0 Value of a Boattail?
Last Post: valvebeater
Last Post: jammantoo
Last Post: lugster
0 Viking bags??
Last Post: cotton1
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 2001 883 'customizing' log
Last Post: cotton1
0 rpm jump pulling in clutch
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: jordan1200
Last Post: Racepres
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
0 79 ironhead
Last Post: Steven2142
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
Last Post: Turbo Sporty 48
0 Feeling in trouble.
Last Post: gravydog
5 Am I looking for Trouble ?
Old 25th January 2009
gemeinschaft's Avatar
gemeinschaft gemeinschaft is offline
gemeinschaft will become famous soon enoughgemeinschaft will become famous soon enoughgemeinschaft will become famous soon enoughgemeinschaft will become famous soon enoughgemeinschaft will become famous soon enoughgemeinschaft will become famous soon enoughgemeinschaft will become famous soon enough
Default No Oil filter.....Help?
I was looking yesterday for the oil filter on my 1977 XLCH and I could not find one. Then I looked it up my Clymer manual and found nothing useful (my bike has been converted to Electric Start so it has a different oil tank, but NO filter.
So I am thinking, it would be a good idea to install an oil filter before I cause more wear on the engine...
Has anyone else ran across this and if so, what direction did you take?
I am thinking about just finding a way to use a standard size oil filter for a cars and adpat it for my bike...
All comments, suggestions and advice will be greatly appreciated..
Thanks in advance.
"Those that beat their swords into plowshares are destined to plow for those who do not." - Murphy's Laws of Combat
"When a strong man armed keepeth his palace,his goods are in peace." - Luke 11:21
"Dulce bellum inexpertis" - Erasmus
bdbecker's Avatar
bdbecker bdbecker is offline
Sportster/Buell Model: 883 XL
bdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of lightbdbecker is a glorious beacon of light
Here's a thread that might be of some use to you:
http://xlforum.net/forums/s...d.php?t=273845
Dragstrip King of the Popes of Hell MC
maverick maverick is offline
maverick is an unknown quantity at this point
use the left side motor mount kit cooling in the wind and you'll be fine you can get it from jp cycles
Old 26th January 2009
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
CH had no oil filter originally.
Just depended on the big end rollers to crush any particles into paste.
If you have the stock HD XLH oil tank as part of your electric start conversion, JP Cycles sells a good filter that drops in the filler cap of the tank.
Gone Gone is offline
the kit that is part of the motormount works good, have one on my XLCH. throw a cooler on that thing while ur at it, and DO NOT use an auto filter on ur ironhead. it was designed for a lot higher operating pressure than an ironhead produces and will put to much restriction in the return line.
flathead45's Avatar
Sportster/Buell Year: 86
Other Motorcycle Year: 1945
I got the drop in with my side mount tank. not the best but cheap and easy to change.
gives the illusion of runnin no filter
"lord of the Night Lite"
thank god for darwin ;)
superwarden's Avatar
superwarden superwarden is offline
Sportster/Buell Year: 1968
Sportster/Buell Model #2: XLC
Other Motorcycle Model: FXSTD
superwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of light
External filter kit is the way to go.
Any date that is not on your tombstone is considered a lucky day.
Old 27th January 2009
Ivan RoachCoach's Avatar
Banned
Default Auto oil filters are perfectly safe to use on your ironhead...
...just use common sense and change it on a regular basis so it doesn't jam up on you.
They will absolutely NOT put any more restriction on your return, feed, or vent lines than a motorcycle filter.
What they will do is add oil capacity to your system and save you a lot of $$$ if you're fastidious about oil changes, like me.
The Fram HP1 is a high-flow/low-restriction race filter that works really well and can be found at any auto parts store.
Shadowdog500's Avatar
Shadowdog500 Shadowdog500 is offline
Sportster/Buell Model: XLH-1000
Other Motorcycle Model: Honda Spree
Other Motorcycle Year: 1987
Shadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enough
I have the one that drops in my tank as well. For some reason I thought that is the way they were from the factory. It doesnt get in the way at all, and seems to do its job just fine. Changing it is a snap, just take the lid off the tank, pull the old one out, drop the new one in, and put the lid back on.
Why would the external filter be more desirable than the one that drops into the oil tank?
Thanks,
Chris
It’s not really your bike unless you work on it yourself!
"Believe nothing, no matter where you read it, or who said it,
no matter if I have said it, unless it agrees with your own
reason and your own common sense."
-Buddha (536 B.C.-483 B.C.)
flathead45's Avatar
Thanks,
Chris
and another bonus, ya have to take it out to change the oil. ya can't forget. ever
