Last Post: XLXR
0 Not measuring any crankshaft endplay
Last Post: nakina
0 Manifold Leaks Gone !!!!
Last Post: cazz1000
Last Post: groovemeisterus
Last Post: rwharris
Last Post: tvon
Last Post: KCinSB
0 Lightning strike
Last Post: Screw Loose Dan
Last Post: x1_guy
Old 22nd January 2009
FiftySixer's Avatar
FiftySixer FiftySixer is offline
Sportster/Buell Model: Hot Rod Sportster XL 1203
Sportster/Buell Model #2: 100th Anniversary
FiftySixer is a name known to allFiftySixer is a name known to allFiftySixer is a name known to allFiftySixer is a name known to allFiftySixer is a name known to allFiftySixer is a name known to allFiftySixer is a name known to allFiftySixer is a name known to allFiftySixer is a name known to allFiftySixer is a name known to allFiftySixer is a name known to all
Default SPROCKET & BELT SIZE? Difference 883 & 1200?
Hey Fellow Forum Members,
I have a 2003 XL 883.
What is the stock OEM rear wheel sprocket size & belt size? Teeth?
What is the difference for a stock OEM sprocket & belt 1200 of the same year?
Does the 1200 spec. belt and belt sprocket give an advantage in speed? By hoew much?
Is it any easier on the motor?
Any help is appreciated.
Best regards,
56r
I Do Custom One Of A Kind Graphic Designs & Websites in exchange for bike parts!
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
Final drive for a 883 is 27/61
For a 1200 it's 29/61
Old 23rd January 2009
FiftySixer's Avatar
Default Thanks Biknut
Hey Bro Thanks for the reply,
What does that mean as far as how the bikes run being that my bike is a 1203cc bike now (converted from 883 to 1200 see below) still with the OEM 883 final drive? Which bike would have Stronger acceleration? Higher Top end? Should i convert to an OEM 1200 final drive?
I suppose I should ask the question differently....now that my bike is basically as warmed up Buell motored Sportster 1203cc how does it run (acceleration and top end) compared to a 1200 with OEM final drive?
Thanks......
also ....that is one bad ass looking bike in your post and just reading your mod list it is no doubt a road burner as well.
What kind of nubers are you getting from your bike?
Best regards,
56R
black_n_orange_08's Avatar
black_n_orange_08 black_n_orange_08 is offline
Other Motorcycle Model: Honda SL70
Other Motorcycle Year: 1971
black_n_orange_08 will become famous soon enoughblack_n_orange_08 will become famous soon enoughblack_n_orange_08 will become famous soon enoughblack_n_orange_08 will become famous soon enoughblack_n_orange_08 will become famous soon enoughblack_n_orange_08 will become famous soon enoughblack_n_orange_08 will become famous soon enough
Your stock 883 gearing will give you more acceleration, as they both have the same rear sprocket, but the two tooth smaller 883 countershaft sprocket makes for more accel. I geared my 1200 like a 883 for that reason.
08 1200C, 2-1 header, custom paint, frisco'd tank, slammed, loud, fast.
Live fast, Love hard, die young, and leave a beautiful memory...
FiftySixer's Avatar
Default THANKS black_n_orange_08
How does that shake out in terms of the bikes behavior on the road,
At 75 miles per hour what rpm's would an 883 be making?
What rpm's from a 1200 at the same spped?
And is the diffreence from when the bike had 1200 final drive specs and now with 883 final drive specs a noticable difference?
How much so ? Only slightly or Very noticeable?
Thanks,
56R
biknut's Avatar
I think road speed wise there's about 9 mph difference in top gear. Without figuring it out a rough guess is 500 rpm.
I can only answer part of your question, because I don't have a tach.
But I can tell you that I noticed a huge improvement in acceleration. If you're not planning to run 100 mph all day long, you probably won't miss the 29 tooth. HD just gears these bikes too high to begin with, in my opinion.
FiftySixer's Avatar
That my brother was the answer I was looking for.
I'm leaving it alone then and going with the stock 883 set up it has now.
One last stupid question,
Does anyone change 5th gear on these bikes to be able to go fast at low rpms on long trips?
I would like to be able to run about 80 to 85 without fear of burning up the motor on a long trip (500 miles to me).
Thanks,
Bro
Best regards, 56R
tensejed's Avatar
tensejed tensejed is offline
tensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to all
i put the 29 tooth front pulley on my 883 and it makes a world of differnce in the higher gears. and as far as off the line its fast enough for me. but i may be old, bald and weird
the females are fixing my old XL for fathers day . its a ford not a harley but its mine, MINE !!!
FiftySixer's Avatar
Default TALL 5th GEAR FOR AN EVo SPORTSTER?
Hey Brothers,
one last question;
Does anyone make a taller 5th gear for these bikes to go fast at low rpm on the highway or is it all done at he final drive sprockets?
Thanks,
Best regards,
56R
