0 2016 Sportster Rear Wheel Removal w/ABS Brakes
0 Slip on muffler
Last Post: Tucsonmax1
0 Decman's Birtday
0 New member in MD
Last Post: RKN
0 Dissembly and Assembly of starter shaft nut on Ironhead
Last Post: blk80bike
0 acc pump
Last Post: lwh1950
0 What's your helmet?
Last Post: 83XLX
0 Rear tire
Last Post: 83XLX
0 Ironhead 2 into 1 exhaust?
Last Post: Iron John
Old 7th January 2009
mwchut mwchut is offline
Sportster/Buell Model #2: XL883-1200 Convert
Other Motorcycle Model: Honda Rebel 250 Moped
Other Motorcycle Year: 1985
mwchut is on a distinguished roadmwchut is on a distinguished road
Default 2007 with an empty primary
My wifes 07 sportster seems to have leaked out its primary oil. We suspect the bike got about 100 miles on with an empty primary. Is it worth ripping the side of the motor open to see if there was any residual damage or just fill it back up and see if I can figure out where its leaking?
bigjnsa's Avatar
bigjnsa bigjnsa is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: BMW R1150R
bigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to all
Nah, fill up the primary, go for a ride to warm it up, park it in the garage with some cardboard undernearth to check where it leaks.
aka - 'Bubba' of the Hells Beerguts MC
When we ask for advice, we are usually looking for an accomplice.
Marquis de la Grange (1639 - 1692)
[SIGPIC][/SIGPIC]
How can a bike leak a FULL QUART OF OIL without someone noticing?
How new is this bike? You sure someone didn't F@#$ up during a service?
Regardless, that's NOT JUST primary oil, that's transmission oil too.
And IF damage was done the motor has to come out of the frame and disassembled to split the cases.
Therefore, NO, it's not worth ripping into it to find out IF damage was done, because you'll find out soon enough.
Meanwhile, are you SURE it's COMPLETELY EMPTY?
It was making a bit of a whine so I went to drain the oil and only got about a pint out of it.. One assumes the rest of the space in there is air. I am going to send her down to the HD dealer to get some oil. It may have been a service issue at the 1k service which was done and not a leak now that you mention it. In which case I am going to make sure this gets documented with them in case it creates a mechanical issue.
bigjnsa's Avatar
Only a pint? Sounds to me like they drained it but never filled the primary. Hopefully the primary isn't too badly damaged.
A pint?
Did you drain it into a measuring cup or an oil bottle to be sure?
if it's about a pint, that's ABOUT half of capacity.
Remember the transmission and primary aren't FILLED with oil, they have an oil level which is achieved with only one quart (spec used to be 28 oz).
So before you get too worried about it, a pint is within 16oz of full. Double-check your calibrated eye.
And even if so you PROBABLY didn't do much wear or damage.
But IF it's really only a pint, for sure document it.
And keep an eye on it. Even a pint of leaking fluid though would make a large puddle on the average garage floor/parking spot.
I drained it into a measuring cup so I am pretty sure it's about a pint.... Good thing she hasn't been out riding..
daggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to all
thats a big miss on the MOCO's end. if she is past the breakin mileage i would fill her up and run the shit outta her, if you still have a warrenty, getting it documented is a really good idea, be carful though, the moco will do anything to NOT claim responsibility
Yeah, then make sure it's documented!
Is it necessary to refill from the inspection cover or can it be done from the chain adjustment cover?
