0 Ironheads
0 Salutations y'all
Last Post: Fridge
Last Post: Vohnsen
0 67 Sportster build
0 There’s shade tree brakes; then there’s the dark side of shade tree
Last Post: sdsbassist
Last Post: Grumpy-Biker
0 no rear brake light
Last Post: geoff
Last Post: goblin_dust
Old 16th October 2006
drhooligan's Avatar
drhooligan drhooligan is offline
drhooligan has disabled reputation
Default 497 vs. 536 with stage 2 883 heads.
I have an 05 1200 conversion using the SE reverse domes and SE jugs. Currently running the stock 883 heads with bolt in ..497 cams. Exhaust is the SE II but may opt for a Thunderheader later. I will also be upgrading to a Twin Tech Ignition module.
My 883 heads will soon be removed and on their way to NRHS for a Stage 2 job. The next consideration is cams. Should I continue to run the .497s or replace with the .536s? A friend of mine has the .536 new in the box that I can have very inexpensively. Any suggestions? Thanks for input.
Rothlisburgh PA
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
At Stage 2 the heads can definitely take advantage of the additional lift of the .536's. High lift flow increases dramatically with port work and bigger valves.
The .536's will work best with a little more compression than the 497's.
Both grinds have a fair bit of overlap so your result will be heavily influenced by the exhaust system, but more so with the 536's.
You'll likely have to clearance the exhaust pocket slightly to avoid piston to valve contact with the 536's.
Click Here to Contact Me
drhooligan's Avatar
Thanks for the advice. Wish I new about you guys and the other options 2 years ago when I went with SE conv. stuff. I may just start over and go with the 1250 kit and XB heads. I'll call you guys soon.
Old 8th November 2006
MakuaKane's Avatar
MakuaKane MakuaKane is offline
Sportster/Buell Model: 1200 Roadster
MakuaKane is on a distinguished roadMakuaKane is on a distinguished road
Was there a problem with the 536's contacting the piston? Dan at NRHS has written me and said that the 536 would give me good performance with my stage one set-up (see below) and would really give great results with the stage two that's in the works. I was planning on installing them as soon as I had the spare $$$.
"Nobody made a greater mistake than he who did nothing because he could only do a little."
- Edmond Burke
[URL="http://xlforum.net/photopost/showgallery.php?cat=500&ppuser=4676"]View My Gallery[/URL]
[FONT="Palatino Linotype"]2006 Sportster Roadster (yellow pearl), Thunderheader, Forcewinder A/C, 48 slow jet w/2.5 turns out on the mix screw, 200 main jet, 1 brass shim under the needle, TwinTec tc88a igniton module and coil, Krankvents, ISO grips, and Progressive 412 shocks and fork springs, and a few other doo-dads.[/FONT]
tonyhds's Avatar
tonyhds tonyhds is offline
Sportster/Buell Model: NRHS 1250 C
Other Motorcycle Model: Road King Classic
tonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of lighttonyhds is a glorious beacon of light
Is that because of the reverse dome pistons ?
04 Road King Classic
04 NRHS 1250 Custom - Longhorns Orange
10.3-1 Flat tops, Stage 2 heads, Powdercoated black w/ highlighted fins, SE 497 cams, TC88A ignition w/ a custom Map, 2" HurricaneFlow intake, 1200 gearing, Energy One clutch, Progressive 418's and Progressive front springs, Mustang Vintage and loves oil.
aka " The Guzzler "
" A song needs to breathe. The rhythm needs to breathe. Sometimes the best way to get some punch out of something is to slow down right before you hit it. Kind of like a slingshot --- Pow "
SRV
Old 11th November 2006
MakuaKane's Avatar
Default Any takers on our cam questions??
Old 23rd November 2006
Mikel_NY's Avatar
Mikel_NY Mikel_NY is offline
Sportster/Buell Model: XL883 w/ 88"
Sportster/Buell Model #2: wife's 883
Mikel_NY is on a distinguished roadMikel_NY is on a distinguished roadMikel_NY is on a distinguished roadMikel_NY is on a distinguished roadMikel_NY is on a distinguished road
I think that the 883's have longer valves that need the clearancing and your 1200 heads using a shorter valve stem may not be a problem in the same situation. To get a 100% answer call NHRS and ask for Dan.
'06 Chopper Blue XL883 Converted...... (88")
D&D 2-1 exhaust * Redshift 630/585's * Mikuni 45mm * Roller Rockers * Oil cooler * Thunderheart Digital ignition
Shrader valves on forks * 27"drag bars * 4.5" pullbacks w/ 1.5"risers * Xena mod Speedo * (2-up & pegs * Removable Back rest...for the kids)
In the works: 4" swingarm w/ 17 x 5.5 - 180 rear tire (to hold the front down.)
Old 24th November 2006
jrazo's Avatar
jrazo jrazo is offline
Sportster/Buell Model: 883 XLC, now 1212
jrazo is on a distinguished roadjrazo is on a distinguished roadjrazo is on a distinguished road
FYI...aswracing is NRHS. Aaron's answers and advice are sound and proven.
Remember when you have increased lift at the cam, this causes the valve to open farther, and with longer duration, the chance of piston to valve contact increases as well. Clearancing of the exhaust pocket essentially deepens it to prevent this contact.
This is how I understand it, if it is off please correct me.
883->1212 NRHS reverse dome, SE .497 cams, SE 1200 ICM 7000 rev limit, stock heads, Screamin Eagle SP Slash outs.
[SIGPIC]http://www.xlforum.net/vbportal/forums/signaturepics/sigpic4931_1.gif[/SIGPIC]
Mikel_NY's Avatar
Thank you ..... knew that
