0 strange small wires attached to coil
0 24633-77 Breather assembly
Last Post: ericfreeman
5 Transmission HELP!
Last Post: Twistedrench
0 Sportster or Street Bob
Last Post: Baby883
0 Ei
Last Post: tvon
0 Solar battery charging
Last Post: tvon
Last Post: wachuko
0 primary chain temp.
0 2016 48 Hesitating
Last Post: XLXR
Last Post: prahxy
Last Post: hhugger
Old 14th January 2009
Gary7's Avatar
Gary7 Gary7 is offline
Sportster/Buell Model: XL883 (traded)
Other Motorcycle Model: FXDC Super Glide
Other Motorcycle Year: 2009
Gary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the rough
Default Installed footboards on my Super Glide
I put the FXDP footboards on my Super Glide today. Wasn't able to ride very far after I got 'em on but so far I LIKE! You can put your feet in either a mid position, or stretch 'em out to where they would nearly be if you had forward controls. Also, the mid foot pegs let quite a bit of vibration get through to your feet. That's totally eliminated with the footboards.
Old 15th January 2009
Thornhammer Thornhammer is offline
Sportster/Buell Model: 883C Pewter Pearl (gone)
Other Motorcycle Model: SuperGlide Custom
Thornhammer is on a distinguished roadThornhammer is on a distinguished roadThornhammer is on a distinguished road
C'mon, dish! Did you have to do anything special to mount them?
Caved to the little devil on my shoulder. Traded the Sportster in on an FXDC.
Cindy Dietz's Avatar
Cindy Dietz Cindy Dietz is offline
Sportster/Buell Model: 883=>1200 Low
Cindy Dietz is a glorious beacon of lightCindy Dietz is a glorious beacon of lightCindy Dietz is a glorious beacon of lightCindy Dietz is a glorious beacon of lightCindy Dietz is a glorious beacon of lightCindy Dietz is a glorious beacon of lightCindy Dietz is a glorious beacon of lightCindy Dietz is a glorious beacon of lightCindy Dietz is a glorious beacon of lightCindy Dietz is a glorious beacon of lightCindy Dietz is a glorious beacon of light
I put floorboards on my sporty. Wrote a blog about it, showing the installation, if you are interested:
08 Installing Floorboards on my 05 883 Harley Davidson Sportster, Effie.
Cindy Dietz
Greensboro, NC
Effie 2005 883=>1200 LOW
IBA #23594
Winner of HOG's 2006 ABC's of Touring
My Travel Blog
Gary7's Avatar
Well, unlike Cindy's install on the Sportster, the floorboards I put on my Super Glide are genuine Harley parts. They came std on the old FXDP Defender model, which was the Dyna police bike.
These boards will bolt right to the existing mid mount points and the forward mount points on the newer 06-09 Dyna models. The only thing that won't work is the forward shifter hardware that came on the FXDP. The mounting points for that don't exist on the newer frame and engine. That's why I just used an extended shifter mounted to the mid-mount shift spline.
Harley used to sell this whole set up as a kit, but they no longer do. But all the parts are still available. If you know the part numbers, you just order each individual part, which is what I did. Here is the list:
Items from Harley instruction sheet #J01921 (The number preceding the item is the item number from the assembly directions, NOT how many of that part you need.):
3 Socket head cap screw, self tapping (Quantity 8) 3214
(Only need 4 of these if you reuse the bolts from your existing mid mounts.)
18 Assembly, right front footboard 50521-01
19 Right rear footboard support 50526-01
20 Left front footboard support 50529-01
21 Left rear footboard support 50530-01
22 Assembly, footboard (Quantity 2) 50632-85
23 Shoulder bolt, 1/4-20 x 1 (Quantity 4) 50635-82A
29 Lockwasher, 3/8" (Quantity 8) 7045
31 Flange nut, 1/4-20 (Quantity 4) 7716
Updated items from the 2003 FXDP manual (needed because of updated brake pedal design--again, the number preceding the item is the item number from the manual, NOT how many of that part you need.):
1 Cotter pin 515
3 Screw, 3/8-16 X 1 Torx 4059
4 Washer, 1/4" 6099
6 Washer, 7/16" 6516HW
7 Washer, 3/8 X 13/16 X 1/16 (Quantity 2) 6701
9 Hex jam nut, 5/16-24 7744
10 LOCKNUT 7/16-14 X 21/64 X 5/8 hex 7827W
14 SHAFT, pivot 33689-02
16 Assembly, Brake pedal 33711-02
17 WASHER, spring wave 34641-01
26 Linkage, rear brake push rod 41954-01
29 Pad, brake pedal 42416-83
31 Clevis pin 42460-80B
jcopel jcopel is offline
jcopel is on a distinguished roadjcopel is on a distinguished road
Probably a silly question, but I'm too busy for any research this morning. Is that, by chance, the Mustang seat off of your Sporty? I'm assuming the Sporty seat would not fit the Dyna. Also, do the compact saddlebags from Don's fit on the Dyna Glide? I use those on my Sporty also.
Your new bike is sweet. I'll still haven't jumped, yet. Still struggling with what I want to do. If I keep what I have, are you going to sell your old windshield? Was it the detachable?
Gary7's Avatar
Thanks. This bike is a blast to ride and look at, and I don't regret for a minute trading the Sportster in on it.
Seat is new. Sporty seat won't fit on a Dyna.
Don's saddle bags don't work too well on the Dyna. That's why I've got 'em for sale in the Classified section.
Windshield is already sold.
el jinete fantasma's Avatar
el jinete fantasma el jinete fantasma is offline
Sportster/Buell Model: XL1200N-Traded :(
Other Motorcycle Model: Harley Fat Bob
Other Motorcycle Year: 09
el jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really nice
Looks good!
Edward
Pasadena Motorcycle Club
http://pasadenamc.com
Old 16th January 2009
mjbogrand mjbogrand is offline
Senior Bike Builder
mjbogrand has disabled reputation
Used those on my ironhead.Let them go with it 'cause at about 240,seemed kinda light weight for me.Loved the look though.
BTW Gary7 nice work.There is a way to do this to a sporty.I just been riding and painting too much to care!
