Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
0 1958 XLCH? Maybe not... Help me ID this bike
Last Post: Jhbox13
0 Pegs vs floorboards
Last Post: RandallM
0 Coulda' - Shoulda' - Woulda' - Solenoid/Bendix?
0 Greetings from NorCal/Nevada
0 First time HD owner
0 Can't install kickstand spring
Last Post: DR DICK
0 extortion
3 Rear galiper bracket spec.
Last Post: DG Racing
Last Post: sportymike02
0 Roler Rockers - Adjustable or Fixed Push Rods
0 A Reliable Engine
Last Post: bikeridermark
1 Hello from Cork, Ireland
0 Video - We Were Wrong! Dyno Told the Truth About Airflow- Question Answered
5 Frankenstein forks- preload?
Last Post: WVDevil
0 Microsquirt EFI Conversion
Last Post: t120r
Last Post: JimVonBaden
0 My XLCH/XLR Hybrid build
Last Post: Steelrain
0 On board voltmeter
Last Post: ZTatZAU
0 Let's See Your Iron!!!
Last Post: Ghostdog
0 Aftermarket Ironhead Seats - ID?
Last Post: ZTatZAU
steve yorke (64), edman (56), Hudsonator (54), kozman32 (54), R3DN3X (52), gmcsid (51), mitch (46), Txngrg87 (35), Gotenfan (32)
  #31
Old 25th November 2018
rubine rubine is offline
Sportster/Buell Year: Bits
Other Motorcycle Model: '00
What do you want to know? There are many reasons not to run breathers back into the intake, the main one being oil/gas mix in the intake means less air, as in the oil/gas mix displaces the oxygen needed for combustion, and the name of the game is getting as much fuel/air through what is basically a pump - the engine. The Buell PCV breathers are a one way valve, they let the heads breath out oil/gas mix, but do not let the vented gasses, oil mist or atmosphere in. The best way to breath heads is with the Buell system and vent the oil and gasses via a rubber hose to a catch can that you have to monitor and periodically empty. You can see the black PCV valves on the top of my engine. Just run a hose from these to some kind of bottle or can that you can empty to waste.
S&S has a system that is a bit of both (can and intake) but someone else is going to have to chime in to explain that... Jorgen!
What do you have at the moment?
Maybe some guys can post up their ways of dong it! Lets see some different systems
Old 26th November 2018
gusm2's Avatar
gusm2 gusm2 is offline
Sportster/Buell Model: Cyclone M2
Other Motorcycle Model: Suzuki SV650
Other Motorcycle Year: 01
gusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud ofgusm2 has much to be proud of
I have converted my 99 Cyclone to XB rocker covers, the rear pcv needs chopping a little to clear the underside of the fuel tank but otherwise working well, I run two separate pipes to a catch can
10.93@119.9
Old 27th November 2018
Airbozo's Avatar
Airbozo Airbozo is offline
Sportster/Buell Model #2: S3T Thunderbolt
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XB12R
Other Motorcycle Year: 2009
Airbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond repute
I converted my 2000 S3T as well. I used some rubber hoses under the back of the tank (body plastics) to lift the tank ever so slightly to prevent the tank from rubbing on the rear PCV. I've found that routing the hoses similar to how Rubine shows the outlet of the PCV works better than trying to route the rear PCV hose rearward.
Routing the rear PCV towards he back will cause interference and eventually leaks around the rear PCV, and eventually failure.
"...Dumb all over, A little ugly on the side... "...Frank Zappa...
