0 too bad
Last Post: Hank21113
0 Head gaskets.
0 Dynamic timing the 2000i?
Last Post: ezmerf
Last Post: robistro
Last Post: felis
0 newby from Australia
Last Post: Veeflys
Last Post: Crosshairs
0 seeking advices
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 Cream
Last Post: jakewalter
Last Post: seajay
Last Post: seajay
Last Post: JKKO
0 H4 bulb
Last Post: andy_t
Last Post: cazz1000
0 blonde, brunette, red?
0 Speedo cable lube
Last Post: JacksBrother
0 Oil use/smoking
Last Post: gpydeski
0 Nighster seat on Iron
Last Post: ed_in_az
Last Post: lo-rider
0 where are the pics?
Old 30th October 2006
Gone Gone is offline
Default speedo/tach not working
The speedo and tacho on my 04 roadster just stopped working the other day.I have removed all the fuses behind the left cover and cleaned them. They were heavily oxidised and had some minor rust evident. I then squirted some wd40 into the box before replacing them. This has not worked. Does anyone have any ideas as to the next step. I can't get into the dealer until 21/11/06.
P.S. Everything else seems to be working ok including the indicator/hi beam/ oil light panel. It is just as if there is no power at all to the speedo and the tacho
Paul's Avatar
Paul Paul is offline
Paul has disabled reputation
can you get a display on the odometer widow? If so you can do a self diagnostic
I'm not getting anything at all
Old 31st October 2006
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
I'd try tracing the wiring harness back and checking the plug-ins.
Stuff: YES
We need a wiring diagram. Is there one in the base service manual (I've never looked) or do we need the electrical troubleshooting manual for that?
Old 13th November 2006
After the advise, I got I pulled off the seat checked every connection between the battery and the speedo and tacho, Took out the speedo and tacho, had power in both connectors then confirmed by pulling fuses. I couldn't find the other end of the wires for the tacho and speedo though to see if the prob is at the sender unit. I have ordered a workshop manual but if anyone can tell me where the sender for the tacho and the speedo is I could check that
hybriDatsun350's Avatar
hybriDatsun350 hybriDatsun350 is offline
Sportster/Buell Year: '99
Other Motorcycle Model: Not yet!
hybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enough
They do use a common ground. Did you look at the ground wire?
Nick
1999 XLH1200, Vivid Black....Trimmed cam cover, Thunderheader, Ram Flo 400, Pingel petcock, forward controls, black drag bars w/4.5" pullback risers, relocated front turn signals, Progressive fork springs, 4-piston HD front caliper, and a bunch of black powdercoated stuff!
[U]Click to Enlarge[/U]
[URL=http://www.putfile.com/pic.php?img=4504798][img]http://img1.putfile.com/thumb/1/1212393091.jpg[/img][/URL]
Can you please tell me exactly where that is.
Old 16th November 2006
I couldn't find this ground wire on the tripple trees. The bike is an o4 1200 roadster, perhaps there have been changes. I bought a manual but when I read it, it said that I needed the electrical troubleshooting manual. Does anyone have one?
The problem is that it is as if the speedo and tacho are dead. I've traced through all connections, fuses etc and everything seems in good ordered and I've checked with a test light and power is in all the leads it should be. The bike is functioning perfectly otherwise.
Its just out of warrantee ( bloody typical) so I'm dreading taking it too the dealer. I will ask them to cover though as the problem started about 14 days after the warrantee ran out. If anyone has the electrical trouble shooting manual I'd be greatful if you could look up the fault for me
Old 22nd November 2006
Well I took the bike to the dealer yesterday. they say that both the speedo and tacho are dead,ie burned out. they also say that the bike has no electrical faults at all. So how did this occur? They suggested that the bike could have been tampered with. But as I am the only person to ride this bike since new, and that they suggest that a lead from the coil would have to be removed whilst the bike was going, this cannot be the cause. I would have noticed someone trying to mess with the bike whilst I was on it.
So there must be some other cause. Anyone with any idea's?
The fault occured 2 weeks after the warranty ran out. I have asked the dealer to contact Harley Australia to see if they would cover it anyway.
Their decision will be critical to my decision to upgrade the bike in the new year, ie if they cover it I'll stay with Harley, if they don't then I'll probably go back to Jap.
This should not have happened to a 2yr old 8000 km bike ridden by only one person. I hope they stand behind their products as I love riding my Harley. But given that they they just surveyed me in regards to reliability and longevity, I can't logically go forward towards another expensive purchase if they don't do the right thing by me.
I'll keep you all posted.
