0 New to me 55kh
0 Nup 1009 (Bearing)
Last Post: dave76
0 S&S Super E Carb
Last Post: jp2code
Last Post: mikethebike61
0 so it's officially ended
0 AGM battery for 76' XLH
Last Post: forqueue
Last Post: Clevspeed
Last Post: class of 82
Last Post: ReddTigger
Last Post: Nitro57xl
Last Post: Cablejudge
0 Sportster book
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: Nicktater
0 What jets do you use?
Last Post: Thack
5 Red Shift cams similar to Jackhammer 570 ?
0 My 08' Nightster
Last Post: XL1275
Old 12th February 2009
Phracas's Avatar
Phracas Phracas is offline
Phracas is on a distinguished roadPhracas is on a distinguished road
Default ECM & PCIII Relocation w/ Pics
Here is how I started.
Pulled out the battery and pulled the wire bundle to the ECM through.
Put back the battery. Strung the ECM between the battery box and the engine. Connected it up.
Zip tied the ECM (left side).
Zip tied the ECM (right side).
Manuever the PCIII and other pieces to make it the best possible fit. This took quite a while and the picture shows the best way I could come up with.
Put back the side panel. It fit in the lower connecter but I had to zip tie the top two connectors. Got really worried here about how far it was sticking out...
Not so bad from a distance...
Actually looks fine w/ the seat...
Side view of my bike because I can...
Last look at the ECM.
Beginning of End's Avatar
Beginning of End Beginning of End is offline
Beginning of End is on a distinguished roadBeginning of End is on a distinguished roadBeginning of End is on a distinguished roadBeginning of End is on a distinguished road
great pics. One question aren't you worried that your ecm might get hot sitting right behind the engine? Great looking bike. I just chopped the fender on my 07 olive. I am looking for a place to put the ecm and the fuel pack. Thanks for the pics.
2007 Nightster with Detroit Bros Frame(Under Construction)
Phracas's Avatar
It is actually a fair distance from the engine. I am going to watch it closely though. I may put some kind of heat shield in front of it.
Originally Posted by vegasrock View Post
is the ecm waterproof?
Ya know, I think it is. Looks like it is sealed tight.
vtdrugs's Avatar
vtdrugs vtdrugs is offline
Sportster/Buell Model #2: ironhead
Sportster/Buell Year #2: 74
Other Motorcycle Model: Suzuki GSXR600
vtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura aboutvtdrugs has a spectacular aura about
mind if i ask why you relocated it if you are running the stock seat with shocks? and from personal experience.....NO IT IS NOT WATERPROOF!!!!!!
2008 XL1200N....work in progress
1974 XLCH....another work in progress
CTFS
I hate deer!
Phracas's Avatar
That would seem pretty silly, wouldn't it? I have a seat pan on order and I'll be getting new shocks here shortly.
Not waterproof? Do tell...
Crud. I'll have to figure out a way to make it so. Maybe if I coat it in heat resistant silicone. Thank you vtdrugs for the heads up!
vtdrugs's Avatar
to clarify...the unit itself is waterproof...it's the harness, especially where it attaches to the unit that isn't
Phracas's Avatar
Yeah, thats where I figured you had meant.
If you don't mind my asking... did yours get fried due to water?
I'm wondering how much of a hassle they are to replace and at what cost.
sportytrace's Avatar
OzChick
Sportster/Buell Year: 08
Easy enough to replace... have to go through a "pairing process" that takes about half an hour. Cost about $350RRP - available cheaper online. I think I'd be worried about it getting too hot there as well as the water issue.
Old 13th February 2009
Phracas's Avatar
Thanks sportytrace. I am hoping to find something to wrap it with so it is protected from water and heat.
I now know not only the cost to replace it if it does fry... but also where the heck Wongawallan is!
OzChick
Gold Coast hinterland, Queensland
