0 Stage 1 results
0 Screw Loose's Repairs
0 C.O.B.B run west
0 Lowboy frame conversion
Last Post: Sportster-92
0 Spokes or Mags
0 Project of the day
Last Post: Baby883
Last Post: kaveebee
Old 3rd February 2009
VT_Sport VT_Sport is offline
VT_Sport is an unknown quantity at this point
Default Frustrated by new Slip Ons
I have a basically stock 2008 XL1200L with 4,500 miles on it. This is my first bike and I enjoyed the heck out of it last summer/fall. While I will eventually fully pay my taxes, I decided to start with a mild exhaust upgrade. I do a lot of longer rides (60 mile commute) and wanted something that sounded better, but not to the point that I needed earplugs. I thought I wanted a deep, mellow rumble.
After doing a lot a reading here, listening to clips on youtube, and talking with everybody I could, I ordered a set of Rush Balony cut slip-ons with 2” baffles. (PN 18604-200) I put them on on Saturday. While it is true that the new mufflers did “slip-on” the stock ones did not “slip off”. Some rust had formed at the joint, and required quite a bit of persuasion to separate. I ended up scratching one, and tearing up the end of the the other when light taps with a brass drift became more spirited. Oh well, I’m replacing them anyway, right?
We had some great weather on Sunday here in Virginia, so I fired up the bike and rode about 40 miles. When I first fired it up, the grin on my face was obvious. It sounded awesome at idle, though a bit louder than I expected. However, the grin faded as the miles passed, and the resonance became downright annoying. I’m not sure exactly how to describe it. A harmonic frequency? Constant popping? (not backfiring). Like being backstage at a concert...music sounds right to the crowd, but not behind the speakers. It wasn’t the rumble I expected and was not pleasant at all. I wanted earplugs by the time I got home.
Before the pipes had even fully cooled, I pulled them off. I’m not keeping them as is, and the bike is now sitting in the garage w/o exhaust. During the initial removal of the stock mufflers, I didn’t loosen the pipes at the head, but did have more movement than I wanted to as I tried to get the old ones off. I looked, but didn’t see any evidence of an exhaust leak at the head. Is there a chance I might have dorked up the gasket and that is my problem?
I figure I have a month or two to sort this out before spring. I’m not sure what to do:
Replace all exhaust gaskets?
Put the scratched stockers back on or buy a fresh set of takeoffs from someone?
Start changing baffle sizes in the Rush pipes until the resonance goes away?
Buy something quieter? Screamin Eagle? Other suggestions?
Upgrade the AC & add a tuner (PCIII or IV) and hope a richer mixture helps?
Buy earplugs?
I’m looking for suggestions & I might have some gently used Rush Slip-Ons for sale.
DIESEL's Avatar
DIESEL DIESEL is offline
If you want a set of stockers, PM me, I have three sets.
Diesel
diggy16valave diggy16valave is offline
diggy16valave is an unknown quantity at this point
i thought you had to do a remap or installl a power comander when install slip ons or full pipes. do you have a windscreen. ? i took a friends dyna out and it was terrible with the windscreen installed we took it off and it was much better,
phmann's Avatar
phmann phmann is offline
Sportster/Buell Model: XL883L
phmann will become famous soon enoughphmann will become famous soon enoughphmann will become famous soon enoughphmann will become famous soon enoughphmann will become famous soon enoughphmann will become famous soon enough
what about drilling out the stock pipes to give them a tad more growl?
'06 XL883L; K&N Replacement; Drag pipes; mini-apes; feels good to have done it all yourself.
Yep, has a windshield. Didn't think about it until now, but I can see how the sound could bounce off and cause the echo or reverb that I'm getting.
Too bad I didn't pop it off yesterday and see if it made a difference.
Sounds like a good option for my scratched up ones. Nothing to loose now.
phmann's Avatar
might as well try it right? I've heard them and I think they sound good. Are you able to return the slip ons? how bad could they be scratched? Can't be too horrible. And if anything you'll know how to drill out stock mufflers; you could attain some from guys on here really cheap and do it again.
Doubt it. They are used now (just barely). I'm not worried about it. Somebody around here or on ebay could use them if I don't keep them.
FoxsterUK's Avatar
When I first got my Sportster it had some SE2s that had been 'modded' and were too loud, they were practically straight pipes. I got the annoying concussions you mention. I think its a low frequency shock wave from the exhaust that seems to make your head rattle.
One option to consider is to fit some additional baffles inside the ones you have. The best ones I found are the Khrome Werks ones, or the cheap universal ones on eBay are OK too. You might then be able to fix the new mufflers you have for about $20.
Fox
"Concussion" is the word I couldn't pull last night, but it accurately describes the phenomenon. Thanks!
Can someone give me a quick lesson in baffles? For instance, Rush has 1.5, 1.75, 2.0 & 2.25 ones. I found a video on youtube with all four demo'd on a Sportster. The big ones sound deeper, but that is all I could really get from it. Is there any general rule regarding the tradeoffs as sizes change, or does it vary from bike to bike? What are the tradeoffs, or is it just tone? Why would adding additional baffling work better than just changing out the Rush ones to a smaller size, or is this just a cheaper option?
