0 Tap extention?
Last Post: T. Clark
0 Tank swap
Last Post: Grymy
0 How do you upshift?
0 Lowboy frame conversion
10 Anyone else noticed this? (Horn Closes Choke)
0 Oil Hose replacement help.
0 Spokes or Mags
0 New From CA
Last Post: jcro61
Last Post: MXHD55U
Last Post: Crosshairs
Old 11th March 2005
mcevoy mcevoy is offline
mcevoy has disabled reputation
Default turn signal to brake light conversion harness
2001 1200Custom. talked to HD store and was informed that the harness will fit 2002 and above. Anyone have any thoughts on this---trying not to get rear-ended.
Old 11th March 2005
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Does that make your turn signals come on with the brake? What flashes when you're turning? I've never seen this....
I was wondering about a stop-strobe, myself....I wonder if that's legal?
At any rate, I'm all ABOUT lights...whatever makes you be SEEN...
Personally, I'm going to put a stop light on my sissy bar, I think....if I can find something I like........
~Chuck
Occam's Razor...
XLF Tuning Stickies
Old 11th March 2005
Ole's Avatar
Ole Ole is offline
Sportster/Buell Model: Umm
Sportster/Buell Year: Yah
Other Motorcycle Model: UltraClassic Electraglide
Other Motorcycle Year: 2010
Ole is a splendid one to beholdOle is a splendid one to beholdOle is a splendid one to beholdOle is a splendid one to beholdOle is a splendid one to beholdOle is a splendid one to beholdOle is a splendid one to beholdOle is a splendid one to beholdOle is a splendid one to beholdOle is a splendid one to beholdOle is a splendid one to behold
Default Lighting...
Yeppers...got it on mine. Harness is the same as yours but you've got the football type lenses I believe...that's the only thing holding you up. Check out your local dealer for red football style lenses for your '01. They should be able to order them...HD part# 68416-99. You can buy the newer kit, pitch the lenses that come with it and use the other lenses. It'll cost you an extra $5-$10 buck but hey, you'll be seen better.
Outboards now have red lenses and come full-on when braking. If you're turning then the one on the side that you've got your flasher on will flash just like normal. Also, check the tailBlazer out...
I've seen these before...is this the type of thing you're talking about?
Ole - 2010 Geezer Glide Ultra - Roberts, WI - U.S.A.
Old 11th March 2005
cantolina's Avatar
I really like this idea....a lot....but I'm not ok with the eventual "steady-on"
Sort of....I have a chrome skull with red eyes and nose that light up....it was originally a trailer hitch cover that I really want to convert into an aux. brake light on the sissy bar...It's awesome..
Old 12th March 2005
TechRep's Avatar
TechRep TechRep is offline
TechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of light
I have the conversion kit installed and think it works great. I like having more brake lights.
I also installed the lighted (LED) turn signial mounts.
Old 12th March 2005
cantolina's Avatar
I'm now going to try a new lamp type.....it flashes in a small circle when riding, then flashes when you stop....I like this a lot...
check it out here: http://cgi.ebay.com/ebaymotors/ws/eB...tem=4534543643
anyone had experience with these?
Old 12th March 2005
engine's Avatar
engine engine is offline
Sportster/Buell Year: 1989
engine has disabled reputation
I got a SUPER bright LED tail light. Almost blinding...good to get attention when braking. I also bought 3-wire Deuce style bullet turn signals (stock bullet look). These have 2 filament 1157 bulbs in them. Right now I wired them to only use the hi-filament for turn signals. I also have the option to wire them as running lights with turn signals, where I'd have to use red lenses (included in the kit), or as mentioned previously, I can wire them to my brake light and have them as extra brake lights, and a turn signal as well. Lots of options.
this is a pic of the tail light, with running light only (not brake light)
Old 12th March 2005
cantolina's Avatar
Originally Posted by engine
I got a SUPER bright LED tail light. Almost blinding...good to get attention when braking. I also bought 3-wire Deuce style bullet turn signals (stock bullet look). These have 2 filament 1157 bulbs in them. Right now I wired them to only ise the hi-filamebt for turn signals. I also have the option to wire them as running lights with turn signals, where I'd have to use red lenses (included in the kit), or as mentioned previously, I can sire them to my brake light and have them as extra brake lights, and a turn signal as well. Lots of options.
That's awesome....never saw that before....
nice look....
still looking for my chrome skull....I know its here somwhere....
Old 12th March 2005
engine's Avatar
nice look....
IT's a Tombstone LED light, designed to fit factory fenders. I had to drill an extra hole for the 3rd mounting stud. Took 15 minutes to install.
Old 12th March 2005
cantolina's Avatar
Here's my extra running light/stop light...
Campy, I know...but I love it....
Similar Threads
Problems with light bulb in turn signal gardkarlsen Sportster Motorcycle Accessories 4 2nd May 2005 21:18
signal light out and half tail light working SkippyRay Sportster Motorcycle Motor - Top End 1 28th April 2005 14:47
Front turn signal light relocation kit Hogan77 Rubber Mount Sportster Motorcycle Talk (2004-2006) 11 18th March 2005 14:06
Turn signal light relocation questions. XLFREAK Sportster Motorcycle Motor - Top End 4 25th November 2004 23:28
