0 LePera Kickflip
Last Post: icebob
0 What's your helmet?
Last Post: Grymy
0 what do you think of these plugs?
0 A Day in the Life...
0 2016 48 Hesitating
Last Post: XLXR
0 'Idiot Lights' plastic face
Last Post: Edster
0 Cartridge Conversion?
Last Post: XLXR
0 Flirting with death
0 Tried to buy a new helmet
Last Post: kap
0 Tank swap
Last Post: Grymy
0 Oil Hose replacement help.
Last Post: McQueen
Old 28th October 2006
Clarinetcat's Avatar
Clarinetcat Clarinetcat is offline
Clarinetcat is a glorious beacon of lightClarinetcat is a glorious beacon of lightClarinetcat is a glorious beacon of lightClarinetcat is a glorious beacon of lightClarinetcat is a glorious beacon of lightClarinetcat is a glorious beacon of lightClarinetcat is a glorious beacon of lightClarinetcat is a glorious beacon of lightClarinetcat is a glorious beacon of lightClarinetcat is a glorious beacon of lightClarinetcat is a glorious beacon of light
Default 19" Mag wheels for DYNA?!?
Would a 19" 3/4 axle hole front mag wheel for a Dyna work on a Sportster? I would like to (hopefully) change out to a 19" front wheel sooner rather than later, and I have thought about taking a mag wheel and powder-coating it black.
Any opinions, thoughts, or suggestions would be greatly appreciated...
Thanks in advance for responding!
Roadster_Rider's Avatar
Roadster_Rider Roadster_Rider is offline
Other Motorcycle Model: Victory High-Ball
Roadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura about
I believe for your bike the 00-05 dyna wheels will fit. Not 100% on this though.
Cory
Yeah RR, I'm thinking it should work, but I wanted to ask here be sure before I bought something that won't end up fitting properly.
Any one else done this, or know if it should work?
Gone Gone is offline
RR is right. Dyna wheels from '00-onward will fit your bike.
Actually, the earlier ones will fit too if you carry over the rotors.
Didnt it switch to sealed bearings in 00? could you reuse your stock sealed bearings in a wheel made prior to 00?
Originally Posted by cleger
RR is right. Dyna wheels from '00-'05 will fit your bike.
Once again Chris, I sincerely appreciate your response.
Also, please check your inbox for a PM from me... thanks!
...except wheels from a wideglide. OK I think that covers it!
Yeah, but the earlier tapered bearings will work on his (everyone's) axle. The only change the sealed bearings necessitate is to the later rotors, which have a larger 2.215" center bore versus the earlier 1.975". You can't re-use the sealed bearings, you just switch to tapered ones.
You really can't re-use sealed bearings in any case. They're damaged upon removal.
You caught me before I could correct my post.. I was quoting RR... '00-present will fit.
