pulley - for all Sportster
Old 14th October 2006
Stratwhak Stratwhak is offline
Sportster/Buell Model: XLH883
Stratwhak is on a distinguished roadStratwhak is on a distinguished road
I got the 30t on Wednesday, piece of cake. The belt was plenty long enough, I slipped the pulley on with the rear wheel still on the bike. The rpms dropped about 500 at 70mph and taking off in first was still smooth and quick. Thank you all for your helpful responses.
4banger 4banger is offline
4banger has disabled reputation
Smile
Glad everything worked out good for you. I really like having a 30t when I'm flying on the interstate.
Old 20th October 2007
Ericxb9r Ericxb9r is offline
Sportster/Buell Model: xb9r
Ericxb9r is an unknown quantity at this point
Default Can I put a smaller sprocket set on my Firebolt
I have a 2005 Firebolt 900. I want to make an acceleration improvment.I'm thinking quite a few teeth less. My question is are there sprockets available and how many teeth should I subtract.
Old 6th July 2009
mrteegass mrteegass is offline
Sportster/Buell Model: IRON
mrteegass is an unknown quantity at this point
Default 2009 883 iron
can anyone help me im trying to replace my front belt sprocket to 30T is the nut 1 7/8 left or right hand thread its difficult to came loose.please help thank you guys !!!!!:
Old 6th July 2009
Oldwrench Oldwrench is offline
Sportster/Buell Model: Sportsters
Oldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the rough
Default Secondary Sprocket Nut
Mr. TeeGass,
Like the second posting in this thread says, it is a "reverse" or Left Hand threaded nut. It is installed with Loctite, so you may have to lean on it.
Turn it clockwise to remove it and counter-clockwise to install it.
Old 6th July 2009
FoxsterUK's Avatar
Mine was a huge PITA to get off; took me two days. I made a sprocket locker to hold the sprocket tight while I whaled on the nut. They fastened it on with red Loctite and I started to doubt it was reverse threaded a couple of times when I couldn't get it to shift. Eventually I got it to move by standing on the 30" tommy bar on the socket I was using.
If there is any chance whatsoever you might take it off again then don't use red Loctite on it, use blue.
Fox
I had an '05 1200R.
Old 19th December 2010
buelldog's Avatar
buelldog buelldog is offline
Sportster/Buell Model: buell x1 lightning
buelldog is an unknown quantity at this point
Hi can you tell me the part number for the 27 tooth sprocket OR which year Sporty they were fitted to
as i want to put US gearing on my Buell
but cant find any 27T pulleys over here in the UK
thanks for any help
devilshound's Avatar
devilshound devilshound is offline
Other Motorcycle Model: bmw r75/6...gone
Other Motorcycle Year: 1976
devilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura about
Per an '01 X1 Parts Catalog, 40285-91B is listed as a sprocket kit (bolts, spacer, seals, ect) and 40288-95 is just the sprocket for a 27T.
Hope that helps,
-DH
