Last Post: Magneto Sportster
Last Post: Wilkinson949
0 Floppy kickstand spring issue, 1991 model
Last Post: seajay
0 A different Oil filter test
0 WTF Happened
Last Post: walterxlh
0 What is the best '70's Ironhead to restore
0 hi from anchorage AK
0 Runs rough on highway.
Last Post: wrkdWS6
Last Post: Airbozo
0 Mainshaft bearing
5 Why Are You Still Married?
Last Post: wrkdWS6
Last Post: Eddie Lives On
Last Post: 83XLX
0 The Multi-tool thread
Last Post: Bassel
Last Post: 83XLX
0 Project Strociek
0 Seized Oil Pump
Last Post: marklocklear
0 900 dual carb front head
0 If You Have An '04+ (Buell's too), Please Read (Oil Usuage)
Last Post: JaKaL
Old 10th March 2005
0ut1aw 0ut1aw is offline
0ut1aw is an unknown quantity at this point
Default Ignition Module Question
OK this is probably a really stupid question but here goes
I have a 2002 883 and purchased an SE 32632-96 ignition module pkg says fits 96 and up 883s.
First question -- Does it fit a 2002 883
if so can anyone tell me where to find install instructs
Thanks in advance
Old 10th March 2005
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Not stupid...only because you asked!
Welcome...I'm gonna watch this one myself....I have an '02 as well.....
There are guys here who know how to confirm this better than I, but I have to believe it will....
As for instructions...do you own a manual?
~Chuck
Occam's Razor...
XLF Tuning Stickies
Old 10th March 2005
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
The 32632-96 is an 8-pin module. I'm pretty sure your bike uses a nose cone module, they switched to nose cone modules in '98. If I'm right, installing it would require using a standard pick-up unit, finding a place to mount the module, and a bunch of rewiring. Personally I wouldn't mess with it, but it can be done.
Old 10th March 2005
cantolina's Avatar
Do you mean the diff. between the ignition modules that have both black and white connectors (mounted on the frame) and those in the gearcase with wire attached??
Old 10th March 2005
gamhill gamhill is offline
gamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura about
By doing a search for 32632-96 http://www.surdyke.com site, it says that it fits '96-'97 XL 883 models. According to H-D's site - 32979-98A fits '98-'03 XL 883 models, and lists for $119.95.
Old 10th March 2005
aswracing's Avatar
An 8-pin module looks like this:
They typically mount under the seat.
Some of these modules will have an extra couple wires that don't go through the 8-pin Deutsch connector. If the module supports single fire (this one doesn't), it needs more wires because it has to provide a separate primary signal for the other coil as well as a tach signal (since each primary outputs are each running at half frequency in a single fire arrangement).
A nose cone module looks like this:
These things integrate the ignition module and the pickup unit into one handy package that goes in the nose cone of the gearcase.
HD went to nose cone modules in Sportsters beginning in '98. Retrofitting an 8-pin module, or it's predecessor the 7-pin module, is doable but a hassle. Gotta put in an old style pickup unit and wire in an 8-pin connector and figure out how to mount the thing.
The color codes on the wires are pretty standard, though. From memory, 8 pin modules look like this:
red, green, & black go to the pickup unit
pink is the primary signal (to one side of the coil)
white is the power (generally leads to the other side of the coil, where a wire from the handlebar switch meets it and provides power).
purple is the VOES switch input (grounded = high vacuum)
and there's a ground in there somewhere.
Only 7 pins of the 8-pin connector are used.
Wouldn't be surprised if the factory nose cone modules have similar color codes.
In '04 of course they eliminated the nose cone module and went to the TC88 style module that works off a crank trigger.
Old 11th March 2005
Confirms what I feared.....
probably not the right place but.
Anyone want to buy it... new but package removed
shoot me an email if you do
Old 9th April 2005
kntalan's Avatar
kntalan kntalan is offline
kntalan has disabled reputation
So am I right in thinking the my 2003xlh 1200 has a "SINGLE FIRE" module in the nose cone. And if i want to replace it, then I would get a single fire module?
thanks...Tom
Old 9th April 2005
maddog's Avatar
maddog maddog is offline
Sportster/Buell Model: Hugger 883/1200
maddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura about
thanks...Tom
No... '03's are still Dual Fire, nosecone or not. If you do get a Single Fire Module you have get Single Fire Coils as well.
Night Train + Street Fighter= NIGHT FIGHTER
MY GALLERY
"It's just a Sportster, but I'm saving up for a Big Twin."
That's like saying...
"It's just a Corvette, but I'm saving up for a Station Wagon."
STEPHANIE FELD
HOT XL MAGAZINE
SUMMER '97
He was asked, "Why do you ride?" He considered the question carefully for a few moments. "The Lean", he replied.
Old 9th April 2005
HotRodSporty's Avatar
HotRodSporty HotRodSporty is offline
Sportster/Buell Model: Custom 1200C
Sportster/Buell Model #2: I wish
HotRodSporty is an unknown quantity at this point
Thanks in advance
I had to ask the same thing 2 weeks ago outlaw, and now I have two ignition modules. The exact Dyna in the pic and a screaming Eagle selectable for the nose cone. I hope you asked before you baught instead of having to buy two of them like I did.
Oops, I just read the rest of your post, guess we are in the same boat. I baught both of mine off ebay so I have two for the price of one pretty much.
Similar Threads
'Initializing' a new SE ignition module? > Turbota Sportster Motorcycle Electrical and Ignition 43 24th October 2013 16:36
SE ignition module / Start problems SilverSporty Sportster Motorcycle Motor - Top End 24 11th October 2008 15:59
Ignition module installation madisonlink Rubber Mount Sportster Motorcycle Talk (2004-2006) 2 28th February 2005 18:08
Ignition module Lukas O Sportster Motorcycle Engine Conversions 6 20th January 2005 12:45
Sportster/Buell conversion ignition question?? sportster883r Sportster Motorcycle Engine Conversions 6 7th January 2005 04:43
