Last Post: mct496
Last Post: conv90
Last Post: Jowniofownio
0 Intro from New England
0 Diagnostic help
8 Crankshaft Failure
Last Post: spitfirechopper
0 Head gaskets.
Last Post: Fridge
Last Post: MatHormell
Last Post: Ben221
Last Post: blindfredy
0 first harley- help!!
Last Post: cantolina
0 oil cooler or not?
0 Engine dies when choke off
Last Post: shovithead
0 90 in. Build
Last Post: mac93
0 newby from Australia
Last Post: GeoK
0 Airtech Streamlining is a Rip-Off Compamy
Last Post: dragstews
Old 20th January 2009
spackelquack's Avatar
spackelquack spackelquack is offline
Sportster/Buell Year: 83
spackelquack is an unknown quantity at this point
Default Super E Shortie mounting to Ironhead
If anyone has a Newer, SS carb........where does it secured to the engine or case? Mine (carb) was free floating, jutst secured by intake clamps and I believe is causing my never ending plug foul problem.
Nothing in SS carb manual useful. I have the mount. It doesnt seem to go anywhere.(too long for that bolt, to short for the other bolt)
Augie
Skinner's Avatar
Skinner Skinner is offline
Sportster/Buell Model: XLH - now XLCH
Sportster/Buell Year: 1976
Sportster/Buell Model #2: 883 XLH - Wrote Off/SOLD
Sportster/Buell Year #2: 1995
Other Motorcycle Model: CJ5 JEEP
Other Motorcycle Year: 1967
Skinner is on a distinguished roadSkinner is on a distinguished road
I don't have the super E but my bracket mounts to the back of my air cleaner, not the carb itself.
Skinner
fdny37's Avatar
fdny37 fdny37 is offline
Senior Master Bike Builder
Sportster/Buell Year #2: 1968
Other Motorcycle Year: 2014
There is a bracket that bolts to the back of the air cleaner and to one of the tappet bolts. It bolts to the front cylinder intake tappet hold down bolt. You can see it in this picture. It holds the carb rock solid.
I made one from flat steel stock, 1/8" thick by about 1" wide. Attaches the same as FDNY's above. A couple of bends; drill a couple of holes. A bit tricky getting it exactly the correct shape.
Old 21st January 2009
THANKS SO MUCH guys! BIG thanks Skin for the picture. It mounts where the the old from stock mounted. Seeing the picture......They sent me the wrong support. The angle on mine is completely different.
Thanks Mick also. Gonna bend this baby and maker fit.
I'de loose my mind without this place
