0 Won't rev past 1200
Last Post: Aocasio
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
Last Post: jordan1200
Last Post: Hank21113
0 too bad
0 Head gaskets.
Last Post: ezmerf
Last Post: robistro
Last Post: felis
0 newby from Australia
Last Post: Veeflys
Last Post: Crosshairs
0 seeking advices
0 Dynatek DC6-5 coil
0 Cream
Last Post: jakewalter
Last Post: seajay
Last Post: seajay
Last Post: JKKO
0 H4 bulb
Last Post: andy_t
Last Post: cazz1000
0 Speedo cable lube
Last Post: JacksBrother
0 Oil use/smoking
Last Post: gpydeski
0 Nighster seat on Iron
Last Post: ed_in_az
View Poll Results: Best carb for reliable daily use
S&S 161 31.32%
Mikuni 99 19.26%
CV 159 30.93%
Bendix 55 10.70%
SU 15 2.92%
Other 25 4.86%
Voters: 514. You may not vote on this poll
Old 2nd October 2006
onadraw's Avatar
onadraw onadraw is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1979
onadraw will become famous soon enoughonadraw will become famous soon enoughonadraw will become famous soon enoughonadraw will become famous soon enoughonadraw will become famous soon enoughonadraw will become famous soon enough
Default Carb ???
Help me decide on a carb for my 79 Ironhead. I will be running stock cams and want reliabilty for daily riding more than excess power.
Ive been reading about S&S, Mikuni, CV, Bendix, and SU.
Help me pick one.
shotgun46's Avatar
i like the c v pretty simple & easy to work on !
Sportsters Rule ! :banana
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Help me pick one.
I voted before I saw it was a 79 Ironhead...
I really like CV, but if memory serves, that wasn't the stock carb?!?!?
~Chuck
Occam's Razor...
XLF Tuning Stickies
MDT's Avatar
MDT MDT is offline
Sportster/Buell Year: 61
Other Motorcycle Model: Superglide
Other Motorcycle Year: 74
MDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond repute
I'm thinking that in 79 Keihin was still OEM. Help me on this mick.
I have S&S on my rides. I have had good look with Mikuni's.
A bendix is an old oem carb. I have used them but they can flood easily. Also they have a bowl vent that can overflow at the darndest time.
I can say this for S&S they still support (sell parts for) their early carbs. I don't know if that is important to you but in my case my carbs are 30 years old.
Bill2's Avatar
Bill2 Bill2 is offline
Bill2 has disabled reputation
You can pick up a cv take off on ebay pretty cheap and they work nice on the ironheads. You just have to buy a adapter to make them fit.
SportsterBart's Avatar
SportsterBart SportsterBart is offline
Sportster/Buell Year: 96
Other Motorcycle Model: Suzuki DR 650
Other Motorcycle Year: 94
SportsterBart has disabled reputation
I'm pretty sure the stock carb was a keihin butterfly in '79.
Bart
Gonna keep my guns and have my fun and call it just the way I see it.
chrishajer's Avatar
Sportster/Buell Year: 1988
'79 had a Keihin fixed venturi (butterfly, non-CV.) If I were picking a carb for an ironhead, I would pick a CV because takeoffs are cheap and plentiful, parts are cheap and plentiful and it works pretty well all the way around. If I had to rank them:
  1. CV
  2. Stock Keihin (new, not worn out)
  3. Mikuni HSR42 or HS40 (more $$ than CV, better throttle response than S&S)
  4. S&S E (more $$ than CV)
  5. Bendix (new, not worn out)
  6. SU (really don't like these, the original CV )
--Chris
geraldxlch's Avatar
geraldxlch geraldxlch is offline
Sportster/Buell Model #2: 883 Custom
Sportster/Buell Year #2: 2000
Other Motorcycle Model: 1200 xlc in flyrite frame
Other Motorcycle Year: 2002
geraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the rough
I have had good luck with the S&S, set it and forget it. However they are expensive and others on this forum have stated that the CV performs well and can be had for much less $.
wabiker's Avatar
wabiker wabiker is offline
Sportster/Buell Year: 94
Other Motorcycle Model: FLSTSB Crossbones
Other Motorcycle Year: 2008
wabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to behold
S&S gets my vote.... simple, reliable, available, versatile.
Support Your local B.A.C.A -Bikers Against Child Abuse
onadraw's Avatar
Default adapter
Sounds like I need a 1993-2006 factory take-off. Are they all the same during those years?
Please tell me about the needed adapter. Is there a part number for it?
