Last Post: jeffro57
0 best set up for ease of kick starting
Last Post: clivelive
0 Tuning a keihin butterfly
Last Post: shivaspear
0 '74 Front Brake Caliper leaking
Last Post: dtwaddell42
0 1960 XLH Stroker – a 13 year journey
0 71 XLH Value?
Last Post: joe s
0 60’s XLCH front tyre
Last Post: davixlrtt
0 72 ih stroker advise needed
0 Allegheny National Park III
0 Hello from CT
Last Post: fafcpa
0 Aftermarket nose cone module vs aftermarket under seat module
0 Had to wait for the snow to fall to pick up my 73
Last Post: Andy56
0 NOS cases
Last Post: BillPlayfoot
0 Facebook sales listing
0 Lectron Carbs: anyone used them?
0 Exhaust compatability?
Last Post: Racepres
0 2021 Iron Butt Rally
ebikerman (85), nalakk (80), blkjak (78), Dave.N (67), cousincletus (61), stretch7 (59), jockeyshift (57), juice900 (43), sportsterwheelies (41), live_loud (39)
Old 4th October 2006
Lightbulb Charging System Checkout
IronHead Charging System Checkout
You need a multimeter. The digital ones are best and can be had for less than $10.00. A voltmeter is a multimeter set to measure DC volts. An ammeter is a multimeter set to read DC current in amps. The ohmmeter section of the multimeter will test for continuity. Continuity means that current may flow between the two points.
I find alligator clip probes are much more convenient than pointer probes. Occasionally a pointer probe is better so i have a set of each.
When using a Multimeter, if the object fails a test, repeat the test ensuring that you have good connections with the meter probes, especially to a good ground.
1. Fully charge battery.
It is not good enough to put it on a charger overnight and assume it is fully charged. Some batteries will take 24 hours to fully charge. The way to know for sure is to do a specific gravity test [for liquid filled batteries], or to use an automatic battery charger.
I have heard that you should never use a battery charger greater than 2 amps for any motorcycle; that it is best to use between .75 and 1.5 amps. Best are the automatic chargers such as Battery Minder or Battery Tender.
2A. Cell test battery [not for maintenance-free batteries].
Contributed by Jeremy
Remove caps from battery cells. Keep the red voltmeter lead on a terminal and insert the black lead progressively into each cell, far enough that it contacts the plates. You should get readings of 2, 4, 6, 8, 10 and 12 volts. If one cell does not contribute its proper 2 volts then that cell is dead and the battery is no good.
2B. Load test battery.
Disconnect both spark plugs; if you have electronic ignition put another set of plugs into the wires and firmly ground them, usually on the cylinder heads. Attach voltmeter leads to the battery terminals. Crank the engine for 10 seconds [no more!]. Observe the meter WHILE cranking. If it goes below 10 volts then the battery is no good. Alternatively you can buy a battery load tester - these are available at Princess Auto or Harbor freight, not too expensive especially when on sale.
Bring the battery up to full charge again before proceeding.
3A. Current Drain Test #1
Contributed by MoreHP
Disconnect the battery -ve cable from the battery. Connect the ammeter between battery -ve post and the battery cable. It should read .003 amps or less.
3B. Current Drain Test #2
Disconnect the +ve terminal from the battery. Connect an automotive test light between the battery and the cable. If light comes on there is a current draw.
Note: To determine which circuit is faulty disconnect the circuit breakers or remove the fuses one at a time. When the light goes out you know which circuit is the problem.
3C. Battery Cables Test
Contributed by Matt
With voltmeter connected to battery terminals check voltage while cranking. Then with voltmeter on battery cables check voltage while cranking. If voltage drop due to cranking [should not go below 10 volts] is different cables may be bad or there may be corrosion.
3D. Contributed by thewizard, and by fs2179 Sam:
Here is another very simple non complex test you can do if you suspect that something is draining your battery when the key is off. This applies to bikes that have no digital instrumentation (like ironheads). Unhook your negative battery terminal. Touch the wire back to the negative battery terminal, there should be no spark when you do. If it arks and sparks (like a downed hydro pole in a rain storm in a horror movie) then something is drawing power when it shouldn't be.
4. Charging System Test
Measure the battery voltage with the bike not running. It should be at least 12.x; preferably it will be 13.x.
Measure the voltage with the bike idling at about 2000 to 3000 RPM. It should be at least 1.0 volts higher than the not-running reading, otherwise the charging system is not charging the battery. It should be at least 13.x, preferably 14.x.
5. Regulator Test
Disconnect the regulator. Connect your ohmmeter to the orange and tan wires. Note the reading. Reverse the connections. Note the reading. One reading should show continuity, the other should show no continuity. If the regulator does not pass this test it is no good. This is the circuit that prevents the reg from draining the batt when the bike sits overnight.
This test only tests one circuit in the regulator, so even if it passes this test it may still be no good. There are other tests of the regulator that require specialized equipment. These tests are in the factory and Clymer manuals. I recommend taking both the reg and the gen to an automotive electric repair shop for testing if needed. Note: these shops usually want to test both parts together.
6. Generator Test #1: Amperes Output
For this test use a 0-30 ammeter from TSC or an auto supply, the type that is intended to be installed in a dash.
  1. Remove all wires from both A and F terminals
  2. run a jumper from F to a good ground on the motorcycle
  3. run a jumper from A to ammeter +ve
  4. run the engine at 2000 RPM
  5. momentarily jumper from battery +ve to ammeter -ve
  6. ammeter should read 10 amps or more
If the generator fails this test it must be disassembled for repair.
7. Generator Test #2: Residual Magnetism
Disconnect both the A and F terminal wires. Connect the +ve voltmeter lead to the A and the -ve lead to ground. Run the engine at about 2000 RPM. The meter should read at least 2.0 volts. If the voltage is low polarize the generator and repeat the test. If the generator fails this test it must be disassembled for repair.
8. Generator Test #3: Maximum Output
Remove both the A and F terminal wires. Connect the +ve voltmeter lead to the A and the -ve lead to ground. Run the engine at about 2000 RPM. MOMENTARILY [not longer than 10 seconds] connect a jumper lead from ground to F and read the meter. The meter should read 25 to 30 volts DC. If the generator fails this test it must be disassembled for repair.
9. Here's a good way to bench test your generator:
Contributed by Bowtied
1. connect a jumper from the "+" battery post to the "A" armature terminal on the gen.
2. Connect a jumper from the "-" battery post to the "F" field terminal of the gen.
3. Now take a third jumper from the "-" battery post and touch it to the case of the gen.
If all is well the generator will run like an electric motor. With the gen gear pointing away from you the rotation is clockwise.
Don't try this with the generator on the bike.
10. Polarizing the Generator
With the generator fully installed in the bike, all connections made, ignition off; connect one end of a jumper wire to the gen A, and momentarily touch the other end to the battery +ve terminal.
Usually [but not always they say], you will get a spark at the battery terminal and a light clunk sound from the gen.
11. Polarizing the Generator - The Complete Story
Contributed by Fe Head and carmine73
1. with the gen on the bench
[i] jumper the gen A to batt +ve
[ii] momentarily jumper from gen F to batt -ve
Note: This can be done the other way around,
[i] jumper gen F to the -ve batt
[ii] momentarily jumper gen A to batt +ve
2. with the gen on the bike, wires not connected
[i] jumper from gen F to a good ground
[ii] momentarily jumper from gen A to batt +ve
Note: This technique is preferred over #3 because the good ground is better than relying on grounding the F thru the reg.
Note: As with #1 this can be done the other way around.
3. with the gen on the bike, all wires connected
[i] momentarily jumper gen A to batt +ve
Note: This is technically the same as techniques #1 and #2 as the F is grounded thru the reg.
4. For bikes with a mechanical reg [1959 to 1977]
Momentarily jumper between BAT and GEN on the reg.
Note: this is technically the same as all of the other techniques as BAT is connected to batt +ve and GEN is connected to gen A.
5. For bikes with a Cycle Electric Generator/Regulator
Contributed by FourCams
On the Cycle Electric DGV-5000 generators you have to remove the brush cover and touch a wire from the positive terminal of the battery to the positive brush lead of the generator to polarize it. You can't polarize the generator from the external terminals. (One of the terminals is the battery terminal, and the other has an internal diode.)
You have to try pretty hard to reverse the polarity on those generators and they rarely need to be polarized.
For clarification: Cycle Electric does have a voltage regulator (the CE-540) which looks very similar. It will bolt up to a standard Model 65A generator and has external leads which connect externally between the regulator and the generator.
The CE-500 bolts to a Cycle Electric DGV-5000 generator and the regulator is internally wired to the generator.
- With the CE-540 setup the generator can be polarized by running a lead from the battery + to the "A" terminal.
- With the CE-500 you need to polarize the generator at the positive brush lead.
12. Generator Brushes Assembly: Dismantle, Cleaning, Repair
1. The brushes holder and related parts can be dismantled without removing the gen from the bike. This is useful because, in my [limited] experience, if the gen light is coming on then one or both of the brushes is probably sticking. This can be easy to fix.
I am writing this from memory, not while doing it. I think i have the removal process right.
Remove gen end cap. Remove the bracket and brush cover strap. Remove the commutator end cover. There are 3 screws visible. Two just hold the brushes to the brush holder; these do not need to be removed. The third screw attaches a wire from inside the gen to the brush assembly. Remove this screw. Now the brush assembly can be removed.
Usually it is quite dirty in there so at this point i use a spray can of electrical contacts cleaner to clean up the mess.
The brushes will spring out of the brush holder. They must be each longer than 1/2 inch else replace both. Reinstall each temporarily and work them between thumb and finger to see if there is any binding.
To re-install brushes in holder use long twist ties from the kitchen. Pick out the twist ties after the holder is re-installed.
2. To remove the gen from the bike: Disconnect the wires from the A and F terminals; remove the two bolts from the gearcase side; raise the inner end toward the 11:00 o'clock position, lower the outer end toward the 5:00 o'clock position, and remove carefully.
For the rest you really need a manual. The FM is very good. It is usually not necessary to remove the gen drive gear - this requires a gear puller to remove. The rest of the gen dismantles quite easily.
Once opened up you can do more cleaning and inspection; again using the spray can electrical contacts cleaner.
The FM contains a number of tests that you can easily do once it is opened up: field coil test, shorted or open field test, grounded armature test, and open armature test.
The shorted armature test requires special equipment which a shop would have [a growler]. Doing actual repair may require special equipment such as a lathe, and perhaps experienced hands.
Barndog's Avatar
Barndog Barndog is offline
Sportster/Buell Model: 1200 XL
Sportster/Buell Model #2: Ironhead
Sportster/Buell Year #2: 1979
Barndog is on a distinguished roadBarndog is on a distinguished road
Thank you.
I'll be needing this soon.
MC
Old 6th October 2006
geraldxlch's Avatar
geraldxlch geraldxlch is offline
Sportster/Buell Model #2: 883 Custom
Sportster/Buell Year #2: 2000
Other Motorcycle Model: 1200 xlc in flyrite frame
Other Motorcycle Year: 2002
geraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the rough
Mick, very nice comprehensive check list.
RogerMason's Avatar
RogerMason RogerMason is offline
Sportster/Buell Year: 1976
Other Motorcycle Model: Special Const Trike
RogerMason is on a distinguished roadRogerMason is on a distinguished road
great job mick. Im going to copy and paste this in my computer files.
Thanks Roger
:chop [I][FONT="Impact"]A good day is one where you have wind in your face and bugs in your teeth[/FONT][/I]
MDT's Avatar
MDT MDT is offline
Sportster/Buell Year: 61
Other Motorcycle Model: Superglide
Other Motorcycle Year: 74
MDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond reputeMDT has a reputation beyond repute
For all you Ebay folks, be on the look out for an "induction ammeter". They used to make them for automotive use years ago. NAPA and Sears had one that was dual range, 0-75 and 0-400 amps. You "saddle" your wire with them and they will tell you how many amps are going which direction. You don't have to pull any wires loose. Blue Point makes a set of 2 gauges. They have the same range. They are great for automotive and MC use. The NAPA and Sears ones usually go for about 8 bucks and the blue streaks go for about 15. Next time you are cruzing Ebay look one up.
Don't wait 'till you need it.
Old 12th December 2006
3. Current Drain Test
If it fails the test you can isolate the problem circuit by disconnecting the circuit breakers one at a time. When the drain stops you know which circuit is the problem. Then trace it through by following each of the wires from the c breaker.
Old 11th March 2007
nativebroncofan's Avatar
nativebroncofan nativebroncofan is offline
Sportster/Buell Model: XL 1000
Sportster/Buell Year: 1979
Sportster/Buell Model #2: xl1200x
Sportster/Buell Year #2: 2019
nativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to all
I ran the charging system test up to #4 and the voltage was less this time on my 79. I have noticed that the generator light is not always comming on when the key is turned on. The generator gets polarized every time the batttery is taken out/put back in. So my voltage regulator is toast now. Not suprised that it is non functioning after all the battery issues that I have had.
If I keep the battery on a trickle charge to have enough voltage to get it started will I be doing any damage to any thing else while I save the money for a new voltage regulator?
Getting sick of push starting the old steed but ya gotta do what ya gotta do right?
NBF
⛓ ALL CHAINED UP ⛓
Old 12th March 2007
Originally Posted by nativebroncofan View Post
1. I ran the charging system test up to #4 and the voltage was less this time on my 79.
2. I have noticed that the generator light is not always coming on when the key is turned on. The generator gets polarized every time the battery is taken out/put back in.
3. So my voltage regulator is toast now. Not surprised that it is non functioning after all the battery issues that I have had.
4. If I keep the battery on a trickle charge to have enough voltage to get it started will I be doing any damage to any thing else while I save the money for a new voltage regulator? ...
1. What was the actual voltage reading, [i] at idle and [ii] at 2000-3000 RPM?
2. I am not really good at understanding how the electrical stuff works, especially the oil and gen lights. But i think the gen light should come on every time. I wonder if there is a problem with the circuit. See what someone else has to say about this.
3. Did you do step 5 to test the reg? I do not see how you conclude that the reg is toast.
4. Keeping it on trickle charge will not hurt anything. Running with a bad reg can damage the battery. Not a good idea to run with a bad reg.
Old 12th March 2007
The fully charged battery was at 12.53. With the bike at 2000-3000 it was 12.30.
I have not proceded to step 5 yet as I am not sure about the multimeter usage yet. Do I need to switch the setting on it before the test can be read correctlly? The first thing that threw me off was the coloring of the wires mine runs red, green and tan in the FM has orange, green and tan . No big deal just treat the red as orange. I suppose that I jumped the "gun" by assuming that the regulator is bad.
I have a back up battery ready for when I get this situation straightend out.
Running with a bad regulator would cause the battery to have less charge all the time? Thus, shortening it's lifespan?
NBF
Old 12th March 2007
Smile
1. The fully charged battery was at 12.53. With the bike at 2000-3000 it was 12.30.
2. I have not proceeded to step 5 yet as I am not sure about the multimeter usage yet. Do I need to switch the setting on it before the test can be read correctly? The first thing that threw me off was the coloring of the wires mine runs red, green and tan in the FM has orange, green and tan . No big deal just treat the red as orange. I suppose that I jumped the "gun" by assuming that the regulator is bad.
3. I have a back up battery ready for when I get this situation straightened out.
NBF
1. OK, definitely not charging. Need to test both the reg and the gen as in the Sticky.
2. The three types of tests done most often are direct current voltage [DCV], continuity, and resistance [Ohms]. The ACV [alternating current volts] section may be useful in the home but not on the bike. I have not yet had any use for the current [amps] section.
For DCV i always choose the range 20 which will read anything less than or equal to 20 volts; usually get between 0 and 14.x. The reg test calls for checking resistance; if you are unsure of which range to use [select the highest, connect the probes, turn it on], choose lower ranges until you get a number. [] can be in any order.
3. The reg contains 3 circuits. What gets wrecked depends on which circuit[s] are broken. A typical result with one of the circuits broken is that the battery loses all charge overnight. A different circuit broken will cause the battery to be charged way to high [15, 16, ... volts] and get wrecked.
