Last Post: Crosshairs
0 Need advice
Last Post: Krjrcustom1
Last Post: 60weight
0 New From CA
Last Post: 60weight
0 FNG from OKC
Last Post: GeoK
0 Oil Hose replacement help.
Last Post: McQueen
0 Shotgun Porn
Last Post: GeoK
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
0 New in NM
Last Post: GeoK
Last Post: bfarrell
Old 23rd December 2008
harleyhornet harleyhornet is offline
Sportster/Buell Model: 883r
Other Motorcycle Model: FLHS
Other Motorcycle Year: 1990
harleyhornet will become famous soon enoughharleyhornet will become famous soon enoughharleyhornet will become famous soon enoughharleyhornet will become famous soon enoughharleyhornet will become famous soon enoughharleyhornet will become famous soon enough
Default The more I learn the dumber I get
IN changing to a high flow air cleaner from stock on a FI bike is it really necessary to ad some type of fuel controller the maintain correct AFR ? Wouldnt the manifold air pressure sensor sense the increased air flow and change the VE table therefore adjusting the AFR accordingly ?
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
IMO if you do absolutely nothing to your EFI scoot it is necessary to add some type of fuel controller to maintain correct AFR. 14.7 AFR is correct only to the EPA, not your scoot or the power it makes. It took me 6 months of research to decide on the PCIII/USB.
To answer your original question, no.
So am I correct in assuming that the MAP will compensate via the VE table to correct to the target AFR ( even if it is the epa 14.6/1 ) Therfore your running the same AFR regardless of air cleaner modification.
racerwill's Avatar
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Year #2: 80
Cool
you are correct
Ww
master wizard
[B][COLOR="Red"]Super Moderator[/COLOR][/B]
[FONT="Book Antiqua"][B][U]RIP Mr Jimi[/U][/B][/FONT]
"All The Way"
Bob F's Avatar
If you also change the mufflers or exhaust system then you'll have to at least get a reflash (waste of money) or some form of fuel adder.
Old 24th December 2008
FoxsterUK's Avatar
Its not the MAP sensor thats in play here, that's not checking the A/F ratio but the pressure of the fuel/mix as it enters the manifold and it adjusts for changes in air density like you get at higher altitudes.
The narrow-band O2 sensor in the exhaust is what adjusts the A/F ratio. It and the EFI can cope with a reasonable change such as you might get with just a muffler swap but once you mess with the A/C too then you are working outside its tolerance and you will need a remap.
Fox
Old 25th December 2008
racerwill's Avatar
technically it's the ecm that determines the correct fuel/air ratio.... the O2 sensor(s) only fine tune the fuel to keep it centered ..... it's the MAP that determines the both long and short term fuel trim........
I'm just sayin'
Ww
Old 26th December 2008
OK I think im getting it, the manifold air pressure sensor is telling the ecm the temp and pressure of the incomming air therefore determining the oxigyn content, the ecm then has to measure that with the ve table which it gets from the x and y axis of the throttle position and engine speed ,the ve table is already pre determined by calculations based on the engine displacement cams intake etc.. soooo if you change your air cleaner without adjusting the ve table accordingly you will need to add a controller to ad more fuel.
oh yea I forgot , the ecm then has to use the data from the ve table , the intake air temp and pressure and measure that against the predetermined afr table to determine the injector pulse width at specific operating conditions. can any one help me with this if I am wrong thanks:
racerwill's Avatar
the air cleaner alone won't change the volumetric efficiency enough to matter...... everything will still be within range of normal fuel maps and it will be fine...... if you change to a set of pipes that scavenge better and flow better than the stockers then it would be possible to pull more air thru the engine than the fuel maps can handle........but just an air cleaner won't change anything enough
some good info here.....
http://www.xlforum.net/vbportal/foru...70#post1633470
Ww
