0 There’s shade tree brakes; then there’s the dark side of shade tree
Last Post: ss396
0 first engine start after rebuild
Last Post: Sprtstr1200s
0 Shovelhead forum gone?
Last Post: gpydeski
Last Post: JensWest
0 Did I buy the wrong length chain?
Last Post: 83XLX
Last Post: Heff
Last Post: BILLETPROOF
0 New England 2018
Last Post: The Crusher
Last Post: Martysf
Old 5th January 2009
Atomic Punk's Avatar
Atomic Punk Atomic Punk is offline
Sportster/Buell Year: 07
Other Motorcycle Model: Road King Classic
Other Motorcycle Year: 08
Atomic Punk is on a distinguished roadAtomic Punk is on a distinguished roadAtomic Punk is on a distinguished road
Default Foolin' your O2 Sensors
Factory Air Fuel Ratio is set at 14.7:1, thanks to the EPA. I would like my bike to run a little richer, but don't wanna drop big bucks for a fuel management system. Was looking into Xieds and thinking about going that way , but then I noticed a DIY page on Nightrider web site where you could fool your O2 sensors into the 14.2:1 range with less than $10 worth of parts from a electronics store. Anyone tried to make your own Power Divider? Did it work? Thanks
FoxsterUK's Avatar
A mate did this for another bike and it worked fine. He's a bit ham-fisted and made a mess of the O2 lead by cutting into it and soldering a resistor in place so he ended up buying a Xied-type lead anyway.
So, yes, it does work but you might find buying a lead more convenient.
Fox
ColinB ColinB is offline
Sportster/Buell Model: 883R
ColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond repute
It's not the resistors that are the trouble...it's finding the connectors that seems to be the problem.
Gary7's Avatar
Gary7 Gary7 is offline
Sportster/Buell Model: XL883 (traded)
Other Motorcycle Model: FXDC Super Glide
Other Motorcycle Year: 2009
Gary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the rough
Just spend the $69.95 and buy his 02 IEDs. It's a lot easier than trying to build your own, and they do work.
FrankBlack FrankBlack is offline
Other Motorcycle Model: Triumph Bonneville
Other Motorcycle Year: 2007
FrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really nice
Question
What A/F ratio do you get with those leads?
Gary7's Avatar
With the $69.95 ones (02 IED) you're going to get about 14.2, which is really ideal for improved performance/cooling and fuel economy.
Once I get my FXDC broken in good, I'm going to put a set on it. I can already tell she's not happy running so lean (even though the 09s are running a little richer than 14.7 from the factory).
Old 9th May 2009
OilBurner's Avatar
OilBurner OilBurner is offline
Sportster/Buell Model: Sportster XL1200C
Other Motorcycle Model: BMW R1200R
OilBurner has disabled reputation
I just did this mod as found on nightrider.com/biketech/hd2007HD_nbo2_volt_divide.htm. For the $5 in parts from FRY's and a little time I saved alot of $$$ and acheived the same results. I cut the wires coming frim the sensor to install the 10kohm and 20kohm resisters and put heat shrink over it all. you cant even see that it was modified...
the results for my engine is that it runs alot smoother at idle and quieter overall (lower pitch exhaust I think best describes it) with more power that seemed to be a little more responsive to throttle movement. I lost about 1-1/2 mpg and the temperature went down ~5-10 degrees
Well worth it for the $5 investment
