0 Ironheads
Last Post: Island Dude
0 2016 Sportster Rear Wheel Removal w/ABS Brakes
0 Slip on muffler
Last Post: Tucsonmax1
0 Decman's Birtday
0 New member in MD
Last Post: RKN
0 Dissembly and Assembly of starter shaft nut on Ironhead
Last Post: blk80bike
0 acc pump
Last Post: lwh1950
0 What's your helmet?
Last Post: 83XLX
0 Rear tire
Last Post: 83XLX
Old 19th January 2009
NewAmerica NewAmerica is offline
Other Motorcycle Model: Yamaha XV750
Other Motorcycle Year: 1982
NewAmerica is an unknown quantity at this point
Default Chain Tensioner Wheels (LBV Eng., Custom Made, Etc...)
got 2 sporty rigid builds goin' on right now, i would like to use a secondary chain tensioner to gain some clearance on one of them thanks to the oil tank selection (sorry no pics right now)
here is one for a stock sportster frame made by lbv engineering
and here is a custom rigid mounted one, made by someone
in the pictures that i've seen of these things, i have noticed that they always seem to be located on the low side of the chain. for my project it would need to be the rigid style, and located on the top of the chain. Is that at all possible and what do you think the life expectancy of the wheel and bearing to be?
Also, since i would be making one similar to the second, I took a look at the materials that LBV Eng. used since i had a better close up. that wheel, a krypto impulse, is a roller skate wheel with an ABEC7 or higher bearing? really?
has anyone on the forum made a solid mounted chain tensioner like this? and can it be used on the top side of chain without being destroyed too fast?
thanks for your help in advance!
'80 XLH - Rigid Wide Tire Ironhead...
Barbie Called, She Wants Her Jeep Back...
choady's Avatar
choady choady is offline
Sportster/Buell Model: XL Chop
choady is an unknown quantity at this point
I have not seen one on the top side.
I wouldn't do it that way myself.
Think about it, that side of the chain is going to have all the pressure of the motor "pulling" the chain.
The bottom is getting pulled by the wheel not the motor.
I guess if you used some type of sprocket that could work, but then you are moving the chain, not just keeping tension like those you have pictured.
Maybe you should rethink the oil tank?
I have seen some oil tanks that have slots in them to clear the chain.
Maybe you can do that?
Good luck which ever way you decide..
Thoughts are like arrows: once released, they strike their mark.
Guard them well or one day you may be your own victim.
-American Indian Proverb
74_XLH_WINCHESTER_VA's Avatar
74_XLH_WINCHESTER_VA 74_XLH_WINCHESTER_VA is offline
Other Motorcycle Model: Sears/Gilera 106SS
Other Motorcycle Year: 196?
74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold
Default Half Pipe
Maybe take a piece of half pipe and weld it into the tank where the chain interferes to give the needed relief, that might even look pretty bad ass.
K.C.
Old 21st January 2009
choady - that's exactly what i was thinking, but just needed someone else to tell me i guess this bike's got a lot of power and the tension on the top side of the chain would most definitely tear that poor little wheel apart
winchester - that's a good idea...i think i might run with that other than just making a square (or rectangular) notch!
time to move some bungs while i'm at it...
thanks guys!
Default Another Idea
I had another idea too, but kept getting the "Server is too busy" message and haven't been able to get on. I don't know what kind of space you have, but another idea is to use a sprocket the same that is on the transmission mounted on a shaft that is mounted to the frame using pillow blocks.
Nash Motorcycles did something kind of similar to what I am talking about:
Pillow Block:
This would hold up to the load that the motor would put on the chain and the sprocket.
K.C.
yeah that "server too busy" message kept me from replying to the responses all day yesterday...
i like that nash design alot, but i think it's a little too much for this customer build...now my ironhead build, that a different story
i'm gonna read up on that some more, thanks!
VTWINSCOOT's Avatar
VTWINSCOOT VTWINSCOOT is offline
VTWINSCOOT is on a distinguished roadVTWINSCOOT is on a distinguished roadVTWINSCOOT is on a distinguished roadVTWINSCOOT is on a distinguished roadVTWINSCOOT is on a distinguished road
I need to install one of these this spring as my chain hits the bottom of my oil bag ONLY when crusing. You see- I built a custom and knew everything would be super close. As for the chain- it's about 3/4" off the bottom of the bag (yes- I recessed the bag by laying a large, deep-well impact socket lengthwise where I needed my relief and basically beat the daylights out of the socket. The result= a uniform crecent that runs parallel to where the chain travels).
Turns out that still wasn't enough room
Everythings fine under load or decel, but when crusing the chain seems to 'jump' up-n-down just enough to BARELY (but knowingly) rub the bottom of the bag!!!!
I'm prolly going to pick up a 'heavy duty' ICE unit (see here --> Chain tensioner) due to the fact that a.) it's a cog, not skateboard wheel, and b.) is adjustable. Although (IMO) a chain tensioner looks 'out of place/like it doesn't belong'... it's a necessity in my case and the ICE unit just looks more like the part belongs.
jrclark19's Avatar
jrclark19 jrclark19 is offline
Other Motorcycle Model: KTM MXC 250
Other Motorcycle Year: 1996
jrclark19 will become famous soon enoughjrclark19 will become famous soon enoughjrclark19 will become famous soon enoughjrclark19 will become famous soon enoughjrclark19 will become famous soon enoughjrclark19 will become famous soon enoughjrclark19 will become famous soon enoughjrclark19 will become famous soon enough
Default Dirt Bikes
Dirt Bikes use an upper and lower chain roller....the lower does put some tension on the chain, but the upper is positioned more for protection, just below whatever the chain is hitting. Even if you have a tight situation, as long as the roller is above the chain when it is pulled tight you should be ok. When the chain is only hitting the roller and not running over it with tension a light weight roller will do.
2004 XL 1200R, SE II, One Off K&N A/C, 42mm Flatside, TC88A(Turbota Map), 10R12 PP Plugs, NRHS Stage 2 Heads, NRHS Hurricane Forged Pistions(10.3:1), Red Shift .567(Welded #2 Gear), Jims Hydrosolid Tappets, Andrews Adj Pushrod, H-D Roller Rockers, 04A Flywheels, Barnett Kevlar Extra Plate Kit, Pingel Petcock, SYN3, Spun Alum Gauges, 1200C Headlight, One Off Rear Brake Lever, 1200S Forks,SE Fork Brace, Progressive 418 Shocks, SE Tires,Misc. Black Goodies....
Run what ya brung, and HOPE you brung enough!!!!!
Old 22nd January 2009
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
Not exactly the topic of your post, but after reading it, I think the LBV tensioner is exactly what my bike needs. I installed longer shocks (see pic of bike below), which has brought chain tensioning problems. The swingarm now angles down from horizontal, which makes the chain more loose because of the geometry of the swingarm pivot vs. the engine sprocket. If the chain is adjusted normally, it's too tight when the suspension allows the swingarm to be horizontal. If the chain's adjusted correctly when the swingarm's horizontal, then it's too loose during normal riding, contacting the muffler mount on bottom and the chain guard mount on top. I could put a nylon slider on the chain guard mount and grind clearance on the muffler mount, but the chain would still be under tight/loose conditions part of the time. I think this tensioner will be a very nice fix, and I found them for sale on eBay for $70. I'll post a close up pic of it when I install it.
nice ironhead 83xlx...you got it! those fancy sprung secondary tensioners pick up the slack created by supension movment, to keep the chain from hopping during jounce and rebound of the shocks!
