Last Post: GeoK
Last Post: GeoK
0 ‘68 XLCH...transmission
0 New from Utah
Last Post: GeoK
Last Post: hexnut
0 1974 Ironhead
Last Post: Jheitt
Last Post: Jheitt
0 primary chain temp.
Last Post: shovithead
Last Post: cazz1000
3 Wtb, Wts, Wtt, Wtg (EFIs)
Last Post: Crash7557
0 no rear brake light
Last Post: SKID LID
Old 8th February 2009
Brandon Richrdella Brandon Richrdella is offline
Sportster/Buell Year: 1973
Brandon Richrdella is an unknown quantity at this point
Default fouling of plugs after a couple minutes of riding.
hello we had a touch of spring here in chicago. 60 outside. well i starterd my bike and was riding aroubd the block and it was foulong out the plugs. it has a super b carb with drag pipes kick only. but after i cleaned off the plugs she would start in 2 or 3 kicks. i could fell the bike running strong but after a couple mins it would stutter and no power. then shut down. i dont know? any help please.
If you used the choke to start it, and let it idle with the choke on for a few minutes, that would foul the plugs. So what was your starting procedure? Should use the choke only to get it running, then choke off and use the throttle or throttle lock to keep it running.
Otherwise:
Was it running well before this?
What slow jet is in the carb, and how many turns out on the pilot screw?
[I am not familiar with that carb but others here are].
FourCams's Avatar
FourCams FourCams is offline
Sportster/Buell Year: 1969
Sportster/Buell Year #2: 1972
Other Motorcycle Model: FXSTC
Other Motorcycle Year: 1996
FourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really nice
How long are you leaveng the enrichener on?
Are the plugs oil fouled? or fuel fouled?
First check the air cleaner and make sure it's clean.
Check the compression, if it's low, spray some WD-40 in the spark plug holes and let it sit overnight. If it's fuel fouled (black soot on the plugs) make sure you're not riding with the enrichener on, and pull the float bowl and spray out the jets and needle & seat with some carb cleaner. Also remove the enrichener and spray it out. There may be some varnished gas or dirt keeping it from seating.
♠ 1969 XLCH ♠ 1972 XLCH ♠ 1996 FXSTC ♠
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Dry fouled or wet-fouled?
Is it oily?
~Chuck
Occam's Razor...
XLF Tuning Stickies
its gas they are wet fouled. and the piolt screw is 2 1/2 turns it idles awsome and i cleaned every thing on the carb. its only after i ride it a little i feel it start to sputter. i got the bike on a trade and the guy i got it from got it on a trade. so i put some plugs and a battery and she fired up. cleaned the carb and idled and ran great but now 2 months later this.
cantolina's Avatar
Just sounds pig-rich....a tuning is in order....
ya thats what i am thinking. i just gonna take it in. this carb is agervating me. if anyone has any other imput please let me know. thnanks everyone brandon
2,1/2 turns out on the pilot screw is too much. What i would do is:
  1. turn it in until gently seated then out 1,1/2 turns
  2. run the engine until it is warmed up
  3. set the idle speed at about 1000 RPM
  4. counting by 1/4 turns as you go along, first turn the pilot screw in until the idle becomes a little rough, then turn it out, letting it go thru even idle, until it gets a little rough again
  5. set it in the middle of the two spots
This process is a little trickier than it sounds. You have to be careful to not burn your fingers on hot engine parts; listen carefully to the idle quality; enjoy all the damn noise!
First read the Stickys on carbs. There is one on cleaning, another on tuning, whatever.
racerwill's Avatar
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Year #2: 80
set the pilot screw the way Mick says....... but I don't think 2 1/2 turns out is that bad..... since it idles okay but fouls while riding I would be looking at the main jet..... sounds like it's too big (cuz you're sure you're not riding with the choke on)
Ww
master wizard
[B][COLOR="Red"]Super Moderator[/COLOR][/B]
[FONT="Book Antiqua"][B][U]RIP Mr Jimi[/U][/B][/FONT]
"All The Way"
Ww
I dunno - he said it fouled riding around the block in the first post.
And adjusting the primary will tell him - if, after setting it properly, he's STILL fouling plugs, YEAH THEN look at the main...
