0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
0 Primary Oil INSANITY!
Last Post: cotton1
0 Cartridge Conversion?
Last Post: XLXR
Last Post: MXHD55U
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
Old 23rd February 2009
Rush's Avatar
Rush Rush is offline
Sportster/Buell Year: 1973
Sportster/Buell Model #2: XB12X Ulysses
Other Motorcycle Model: Yami XS650 (custom)
Other Motorcycle Year: 81
Rush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the rough
The original link worked for me, but the new one asks for a username and password.
Nice work, by the way. Thank you for your efforts.
russzx6's Avatar
russzx6 russzx6 is offline
Sportster/Buell Model: 1000cc Ironhead Sportster
Other Motorcycle Model: 96 KDX200 Dirt Bike
russzx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to all
Sorry Lads i might have not made it accessable to all. ..try this link and let me know, title is "Ironhead wiring diagram in Autocad". It may have the out of date drawing sitting next to it . .i'll delete that if this link works
http://cid-1a5266e54855285b.skydrive...%20diagram.pdf
Originally Posted by russzx6 View Post
...try this link and let me know, ...
It's good now.
75sporty 75sporty is offline
Sportster/Buell Model: Ironhead XLCH
75sporty is an unknown quantity at this point
I have a few questions again.
What wire goes on what post for the regulator? I have D+, DF, etc...
My high beam switch is a 3 way with a common wire to the center, then a switched wire to high and low beam. I thought this was stock on my 75. In this case, I just take the center wire for power, and have the other two as switched high/low beam. I don't need a relay, right?
FourCams's Avatar
FourCams FourCams is offline
Sportster/Buell Year: 1969
Sportster/Buell Year #2: 1972
Other Motorcycle Model: FXSTC
Other Motorcycle Year: 1996
FourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really nice
D+ goes to the Armature post of the generator. The wire to your generator light also comes off this post.
DF goes to the Field post of the generator.
B+ goes to the positive battery post. It also goes to your ignition switch.
Gnd goes to ground.
You don't need a relay for the headlight. The wire to the switch should be on the lighting breaker though.
♠ 1969 XLCH ♠ 1972 XLCH ♠ 1996 FXSTC ♠
hmiller's Avatar
hmiller hmiller is offline
Sportster/Buell Model: 883
Other Motorcycle Model: BMW K1200GT
hmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud of
Your draftsman should be able to change the background color of the plot to black to make the white and grey colors show up better. Autocad used to use a black background but changed when they went to the model views. I change them back to the old schemes to better match my color setups.
And I am assuming the lighting and Accessory C/B's are 15 and 10 amp? The main one is a 35 amp, right?
FourCams's Avatar
I'm not 100% certain on the 75 but I think the lighting is 15 Amp, the Ignition is 15 Amp and the main is 30.
russzx6's Avatar
On the Autocad DWG drawing yes it shows up grey and white wires, but when you change them to a pdf version they lose clarity. Autocad is not a thing most people can open.
hmiller's Avatar
Just looked at the link, didn't realize it was a pdf, for some reason I assumed it was a jpg or wmf. I've had some luck with them but the issue is always resolution, the small text always ends up blurry or shown as a box.
In the words of Roseann Rosanadana: Nevermind.
