Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
Last Post: 72 Ironhead XLH
0 Blow thru setup
Last Post: Sideshift92
0 -75 ironhead, My first HD
Last Post: blindfredy
0 91 oil in cam cover
0 Safe to run 2 master links?
Last Post: Reverend G
Old 31st December 2008
TimberwolfZ28 TimberwolfZ28 is offline
Sportster/Buell Model: Ironhead XL
Sportster/Buell Year: 1985
Other Motorcycle Model: Dyna Low Rider
TimberwolfZ28 is an unknown quantity at this point
Default Your latest FNG
Hey all. Just bought a 1985 XL. Doing lots of research and google kept leading me back here. Finally XLforum had enough and told me I couldn't look for free no more
So here I am, and here it is:
Or at least that's how it WAS... Lots of parts flying off and I am making a lit of things to sell, so holler if you need anything (wheels, tires, fenders, swing arm, front end, bars, controls, mids, plus a ton of dyna and triumph parts, engine, frames, etc)
Here's how it sits as of tonight:
Hope you all don't mind if I resurrect an old topic or two to ask questions. I was already browing the primary removal topic from a month or so back... now off to find info on engine removal. That rear trans/motor mount has me scratching my head a bit.
Bummer about the picture thing. I'd like you guys to see what I was doing, and I always like to see others projects too. And I refuse to mess with photobucket or the like because they are bandwidth limted and I have my own server. oh well..
flathead45's Avatar
Sportster/Buell Year: 86
Other Motorcycle Year: 1945
5 and you can post pics, not 15
and welcome from Wisconsin
"lord of the Night Lite"
thank god for darwin ;)
66xlch 66xlch is offline
Master Bike Builder
Sportster/Buell Year: 66
Sportster/Buell Model #2: 67 XLH, 63 XLCH
Sportster/Buell Year #2: 67
Other Motorcycle Model: FXRT
Other Motorcycle Year: 91
66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about
The rear mount is no biggie. Just unbolt it, and lift the mill out from the right side, kind tilting it to clear the sump. '85 was the last ironhead. It has an alternator built into the clutch shell, same as 4 speed EVO XLs.
I think they have a sticky or a thread on posting pics. I thought I posted pics after only 4 posts, but I could be wrong. Maybe in the FAQs?
Anyways welcome to the forum, I'm sure you will find lot's of answers to any questions here!
cybrdyke's Avatar
cybrdyke cybrdyke is offline
Location: Way back up in the woods among the evergreens
Sportster/Buell Model: xr1200
Sportster/Buell Model #2: XLS Heavy Mods
Sportster/Buell Year #2: 1982
Other Motorcycle Model: FLHRS Road King Custom
Other Motorcycle Year: 2007
cybrdyke has a spectacular aura aboutcybrdyke has a spectacular aura aboutcybrdyke has a spectacular aura aboutcybrdyke has a spectacular aura aboutcybrdyke has a spectacular aura aboutcybrdyke has a spectacular aura aboutcybrdyke has a spectacular aura aboutcybrdyke has a spectacular aura aboutcybrdyke has a spectacular aura aboutcybrdyke has a spectacular aura aboutcybrdyke has a spectacular aura about
Twolf, Welcome from Cleveland. You should be able to post pics after 5 or 6 posts, so post away. Also, check the sticky's at the Ironhead main page for tons of topics that will probably be useful to you. the guys here are super knowledgeable and very helpful.
OK, but...what does the lever on the right side do?
Brad's Avatar
Brad Brad is offline
Senior Master Bolter Oner
Welcome from a rubbermount!
My cyclography
Sportsterpedia
brokebastardracing
joesporty.com
boilermaker's Avatar
boilermaker boilermaker is offline
Sportster/Buell Model: 81 sporty
boilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really nice
You can just lay the bike over on its left side (Primary) un bolt everything Lift frame off of motor lot easier on the Back especially if you work by yourself
sesenta y ocho
good tips so far! Keep them coming!
I'm from Southern Michigan (Battle Creek) by the way...
As far as the rear mount goes, it looks like there about 8 bolts, with a few coming from inside the primary... is that the case? there's 4 going straight front to back, two into the top of the trans, and then it appears maybe two more going into the primary area.
Also, I pulled all the bolts from the primary cover and it doesn't seem to want to budge. I go the front to pop free from the gasket sauce, but the rear is tight. I pulled the adjuster plug from the clutch area, and didn't see anything that would be hanging it up.
I read about actuating the clutch and it would pop free... is that the case? What's the bolt coming down from inside the cover with a lock nut on it?
The "bolts" coming out of the case are studs and there should be 3 Studs
ok, edited the original post to include pics
