Last Post: ezmerf
0 Lowboy frame conversion
Last Post: yoshi
0 What are you drinking tonight?
Last Post: ABMI
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
0 Need FP3 map for 2014 Sporty 1200
Last Post: tester
Last Post: Aden
Old 8th March 2005
SxysCowboy's Avatar
SxysCowboy SxysCowboy is offline
Other Motorcycle Model: Kawasaki 750 H2
Other Motorcycle Year: 1972
SxysCowboy has disabled reputation
Default want wider tire need help
i would like to put a wide tire on my 1998 1200C 150 or 180 would be nice but i don't want to have my sprocket cover with that ugly gap in it. 150 is probly enough but can i get it under my stock fender.? also i can go to chain but was hopein not. any ideas would be great. also i am a custom steel fabricator so i will most likely build my own swing arm if a store bought one is too high.
Old 8th March 2005
Barry Clark's Avatar
Barry Clark Barry Clark is offline
Barry Clark has disabled reputation
I think you can put a 150 in their without too much fuss. I think there was someone on this forum that did this. I don't think they had to switch swingarms or anything to do it either. If you go to a size that requires a swingarm switch, they are too high.
Old 8th March 2005
mikeLI_77's Avatar
if you do a search for tire sizes you will find a few posts on this question but one of the posts says a 150 is the max size for the stock rim.
2002 XL1200C (originally)
Supertrapp supermeg exhaust 20 disks and open end cap, S&S roller rockers, Alto Carbonite clutch with Energy One 15% heavier spring plate, Daytona twin tech single fire ignition 1005s
Ricor intimnators, 13" Ricor IAS shocks, Brembo dual disk setup from a 2012 street glide with matching brembo street glide master cylinder,
States I Have rode through
Old 8th March 2005
SxysCowboy's Avatar
thanks guys
Old 8th March 2005
KingSize's Avatar
KingSize KingSize is offline
KingSize is an unknown quantity at this point
I run a 160, but of course I put a chain on.
Old 9th March 2005
SxysCowboy's Avatar
my bike has the full lowering kit so i think i might rub but will i need to go chain for a 150? i am shootin for 90HP on my recent mods and i know ill need more tire to hold it
Similar Threads
200 Rear tire on my Ironhead 74XLwide Ironhead Sportster Motorcycle Talk (1957-1985) 12 30th June 2011 15:17
Rear Tire blow out or fast leak at speed conecuh Riding Tips & Safety Advice 24 28th September 2008 21:08
Tire Size/performance question bullittt Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 1 18th May 2005 17:32
Repair a flat tire? Kelley Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 15 22nd April 2005 02:58
wider tire HD CRAZY Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 1 9th March 2005 01:04
