Last Post: Twistedrench
0 Cartridge Conversion?
0 Primary Oil INSANITY!
Last Post: GrimKvlt
0 Solar battery charging
Last Post: tvon
Last Post: tvon
Last Post: tvon
Last Post: Wharfcreek
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
Old 13th November 2006
ol'ironhead ol'ironhead is offline
Sportster/Buell Year: 1973
ol'ironhead has disabled reputation
Default question about neck races
I'm looking to get some new front end parts (steering stem, trees, bearings, and races) and as I understand it, the races can be hammered in (and out) with a block of wood. I recently heard that this is incorrect and that new ones need to be pressed in. Is this the case?
Is any stem & tree set-up (manufacturer) better than the next? When I took the front end apart I found that there was a difference in diameter of 0.003" between the stem and the bearings and so I'm replacing everything.
Old 14th November 2006
I do not have much experience with installing bearings. I have seen it done with a hammer and a PVC pipe, or a hammer and a large socket.
sjeccles's Avatar
sjeccles sjeccles is offline
Sportster/Buell Year: 77
sjeccles is an unknown quantity at this point
When I painted my frame I just used a block of wood and a large hammer. Worked fine just take it easy and make sure its going in square.
Old 15th November 2006
XLFREAK XLFREAK is offline
I don't know about a block of wood, but you can get
a race and seal driver set for about twenty bucks.
Fourcats's Avatar
Fourcats Fourcats is offline
Sportster/Buell Model: XLCustom 883
Sportster/Buell Year: 99
Fourcats will become famous soon enoughFourcats will become famous soon enoughFourcats will become famous soon enoughFourcats will become famous soon enoughFourcats will become famous soon enoughFourcats will become famous soon enough
Or some threaded stock, some nuts and washers...I hate beating on things.
tprJJ49707's Avatar
tprJJ49707 tprJJ49707 is offline
Sportster/Buell Year: 1985
Other Motorcycle Model: Indian Sport Scout
Other Motorcycle Year: 1940
tprJJ49707 is an unknown quantity at this point
The cups should be pressed in on later models or any with timken bearings. The cup is real light and could damage easy. The earlier roller bearing types are just like a bicycle and could be tunked in with block of wood.
sjeccles's Avatar
His profile says a 73 so I was basing it on that.
tprJJ49707's Avatar
I'm with ya, just trying to come up with rational explanation why half say yes, and half say no...possibility of retrofitting timkens to old iron too.
jweitzel's Avatar
jweitzel jweitzel is offline
jweitzel has disabled reputation
If you talking about getting the cups in the frame neck, try freezing them for a few hours. The cups will contract and should slide in easy. You can do the same with the races. And/or try all thread and some blocks on each end, but I wouldn't beat it too much with anything.
Old 16th November 2006
sjeccles's Avatar
The ones saying no aren't riding Ironheads. So they may not be used to the old neck cups.
